BMW 3-Series (E90 E92) Forum
Please help diagnose "rumble strip" vibration under acceleration! No noise
03-30-2016, 08:22 AM | #2 |
Rep 452
Don't remove the fuses you will have a very strange behavior because of all braking system error...just unplug the actuator motor of the transfer case...what you describe is most probably torque converter shudder.
03-30-2016, 08:54 AM | #3 |
Rep 545
Thank you! So do you think a proper fluid change with filter will solve the problem? It's only 37K miles, but car is 2007, it was sitting for 3 years in garage unfortunately without driving.
03-30-2016, 09:03 AM | #4 |
Rep 452
3 years without driving if it's mine i will do it for sure and add this to your fluid http://www.lubegard.com/~/C-230/Instant+Shudder+Fixx
03-30-2016, 09:05 AM | #5 | |
Rep 545
03-30-2016, 10:25 AM | #7 |
Rep 545
Another silly question - how to find out if I have a GM or ZF transmission? Any visible differences easy to check or just by VIN code? Thank you
P.S. I'm trying to order filter, gasket and fluid. |
03-30-2016, 12:04 PM | #8 | |
Rep 758
Drives: 2007 BMW 328xi Wagon
please look at my thread (specifically the SIB and flow-chart i posted)... seems to be a problem with the GM transmissions in our cars... I am going to do a transmission fluid change tonight, and see if my issue gets resolved. if not, i'll add the friction modifier to the fluid and see what happens. if that doesn't work, either a new torque converter or transmission. http://www.e90post.com/forums/showthread.php?t=1201992
2007 328xi Wagon, Black Sapphire Metallic, Sports Package, Cold Weather Package, Rear PDC, Airlift kit with 3P mgmt, CF Akrym rep lip, LCI M-Tech front bumper, LUX Angel Eyes, Black Kidneys, LED Interior Lights, M3 Steering Wheel with Extended Billet DCT Paddles, 19" Staggered VMR 710's
03-30-2016, 01:29 PM | #9 | |
Rep 545
P.S. did tech explained reasoning why not touch filter and gasket? Just curious. Thanks |
03-30-2016, 03:09 PM | #10 | |
Rep 758
i will certainly post on my thread the results of the fluid change, so check back there.
03-30-2016, 04:21 PM | #11 |
Rep 947
When my front passenger CV joint failed, I got vibration under load.
I pulled the xDrive/DSC fuse (20 or 26) and the vibration went away. The car drove normally, I just had no safety systems, no road speed, etc. I highly doubt changing fluid will help. Btw, do not cheap out on aftermarket axles. We put them in all the time and they always fail within miles..... The shafts themselves are normally ok, but the boots fail. |
03-30-2016, 04:33 PM | #12 | |
Rep 545
03-31-2016, 03:41 PM | #13 |
Rep 947
At first, it was only first few seconds of accelerating.
As it got worse, it would vibrate any time I was applying throttle until I reached cruising speeds. As soon as I added load, it would vibrate. It got to the point where I thought my car was going to fall apart. When I pulled the axle, the bearings just dropped to the floor. |
04-01-2016, 01:00 PM | #14 | |
Rep 296
Check your control arm bushings, i had a similar issue. Found out my lower control arms had no bushings at all 78k miles in.
04-01-2016, 01:28 PM | #15 |
Rep 947
04-09-2016, 06:25 AM | #16 |
Rep 4
Not sure if you got this fixed yet, but I had the same issue and turned out to be a bad oil cap which was causing air to mix in with the oil. Didn't happen all the time, but definitely made the car behave erratically.
That being said, my water pump just went as well, and leading up to the failure I noticed that throttle response in general seemed to be off for the last two weeks leading up to the car totally overheating and going into limp mode. |
02-28-2022, 04:10 PM | #18 |
Art Collector
2427
Rep 3,450
The way OP edited this post has got to be the stupidest thing I’ve seen here in a while. (I know it’s from 2016.)
How the hell someone could think that removing your description of the issue you’ve since solved and replacing it with SOLVED does anything for posterity is beyond me. I’m sure it wasn’t done with ill intent, but LOL…
When I'm dead, just throw me in the trash.
