2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Squealing sound when lightly pressing the brakes
      04-06-2016, 07:11 AM   #1
BentZero
BentZero's Avatar
Yesterday when I pulled into the lot at work I heard a squealing sound coming from my brakes. Kind of like the brake wear indicator sound. It only happened once though. This morning I heard it again when I was in a bit of traffic and again when I pulled into the lot.
The car isn't even a month old. :/ Anyway, is this covered? Should be, right?
Build thread
      04-06-2016, 08:09 AM   #2
aerostar
Drives: 25 G80
Squealing is normal when coming near a stop.
      04-06-2016, 08:16 AM   #3
jaboyd
Drives: 2015 M235i black/black
Try a the following to remove possible light glazing on rotors: drive on a road with no traffic, at 60mph aggressively apply brakes (but don't activate abs) to a speed of 20mph. Accelerate up to 60mph and do it again....repeated 3- 4 times. Your brakes will be quite warm so drive a few miles without stopping to allow them to cool off. This should remove any glaze on the pads/rotors. If you still have the issue check w/dealer.
      04-06-2016, 08:22 AM   #4
BentZero
BentZero's Avatar
After 1,500 miles you'd think that brakes would already be broken in though. :/ I'll give this a shot tonight. I have the perfect road to do it on near my house. Thanks.
Build thread
      04-06-2016, 08:23 AM   #5
BentZero
BentZero's Avatar
My wife's Merc had a similar issue. It ended up being some spring or something that's supposed to return the pad to the original position, but it was malfunctioning with low speed/light braking. Basically similar issue in my car. Also, it just started happening. Driving habits haven't changed. Doesn't seem normal to me.
Build thread
      04-06-2016, 09:13 AM   #6
BMWZ4
BMWZ4's Avatar
1950
I've had this on all 3 of my cars. Seemed to be temp related but anytime I mentioned to my service guy they lubed the brakes and the squeal disappeared.
      04-06-2016, 09:21 AM   #7
Viffermike
Viffermike's Avatar
Drives: '25 SSG/black G87 M2
My car has nearly 9K miles on it now, and it still squeals lightly at times -- even when the rotors are warmed. Based on other threads, it partially has something to do with the OEM pad compound.
Also, don't feel too bad about the squealing ... I had what I think was a small pebble lodged in between my rotor and the pad in the middle of Big Bend National Park a few weeks ago. It made a horrible screeching sound -- only going forward, not in reverse -- and I initially thought I had a serious problem in one of the Continental U.S.' most remote NPs. A hard application of the brakes at about 15mph dislodged the pebble ... and my butt unclenched.
--Helmets are for closers.--
<<Current: 'Emma' '25 SSG/black G87 M2. Gone (but not forgotten): 'Johnny Boy' '23 CR MINI JCW 2-door; 'Allie' '18 NBM Porsche 718 Cayman; 'The Blackened' '15 MG 228i M Sport ... many others, all modded ... >>
      04-06-2016, 09:22 AM   #8
Sportstick
Sportstick's Avatar
6327
Drives: '15 228i and '24 X3 sDrive30i
There is variation on this. Two years in, and never a squeal so far.....
2015 228i 6MT/Track Handling/Tech/Cold/Premium/Lighting/Driver Assistance/KCDesign Strut Brace/M2 LCA&Tension Strut w/Powerflex Bushings/Rogue SSK/17" BBS SR/ExtremeContact Sport02/ER Chargepipe/AA Intercooler/Dinan Shockware/MPerf Spoiler/Black Grilles/Xpel Ultimate PPF & Prime XR+ Tint/no CDV
2024 X3 sDrive30i/MSport/Premium/Dynamic Handling/Shadowline/Parking/Xpel Prime XR Plus
      04-06-2016, 09:28 AM   #9
Viffermike
Viffermike's Avatar
Interesting. I wonder if climate has something to do with it; humidity, etc ... I don't have the THP, so it could also be that -- though I'd imagine the M Sport fixed-caliper brakes likely have a slightly more aggressive compound than the standard floating calipers ... ?
