BMW 3-Series (E90 E92) Forum
Wheel fitment ?
11-01-2016, 08:48 PM | #1 |
Rep 74
Wheel fitment ?
I will be picking up my 2010 e92 335i tomorrow. I currently drive a 2004 E60 530i. I have a set of staggered Miro 111s on the E60. 18x8.5 and 18x9.5 ET20. I know these would push out quite a bit, but for those who know the E92 better than I, will i have issues if I try to run these. Not really looking at lowering the car or rolling the fenders. Might just have to let them go with the E60.
Thanks in advance |
11-02-2016, 11:39 PM | #3 | |
Rep 2,367
Drives: 2011 335i
11-03-2016, 02:51 AM | #4 |
Rep 319
Depends on your tires. On my e90 I got a set of work vssd 18x9.5 front +20 and 18x11 rear +25 with 225/40 front tires and 245/40 rear tires and my fenders are rolled by hand which is not as much as what a fender roller could do but it suffices and only runs and hard dips. I'm also lowered on coilovers. You should be fine on stock height with that fitment.
11-03-2016, 01:29 PM | #5 |
Rep 471
You can check OEM fitments by filtering the dropdown on this website by "E90", but I think you will find most non-M OEM wheels have a 30 mm offset. 20mm is going to bring the wheel and tire much closer to the outside and nearer to the fender.
http://felgenkatalog.auto-treff.com/ You can also look at what TireRack recommends for your car, or even call them. They are very familiar with what fits.
BMWCCA member since 1990
Mods: 330 intake, ECU reflash & tune, Magnaflow cat back resonator & muffler, BMW Euro airbox, tinted windows |
11-03-2016, 02:47 PM | #6 |
Rep 74
I am pretty sure they aren't going to work, especially since the rear tire is a 275. I have doing a lot of research, but really hard to find those offsets anywhere on this forum. That should be a clue that it just won't work. Thanks for all of your input. Greatly appreciated.
11-03-2016, 03:39 PM | #7 |
Rep 195
Are the front and rears both a 20 offset? I have the same wheels with 245/40/18 fronts and 275/35/18 rears and rub on the fronts (large dips) but rears none because fenders have been rolled.
11-03-2016, 04:56 PM | #8 |
Rep 24
Before I rolled my rear fenders, I scraped with 255 rear tires and a 15mm spacer but was fine with a 12mm so it will probably be pretty close with the 275 tires. I also had oem sports suspension which lowers the rear considerably.
11-03-2016, 07:03 PM | #9 |
Rep 74
