11-27-2016, 01:38 PM | #1 |
Rep 258
m135i remap stage 2 catless
Hi all,
I know it's the wrong forum, but a lot of m235i owners here with the same n55 engine. So maybe you guys could help me out... I am doubting about getting a ecu remap stage 2 with the m135i.. With a catless downpipe of Wanger the hp will be around 420 and 600nm. Is this still safe enough for the BMW? Are there any other things i should worry about? Thank you. Regards, Danny |
11-27-2016, 03:28 PM | #2 |
IG @bmwF9xG80
3817
Rep 7,595
Becareful who you getting your remap from
Someone to ask for help/advice with m135 is harkes and Darkiedm4
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 |
11-27-2016, 04:13 PM | #3 |
Rep 258
Remap will be done by BR Performance, so that's not a worry. I'm more worried about how the car will perform with a standard intercooler with +400hp and almost 600nm..
11-30-2016, 08:02 PM | #4 | |
Rep 191,503
Always ask for a log when getting a remap no matter who does it
11-30-2016, 08:31 PM | #5 |
Bright Sky
1165
Rep 922
Drives: BMW M235i (8AT)
I would say you'd definitely want an uograded intercooler. Heat soak should become less of an issue that way and it will probably result in more consistent performance.
11-30-2016, 10:13 PM | #6 |
Rep 191,503
+1
12-01-2016, 12:42 AM | #7 | |
Rep 4,529
Started using 100+ octane fuel and boost pressures were increased and felt heat-soak, at a track day last summer, for the 1st time. Now running Wagner evo 2 comp IC. BP |
12-01-2016, 02:49 AM | #8 |
Rep 258
Thank you guys all for the reply.
At the moment I live in the Netherlands. So hot weather won't be a issue the coming months haha! Beside the intercooler I will also update the chargepipes. With my previous m135i it broke after a tuning. Thank you for helping me out! |
12-01-2016, 03:38 AM | #9 |
Rep 4,529
Yup good plan - I upgraded both IC boost pipes when swapping out FMIC. Also fitted Pure hi flow inlet pipe as that was also easier to install during FMIC/boost pipe swap out.
Current '22 X3M LCI.. |
12-07-2016, 03:24 PM | #10 |
Rep 258
So finally the remap is done! Yesterday spent almost 9 hours by BR Performance NL. But the results are amazing! 408hp and 543nm with the Wanger catless downpipe. The boost, sound, and smoothness of the car is unbelievable.
I will get the dyno today, but they did a perfect job! In comfort the car is shifting smooth without any problems and in sport it's a whole different car. I had yesterday on the highway wheelspin with 160 km\u haha.. Here are some pictures and videos: After the downpipe was installed: Coldstart this morning: Dyno Sheet: |
12-07-2016, 05:58 PM | #12 |
Rep 258
Thanks!
No movies on the dyno, but I can promise you the sound and boost is amazing and the pop and going in to the red line is crazyness! If it's not that cold one of the days here I will try to make a movie when driving the car! |
12-09-2016, 11:47 AM | #13 | |
Bright Sky
1165
Rep 922
I'm not getting their flash tune, but the car will be equipped with a JB4, ER Chargepipe and like you, a Wagner downpipe. Did you dyno with RON 95 or 98? I've been filling the car up with RON 98 for about a few weeks now to get the most out of it.
Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive. |
12-09-2016, 01:27 PM | #14 | |
Rep 4,529
Here's my latest jb4 map 6 dyno by comparison with low end peaking at 630-640 nm and staying north of 540-550nm to past 5500rpm Your dyno Sheet: [/QUOTE] Last edited by Bee Pee; 12-09-2016 at 01:34 PM.. |
12-09-2016, 01:56 PM | #16 | |
Rep 4,529
As long as you are happy then good for you. Trust me with 100nm more torque lower down, a Quaife LSD and you needing to dial in more revs, you would not stay with my cars taillights for long !! |
12-09-2016, 03:22 PM | #19 |
Rep 4,529
Yes I do. On 98RON with 16.5psi boost
0-400m - <12sec 0-200kph - <13sec 100-200kph - 8.5sec Look forward to see your 98 SULv 102 race fuel dyno. I use octane booster on Jb4 map5 which auto tunes so see extra 1.5-2 psi above 98RON. |
12-09-2016, 03:25 PM | #20 |
Rep 258
Nice numbers mate!
I will keep you updated with updates and the dyno after two weeks! Sadly enough there is a ocean between us otherwise we could meet haha! |
12-09-2016, 04:27 PM | #21 | |
Bright Sky
1165
Rep 922
Where will you be getting the 102+ octane fuel from?
12-09-2016, 04:40 PM | #22 |
Rep 258
Tags |
catless, remap, tuning, wagner |
