05-15-2016, 06:19 PM | #1 |
Rep 86
Dinan Spring and Camber Plate Install
After much research, I decided to go with Dinan Springs and Camber Plate. I did the install last weekend and got it aligned on Monday. Thanks, in particular, to 335sRus and RWalker for the advice on this project. I thought I would add a few details on how I did this, which might save folks a bit of time in the future.
For the rears, I follow the instruction that 335sRus referenced: http://f30.bimmerpost.com/forums/att...3&d=1401934841 That all worked out pretty well. This guide led me astray on the fronts. Thankfully, I found the guidance of snodgrass23 in another thread. He threaded the springs in and out of the top of the strut tower…much easier: http://www.2addicts.com/forums/showpost.php?p=16818777&postcount=12 Also, perhaps worth mentioning a few of the tools I purchased from Amazon for the job: 16mm Spark Plug Socket ($4.99) – for removal of rear shock top mount and removal of front push rod http://www.amazon.com/Sunex-884504-8.../dp/B0074HNKI6 Spark Plug Socket Set ($11.07) – 18mm for removing OEM strut bearing nut, 3/4” (19mm) for installing Dinan strut bearing nut, reportedly the 5/8” socket might have worked in place of the 16mm socket: http://www.amazon.com/Powerbuilt-640.../dp/B004QO9F0W Extra Long Hex Bit Socket Set ($14.99) – for use with the spark plug sockets for removing the shock / strut support nuts. The first set I got was too long and they flexed too much in torsion. These are just the right length: http://www.amazon.com/Neiko%C2%AE-10.../dp/B000IQNMQU Strut Compressors ($37.99) – These worked well enough and were compact enough to work with inside the strut tower. It was a tight squeeze, resulting in some bruises on my arms: http://www.amazon.com/ABN-MacPherson.../dp/B00SX5RSA4 Overall, less than $100 in tools and about 10 hours of satisfying, mostly frustration-free work saved me over a grand in labor. I kind of agree with 335sRus on difficulty of 4/10 or maybe 5/10. I’m pretty comfortable with tools. I don't do much wrenching on cars, but I used to do a bit on my motorcycles. I went with the following compromise street / track alignment: Front Camber -2.5 degrees Front Toe in 1/16” total (1/32” each) Rear Camber -2.0 degrees Rear Toe In 1/8” total (1/16” each) Attached are before and after alignments. I’ll get to see how it does next weekend at the track. |
05-15-2016, 06:27 PM | #2 |
Rep 86
And here are some pictures...
Personally, I like the look of 1/2" drop in the front a bit more than the 1” drop in the back. I’ve been driving it for a week and definitely like the way it feels. It is definitely less floaty in comfort mode at highway speeds. Hopefully it will feel a bit more planted at the track too. |
kern4174464.00 |
05-15-2016, 06:31 PM | #3 |
Rep 86
Alas, the camber plates have the dreaded adjustable camber plate rattle, only noticeable at low speed over minor road imperfections that induce a slight suspension vibration / rattle. I went over the front suspension again. Nothing is loose. Hopefully it will not get worse...
But it definitely plants the front corner in turns. Looking forward to track day! Note, even at -2.5 degrees camber, there's still a fair bit of adjustment left in the camber plates. Perhaps this is because the drop is contributing a bit of camber as well. |
05-15-2016, 06:42 PM | #4 |
Rep 86
The car is definitely begging for wider wheels and tires. Like a few folks on this board, I’m going to try to do 255/35 square.