      04-06-2016, 09:33 AM   #10
Sportstick
Sportstick's Avatar
6327
Climate may also be a function of my car spending every night in the garage. I do see some members appear to park outdoors. But, even on cold days at work, I have not heard a squeal after sitting all day. Squeal also can relate to the proper application of grease during the pad installation.
As far as aggressive pads, I am also surprised at the low level of dust on the MSport brakes.
      04-06-2016, 09:40 AM   #11
BarryJI
BarryJI's Avatar
Drives: 2015 BMW 228i M Sport
From what I've heard it's fairly commonplace.
2015 BMW 228i M Sport w/Track Handling Package
DAP | Lighting | Premium | Tech
DINANTRONICS Performance Tuner Stage 1 | DINAN Shockware | DINAN Free Flow Exhaust | DINAN Performance Spring Set + Ride Quality and Handling Kit
      04-06-2016, 09:46 AM   #12
Viffermike
Viffermike's Avatar
That's a great point. I park in a covered garage, but it's open to ambient outside air and not climate controlled. Hmmm ...
      04-06-2016, 10:09 AM   #13
BentZero
BentZero's Avatar
Man, the fact that it's common is disappointing then. I find it to be embarrassing. :/ I'm gonna call the dealer on the way to the gym and see what they say.
Build thread
      04-06-2016, 10:09 AM   #14
dc2112fan
dc2112fan's Avatar
Drives: 2014 BMW 228i VO
Mine is garage parked at home and work. I have brake squeal when I first get going nearly all the time with light pressure. Goes away once things warm up. I asked about it at one of my service appointments. They said it was normal for "high performance brakes".
      04-06-2016, 10:19 AM   #15
Sportstick
Sportstick's Avatar
6327
Maybe I can't do "light pressure"!
But, seriously, I've had squeal in other cars of this caliber, but not this one. I cannot explain it.
      04-06-2016, 10:38 AM   #16
BentZero
BentZero's Avatar
Well, dealer told me to bring it in Tuesday and they'll provide a loaner. Gotta use some of my time, but oh well.
      04-06-2016, 11:17 AM   #17
an4691
Drives: 2020 M2C in HS
Low? My wheels are literally covered in dust all the time. Within a few hours of cleaning them they're all dusty again.
      04-06-2016, 11:22 AM   #18
Sportstick
Sportstick's Avatar
6327
Hmmmm....between noise and dust, this is starting to seem as if there was a pad formulation change at some point in production.
      04-06-2016, 11:44 AM   #19
Mywifes335
Mywifes335's Avatar
Drives: 2014 FBO M235i
Honestly, if fewer people complained about brake noise and dust, our cars would be equipped with much better performing brakes.
Compared with pre-2011 vehicles, current non-M compounds are weak sauce.
Originally Posted by Axius View Post
Why the sad face, I fucking love sausage.
raleedy162.00
      04-06-2016, 12:18 PM   #20
BentZero
BentZero's Avatar
Crap......my wheels get dusty too which I can deal with. I can deal with noise too if it means better performance. I shouldn't have complained. I've failed us!!!
Build thread
      04-06-2016, 12:45 PM   #21
EternalVendetta
Drives: '16 M235i 6MT / '19 Model 3 SR
I hear this occasionally as well with my 2016 M235i. It's a minor annoyance, and thankfully it doesn't seem to happen often.
2016 M235i | Estoril Blue | Coral Red | 6MT
Tech | Cold Weather | Driver Assistance | HK
M Perf. Gear Shift Knob, Parking Brake, Pedals, Carbon Interior
M Perf. Black Grilles | CF Mirror Caps, Rear Spoiler, Rear Diffuser | Lightweight Front Lip Spoiler | M Perf. Exhaust
      04-07-2016, 12:07 PM   #22
bimmerfile
bimmerfile's Avatar
634
Drives: 2019 BMW X2 F39
My brakes only squeal when the temperature is below -2 Celsius (28F)..
2019 X2
