BMW 3-Series (E90 E92) Forum
jb4 backend users
03-21-2016, 09:55 PM | #1 |
Rep 111
jb4 backend users
ok guys what is the best most aggresive map to run on the jb4 with backendflash.
currently i am on the e85 flash, but what map do you guys recommend to run to get the most power of my 335i i currently run it on map 2. I've tried map 7 but it always throws me into map 4 the safe mode map. mods: inlets, dci, cp with bov, stage 2 fuel it pump, bmw performance exhaust running e85 with e60 |
03-23-2016, 08:36 AM | #3 | |
Rep 111
03-23-2016, 01:04 PM | #6 |
BimmerPost Supporting Vendor
24348
Rep 191,145
assuming your map's fuel scalar matches the E85 mix your are running, Fastest solution is map 5
If you want more power you need to check your logs and get a tuner to a custom map for you
03-23-2016, 08:10 PM | #7 |
Rep 1,023
IIRC the stock TMAP sensor only reads to 20psi, so if you hit 20 you may be hitting your boost safe and thereby tripping to map 4. I'm not sure how the system responds when you may temporarily make over 20psi with the stock TMAP.
I would recommend contacting Terry @ BMS or others over at n54tech where the discussion is more focused on this stuff. And probably get the 3.5bar TMAP sensor.
2001 e36/7 M Roadster 5spd
2008 e90 335i 6spd 2011 e90 335xi 6spd 2011 e70 x5 diesel 2010 Ducati Monster 696 |
