2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions DIY interior trim replacement F22 F23
      09-18-2016, 09:28 AM   #1
TiresOnFire
TiresOnFire's Avatar
32
Drives: 2015435i,2015550i,2017M240i
Interior trim replacement is easy. Here are the steps to replacing trim as I did on my 2017 M240i convertible / F23. Takes approximately 30 minutes. Tools needed: Torx #20, plastic trim pry tool - got mine on Amazon cheap.
Lift from the right.
Lift from the left. Grip with both hands and lift to release each clip, working your way forward.
Remove the 7 torx #20 screws. Swap centers. Insert the 7 screws. Do not over-tighten! Do not under-tighten or controls will be loose. Snap trim into place in reverse order of removal.
Pry from bottom. Grip with fingers. Pull out and up.
Seven tabs hold vent to trim. Find side with three of the seven and easily release them with your finger or gently with plastic trim removal tool. Insert vent into new trim, four tab side first, then three tab side.
Open glove box door. Grab trim with fingertips and pull. Replace vent with same procedure described for driver's side (release vent from trim using three tab side)
Insert plastic trim removal tool here, at bottom.
Pry.
Keep prying along the forward edge and as you near the top it will release.
To assemble, insert the "L",
With "L" where it fits, properly position top of trim.
Snap into place from top to bottom. If "L" was not first positioned in the first step it will be obvious an you won't be able to snap trim to door.
Appreciate 11
      09-23-2016, 11:45 PM   #2
T4455
Drives: m3
Great DIY. Saving this.
      10-01-2016, 05:03 PM   #3
Hrushka
Same, thanks for this!
      10-01-2016, 05:32 PM   #4
M235iguy
M235iguy's Avatar
Drives: 2016 M235ix
Excellent DIY. Thanks!
2016 ///M235ix | MP Grilles | MP Pedals | Gloss Black M235i Badge | Dinan CAI | Dinan tune | Dinmann CF Diffuser | MP CF Spoiler | CF mirrors | M2 CF interior | M2 Steering wheel
      10-02-2016, 08:39 AM   #5
T4455
Drives: m3
Do you have any photos of these at night and during the day?
The only thing I like about the white carbon fiber is the way it looks at night and many people have pointed out and complimented the white carbon fiber at night. Gives it a spaceship-like feel.
      10-09-2016, 12:37 PM   #6
Bjmsr
Bjmsr's Avatar
21
Drives: BMW 2017 M240i Convertible
Great information. Can you post the supplier and part number you used? Also, did it come ready to install? Clips and all?
      10-10-2016, 09:40 AM   #7
TiresOnFire
32
Www.getbmwparts.com
Click accessories, then f22 f23
Item number 51952333984 can (presently) be found on page 2.
Yes, all clips included.
Get the nylon trim tool elsewhere (Amazon).
      10-24-2016, 07:44 AM   #8
MerlinPurple
MerlinPurple's Avatar
Drives: M2 LBB
Superb thread!
Thank you OP for taking the time to post pics
      11-05-2019, 03:57 PM   #9
n55d_more_alpine
n55d_more_alpine's Avatar
Drives: 2014 BMW M235i
2014 BMW M235i  [0.00]
Great post! Thanks for this. I'm going to try wrapping the pieces in carbon fiber to see how I like it. Will most likely purchase the real carbon trim pieces if so
      11-11-2019, 01:26 PM   #10
JG_Media9
JG_Media9's Avatar
27
i wrapped mine as well and am super content with how it all came out.
      12-21-2019, 10:19 AM   #11
atmer
Drives: 328xi Sport Line
For those of you that have recently ordered this kit, did you receive 4 or 5 pieces?
I just received mine and its missing the left side dash vent assembly as shown above. I questioned my supplier who ordered a second kit for me but that also was missing the piece so I'm not sure if BMW made a change even though the part number is the same.
Thanks,
John
2020 M240Xi
In Transit
Search this Thread:
Copyright ©2000 - 2023, vBulletin Solutions Inc.