There’s obviously lots of clearance at the front fender now. But I’m really surprised how little clearance there is between the front wheel and strut, just 9 – 10 mm with the stock 18x7.5 ET45 wheels, measured by sliding an Allen wrench between the wheel rim and strut. (You can also see it looking through the wheel.) I really don’t understand how others have been able to use an 18x8.5 ET42 (inner rim 10mm closer to strut) without the rim hitting the strut. There seems to be no hope of running a 9" wheel, which would probably be a bit more appropriate for 255 tires. So, I’m leaning toward ordering a set of Forgestar F14 wheels in 18x8.5 ET48 along with a set of 12mm spacers for the front. This would have the following results: Front: Tire 6mm closer to strut, 24mm further out. With -2.5 deg I think I have plenty of room to fender. Rear: Tire 1mm closer to shock, 9mm further out. Seems similar to what others are doing with rear spacers. Of course there's a gigantic amount of room on the inside. I would certainly appreciate feedback on this part of the plan. Though perhaps I should ask in wheels/tires... |
05-16-2016, 10:53 AM | #5 | ||
Rep 1,084
Glad to see you've got it sorted, and that the low speed clunking is not a figment of my imagination .
Looks really good, BTW. One thing you might try (that is helping me, I think) is to add a nylon washer between the strut shank shoulder and the spherical bearing. 12mm ID, 1mm thick. Press it over the bulge in the stud with a 1/2" closed-end wrench. This serves to lessen the impact transmitted from the upward moving strut to the spherical bearing. Quote:
I run street: 255/35r18 square MPSSs on 18x8.5et47 M441s with a 5mm spacer in front track: 255/35r18 square RE-71Rs on 18x8.5et45 ARC-8s with a 5mm spacer in front Quote:
square 255/35r18 Toyo Proxes R888s on 18x9et41 D-Force LTW5s with 5mm spacer in front The above setups have absolutely minimal clearance to the strut, and absolutely require camber plates to clear the fender.
05-16-2016, 02:28 PM | #6 | |
Rep 845
Also, That alignment looks good, but do you have a limited slip differential? I found that when I got camber plates and dialed in some front camber (before I got my diff), the car became very difficult to control at times due to the rear breaking traction before the front. This problem is greatly mitigated (read: resolved) with a locking diff.
05-16-2016, 09:20 PM | #7 | ||
Rep 86
Thanks again for all the help. |
05-16-2016, 09:27 PM | #8 | ||
Rep 86
Back to the drawing board... Quote:
05-16-2016, 09:29 PM | #9 | ||
Rep 1,084
05-17-2016, 12:37 AM | #10 | |
Rep 1,503
FBO M235i r
F80 M3 |
05-24-2016, 06:04 PM | #11 |
Rep 18
Dinan Camber Plates Installed
Pursuant to my quest for camber, I made a decision and ordered and installed the Dinan camber plates. I simply could not wait until July for Vorshlag. I may end up getting their plates, but for the time being, I needed something. I tried to find a nylon washer, but couldn't find them, so the plates were installed without. I'll learn to live with the potential noise, I guess.
For autocross, I am using a square setup with APEX ARC-8. 18x8.5 ET45 with 245/35/18 Hoosier A7. Stock springs/struts. Had to use a 12 mm spacer up front, as the inboard side of the Hoosier is only 3 mm from the strut. I am using a 5 mm spacer in the rear. I am also using the 75 mm APEX stud kit. Alignment specs are as follows: -2.5 camber front, 0 toe. -2.0 camber rear, 1/16 toe in each side. There still appears to be some wiggle room, I could probably get to -2.8 or 2.9 up front, if necessary. So far I haven't even driven on the Hoosiers, so I don't have any idea how they are. There is a local autocross on Sunday, then a Pro Solo two weeks later. I am scheduled to participate in both, will post results and commentary if anyone cares, lol. |
05-24-2016, 06:07 PM | #12 |
Rep 1,084
Sweet setup, sounds like those 245 Hoosiers run really wide, approximately 7mm wider than my 255/35r18 RE-71Rs...
