BMW 3-Series (E90 E92) Forum
335i N54 Continual Cylinder 6 misfires
04-28-2017, 11:03 AM | #1 |
Rep 27
Drives: 2015 BMW F10 M5
Hi,
I've been having issues with my 56 plate with misfiring, shutting off injectors and a mixture of CEL and EML. Lots of 2D92. So far I've had new plugs, new coils, stopped an oil leak from the rocker cover, and a new injector in Cylinder 6. I've also just had the inlet valve ledge replaced due to one or two (over 4 month ownership) VANOS errors (2A82). It's also had a new water pump and 2 new turbos prior to these errors. I still get misfire detected cylinder 6, and according to Carly freezeframe it's at 5984rpm. Clearing the codes and repeating the process of accelerating upto/past this rpm ensures the EML comes back on. Any pointers? Getting a bit peeved now. |
04-29-2017, 01:59 PM | #3 |
Rep 27
04-29-2017, 02:00 PM | #4 |
Rep 27
04-29-2017, 02:01 PM | #5 |
Life is better with burnouts
99
Rep 611
Drives: BMW
Well it looks like you have swapped/replaced all the parts for that cylinder. Consider a bad mosfet in your dme or doing a compression test on cylinder #6.
04-29-2017, 02:14 PM | #6 |
Rep 27
04-29-2017, 02:18 PM | #7 |
Rep 27
04-29-2017, 06:38 PM | #8 |
Rep 2,825
04-29-2017, 07:46 PM | #9 |
Rep 76
So did you put a new injector on cyl 6 or swap another one to it? I had a similar inexplicable misfire on mine and I swapped injectors (and coil and plug and tested compression) and the misfire stayed on the same cylinder. Took it to my favorite indy and they diagnosed injectors. I refused to believe it because the misfire would not move off of the one cylinder, but replacing a bank of three cured it. I cannot explain it.
04-30-2017, 01:13 AM | #10 | |
Rep 27
EDIT: It was a brand new Injector into 6. We swapped with Cyl 1 afterwards to rule out individual injector failure. Last edited by tgreer; 04-30-2017 at 01:32 AM.. |
05-01-2017, 12:03 AM | #11 |
Rep 263
Drives: E46, E91, F21
Have you ever had a carbon media blast performed for your intake valves?
05-05-2017, 03:47 PM | #12 | |
Rep 27
Although I'm being told this is down to my DMFW, so I have a new one + new clutch being fitted next week @ CPC. If this doesn't solve it, I don't know what will. CPC don't have any more ideas. |
05-05-2017, 07:19 PM | #13 | |
Rep 9,209
05-05-2017, 08:30 PM | #14 |
Rep 1,017
There is a tread somewere that the number 6 misfire still continuing after all that's replaced, could be from the oem flywheel. Guys running higher hp who experience the same systems, done the same procedure as you, has determined the flywheel is causing the misfire, there is a tread about it and it's been repaired by replacing it with a single mass flywheel. I'm sure others will confirm. Only on 6 tho. Hope this helps, M Factory are building flywheels just for this.
05-07-2017, 02:18 PM | #16 | |
Rep 27
Wires all look in good condition don't see any breakages. |
05-08-2017, 05:15 PM | #17 |
Old Man
248
Rep 131
Drives: DGM 335xi
Just curious you said you put a new injector in cyl 6? what was the index on it?
if its 12 you have to make sure in cyl 5 and cyl 4 are 10 and up (I believe). Index 12 don't play well with others for some reason. Also make sure they code it. I just had the same problem constant misfire on cyl 6 did the spark/coils too but kept on misfiring on 6. So I just decided to replace all injectors with Index 12 (had 2 index 5 and 4 index 9) and now the car runs like its brand new. I hope this helps. |
05-09-2017, 04:01 AM | #18 |
Rep 113
I'm in the same boat as you right now..
Had intermittent misfires since Oct '16. Changed both turbos with new OEM turbos. All Sparks, All Coils, Exhaust Sensors, Just changed all 6 injectors over the weekend however now its misfiring only after a quick WOT. Can't fathom what it is ! Driving me nuts!
05-09-2017, 08:07 AM | #19 |
Rep 23
Drives: 2012 le mans blue 335is
My stealership is pushing a walnut blast... They're telling me these direct injection intake manifolds have terrible carbon buildup... Recommend every 35k... I'm at 88k, and the coil replacement did the trick for me...the walnut blast is about $800
05-09-2017, 12:05 PM | #20 |
Rep 1,017
After you run down the obvious,the dual mass seems to cause misfires when running higher horsepower, check the other form about the flywheel, if your in there, look into changing it. Guys are going with a single for this reason.
05-10-2017, 01:01 PM | #21 |
Rep 23
I just had a persistent misfire in cyl 5. Changed all coils and plugs since they were due. Still threw the code every now and again. Plus in 6th under high load if you punched it the car would mis. So had a walnut blast done and I think I got 50 hp back. Totally different car now.
05-11-2017, 11:35 AM | #22 |
Rep 27
Well, we done the DMFW + Clutch, didn't fix it.
We had a look at the ports, and they're not as bad as others, although I'm still going to get the walnut blasting done. More investigating, found that one of the ports on the intake side for cylinder 6 wasn't opening. Turns out the finger(?) had come off. That's been reattached and now no more misfires on cylinder 6 at 6k+ rpm. Thanks to CPC for battling through with this. |
