07-27-2016, 05:15 PM | #1 |
Rep 15
Annoying throttle response m235i xdrive AT
First, yes I did some searching, I found a few threads of people talking about similar issues. Most all were in reference to manual gearbox 235's.
I also let google do some work and found one article from, I think motortrend, describing the same behavior. I've noticed that when I first get on the throttle about half the time the car just kinda pauses for half a second then starts moving. Of course you've tipped into the throttle a little more because it wasn't moving and now it really starts moving. I drive an X3 every other day and it's the silky NA 3.0 from the E9x platform and of course it's throttle response is instant. Does anyone else experience this at all? |
07-27-2016, 05:40 PM | #2 |
Rep 260
I have the opposite experience as you. My parents owns a x3 (E83? it's an 07) and I found the throttle to be very laggy in that. On my 2, the throttle is much more responsive. In sport and sport+ (where I spend most of the time), it's pretty much instantaneous. There is a very slight delay in comfort, and a very noticeable one in eco pro (at least as I recall since I rarely use that mode).
07-27-2016, 07:43 PM | #4 |
Rep 227
In comfort you will see more turbo lag as the car is not keeping the RPMs in the sweet spot for performance. Go into sport and it is much more instantaneous.
I dont know how you could not call sport instantaneous, the car really gos on a hair trigger.
Current
19' G05 X5 40i 03' e46 M3 Convert. Past09' e90 335d, 11' E70 X5d, 16' F22 M235xi |
07-27-2016, 08:40 PM | #5 |
Kingslayer
411
Rep 1,479
I use Comfort mode for the highway and Sport + for city driving. With that said, there have been instances in Comfort mode where the transmission seems to confused. You press the throttle, nothing happens, so you press it harder - there is a noticeable delay as if the computer is trying to figure out what to do - then bam here comes a rush of power. Often way more than you intended. It doesn't happen enough for me to be concerned about it.
My car is a 16' M235i with xDrive.
07-27-2016, 09:21 PM | #6 | |
Rep 2,010
07-27-2016, 09:49 PM | #7 | |
Rep 8,942
07-28-2016, 05:36 AM | #8 |
Rep 596
Most of the hesitation will be down to the turbo. But also other things like being caught in the wrong gear. If you down shift manually before getting on it, it will help. I find kick down actually increases the lag a little and can be a bit ott with a multiple gear downshift. The only way to eliminate lag is to keep revs nearer 3k so the turbo is spooled. The N55 uses vanos and valvetronic instead of a throttle to try and increase responsiveness. Its a lot less laggy than other turbo motors because of this. i find it to be quite NA feeling most of the time tbh. The only numb spot is on occasion just off idle, but you just need to adapt your driving style to counteract this.
07-28-2016, 08:16 AM | #9 | |
Rep 1,797
Manual gearbox 235's?
Previous Rides: 535xi, M235xi, X3, E92 M3, E70 X5 35d, X6 50i, X6 35i, E60 550i, E46 M3 Cabriolet, E39 540i, E36 328i
07-28-2016, 10:27 AM | #10 | |
Rep 227
Only way to drive it super smooth was to anticipate, which became natural after driving it for awhile.
Current
07-28-2016, 10:45 AM | #12 |
Rep 2,248
It ain't the turbo, folks. It is the transmission. There is no half-second or one-second turbo lag. That said, moving the AT lever left to "S" mode, if you are driving in comfort or Eco, will make this delayed downshift problem go away.
07-28-2016, 11:09 AM | #13 | |
Rep 2,010
http://autoweek.com/article/car-revi...e-review-notes Read the 9th paragraph: http://www.autoguide.com/manufacture...ideo-3699.html So yes, there is a bit of turbo lag, just off idle. No big deal, but it is there. And as I mentioned previously, easy to anticipate.
07-28-2016, 11:10 AM | #14 |
Rep 447
I had this issue with my old 2012 X3 with the same N55 engine. I could be in sport mode with shifter to the left and if I slowed down a bit going say 50 down to 30 and then tried to change lanes and go, there was almost a dangerous delay in acceleration. You would just be in the other lane and nothing for 1/2 second.
This for the most part has gone away with the 235i, but it's still there from time to time more so during rolling stop situations. I had no issues with the N54 135i, so I don't know if it's the new 8 speed, the xdrive, or the N55 single turbo vs. the N54 twin turbo. My guess is it's the tranny or xdrive. Good news is the S3 and GLA45 amgs are loads worse, so at least we've got that going for us, whish is nice.
07-28-2016, 02:29 PM | #15 | |
Rep 15
07-28-2016, 02:37 PM | #16 |
Rep 15
07-28-2016, 02:56 PM | #17 | |
Rep 2,248
07-28-2016, 07:24 PM | #18 | ||
Kingslayer
411
Rep 1,479
07-28-2016, 08:59 PM | #19 |
Rep 2,010
My solution: drive it in the Sport mode!
amw896582.50 |
07-29-2016, 07:26 AM | #20 |
Rep 818
BMW335iOn18s259.00 |
07-29-2016, 07:38 AM | #21 | |
Rep 669
Turbo lag is more of a kick in the pants after the car has reached optimal RPMS. The problem is that the car is completely unresponsive. Happens to me all the time and has put me in tight spots. You cant predict this behavior, as it is not consistent. Ive run with the DTC off (or on, idk, one push) lately and it has mostly solved the lack of responsiveness. Seems the car is trying to adjust to give you and your passengers a smooth ride by smoothing out inputs. Sometimes, when you are in an intersection and need to move out of the way, you dont want smooth inputs. Ive run with DTC off during snow storms too and the car behaves more like I want it too. |
Tags |
auto, m235i, throttle response, xdrive |