05-25-2016, 07:28 AM | #13 | |
Rep 86
I took my car to the track (Texas World Speedway) last weekend. And the final result--exactly the same lap times. Hard to compare conditions. Also it was my first drives solo. The car definitely feels very different though. With the springs, the car rolls less through a couple of tight turn sequences. Also the car feels much more composed across a transition from the banked front straight into turn 1. I felt much more comfortable carrying speed into that transition. With regard to camber, the car is very clearly understeering less. It is definitely more willing to rotate in turns. I think I need to get more comfortable taking advantage of this to find the speed that it offers. Note I am still on stock tires. |
05-25-2016, 11:54 AM | #14 | |
Rep 98
Incidentally, I had the exact same noise when I tried plates from another manufacturer last fall. My comments here are not meant to talk down on anyone. This is a difficult problem to solve with an adjustable camber plate and I, for one, am glad that we have manufacturers working to get the community parts. |
05-25-2016, 12:21 PM | #15 | |
Rep 1,084
I think the washers may have helped initially and may have delayed onset, but they're not a real solution.
05-25-2016, 01:02 PM | #16 |
Rep 221
Just installed my camber plates this weekend and they have a significant rattle. I e-mailed Dinan, no response as of yet.
Thanks to several of you guys for sharing info on the board for this install. I wish I would have read a little bit closer. Getting the spreader tool would have been much better than trying to jam a screwdriver into the knuckle (strut connection to knuckle). http://www.amazon.com/gp/product/B00...A1UMBRA5ZTBCX8 It’s definitely worth investing in the socket to properly torque the nuts. I think rwalker previously posted this: https://www.ecstuning.com/Search/Sit...ket/ES2652174/ In the picture below you can see I used a crowfoot. Big PITA. To remove and put nuts back on (before torqueing) I used an air ratchet with pass through (bottom picture). I love this tool. It makes the job way faster and easier. http://www.summitracing.com/search/p...et-wrench-kits |
05-25-2016, 09:29 PM | #17 |
Rep 356
Drives: 2014 m235i
Glad my post helped you at least a little. I think maybe I had less trouble with the front since I had some experience taking the struts out on my e90 when I did the coilovers.
Looks great! |
05-26-2016, 08:47 AM | #18 | |
Rep 18
I have yet to really push the car, so maybe once there are serious stresses on the suspension, things might settle and shift. I'll know by the end of day Sunday, after I complete my first autocross with this setup. |
05-26-2016, 10:08 AM | #19 |
Rep 5,394
I just want a little more camber up front to improve feel and grip, but the options to do that right now have their issues. Adjustable camber plates rattle (all of them) and M3/M4 LCAs create a wonky wheel to wheelwell alignment issue. I'm holding out for someone to make strut mount tophat that has an offset inwards strut hole, creating a degree or so of extra camber. I don't want or need any camber adjustability in my street car. I just want a little extra front camber.
Adjustable camber plates are great for track cars, but they suck for street cars if you cherish NVH. |
05-26-2016, 03:26 PM | #20 |
Rep 1,084
The wheel placement issue has been addressed now:
http://www.2addicts.com/forums/showthread.php?t=1250352
05-26-2016, 06:13 PM | #21 |
Rep 957
I am suprised dinan would release something half baked. I have not seen there plates in person but looking at the photos the problem seems to be the same one most manufactures have, that bearing/bushing is not large enough.
I run the kmak plates and the bushing is huge. No noise what so ever. If you look at your stock plate it has a giant bushing pressed in between the metal. If you hear noise, its not normal, something is out of design spec and will unfortunately only get worse. |
05-26-2016, 07:31 PM | #22 | |
Rep 98
On your KMAC plates, I have a few questions for you: 1) Which ones do you have? 2) Do you have adaptive suspension on your car? The reason I ask is that I've seen KMAC camber plates for the F20 and F30 chassis on the Turner Motorsport web site, but they are listed as not compatible with the Adaptive M Suspension option code S2VFA. I haven't spoken to Turner about them yet, but with your experience, maybe it's time to make the call. 3) Where did you source them from? Thanks in advance for your help! John |
Tags |
alignment, camber, dinan, spring |
