01-12-2017, 12:29 PM | #1 |
Rep 19
M240i Coilovers.
What options do I have for a set of coilovers for the m240i.? Same set up as m235i? If im not mistaken some come with the option of using the damper control the car comes with and some don't. If I choose to buy a set without the dampening control would it affect anything else apart from not activating the sport and comfort mode for suspension? Thanks for the help! New to BMWs.
01-12-2017, 12:54 PM | #2 | |
Rep 1,303
Drives: 2021 C8 Corvette 1LT
01-12-2017, 09:36 PM | #4 | |
Rep 1,078
01-13-2017, 01:54 AM | #5 |
Rep 1,303
I thought the KW DDC kit used an app on your phone to control the damping, not the driving experience button in the center?
01-13-2017, 10:02 AM | #6 | |
Rep 580
I priced them out closer to $5000 ,installed, for my 228i.They're $3500 at Turner Motorsport plus installation and tax. Last edited by Tpeterson; 01-13-2017 at 02:28 PM.. |
01-13-2017, 12:36 PM | #7 | |
Rep 1,303
01-13-2017, 03:37 PM | #8 | |
Rep 2,214
Edit: This is what I'm after, and at the same price as the DDC KW's it's a hard decision.
01-14-2017, 08:44 AM | #10 |
Rep 19
Im not really going to the track with her to often but I woulnt mind something to give it a lower look and a comfortable ride lol So I think the KW's atm seem like a good fit.
01-15-2017, 04:16 PM | #11 | |
Rep 1,541
If you do go with coilovers just make sure they have the 5 bolt top hat and not the 3 bolt.
01-15-2017, 10:21 PM | #12 |
Rep 1,078
There are 2 versions of the KW DDC. The one that works with the M235i is a plug and play version and uses your oem buttons to adjust the damping. As such, you are not given an additional button or the capability to adjust using the smartphone. The other version of the kit does NOT work with OEM buttons and you have to utilize their version of the button. It is not recommended to use this for the F22.
01-15-2017, 10:25 PM | #13 | |
Rep 1,078
Tpeterson156.50 |
01-15-2017, 10:27 PM | #14 |
Rep 1,078
I'm going to tag abirmaher because he's the only other person I know of that has this in case he has anything he wants to add.
01-16-2017, 02:00 PM | #15 | |
Rep 2,214
D
01-16-2017, 03:42 PM | #16 | |
Supreme Allied Commander
3893
Rep 54,605
Drives: F80 M3
01-16-2017, 05:32 PM | #17 | |
Rep 2,386
My car also has M3/4 lower control arms and front and rear sway bars so those will play into the difference in feeling as well.
Follow my builds:
01-25-2017, 05:28 PM | #18 |
Rep 91
Drives: M235i & X1 2.0d
Have you also had a look at the JRZ coilovers? You can get a delete, you have three different versions with camberplates and three using the original topmunt. For me they beat all of the above mentioned. Read more here to see some samples. https://europeanautosource.com/blog/tag/jrz.html
01-25-2017, 05:39 PM | #19 |
3893
Rep 54,605
Drives: F80 M3
JRZ track and race products are great, but their road product isn't as robust.
Noise is the most common problem. Although their warranty is great, dampers often need to be send to Netherlands for warranty repair or replacement. A similar product line that is semi custom would be MCS, based here in the US with a much shorter turnaround time. |
01-27-2017, 12:34 AM | #20 | |
Rep 91
01-27-2017, 12:55 AM | #21 |
Rep 91
01-27-2017, 12:01 PM | #22 |
3893
Rep 54,605
Drives: F80 M3
