03-21-2016, 01:14 AM | #1 |
Rep 40
Drives: Alpine white, Coral red M235i
N55 HPFP Upgrade
Gents,
Is there in anyway a possibility to upgrade the M235i N55 HPFP with lets say an M3 HPFP or an aftermarket one?? That will solve a huge number of problems Looking forward for your thoughts
2014 M235i AW 8AT,
ER: FMIC & DP & CP , BMS: JB4 EWG(OBDII) |
03-21-2016, 11:39 AM | #2 |
Rep 986
Please list these problems and elaborate on the HPFP.
Only LPFP is available , stage 2 unit by Fuel It. http://www.fuel-it.biz/f-series-stag...grade-options/ E85 compatible |
03-22-2016, 05:34 AM | #3 | |
Rep 40
1. I have access only to 91oct fuel so upgrading the LPFP would not make sense as I understand from some research I've been doing. 2. when going for a higher boost level your aim is to prevent the car from having a lean AFR either by increasing fuel octane or volume. here is where the M3 HPFP swap/upgrade stock one comes in handy. Because from what I gathered the HPFP is limiting factor for a guy like me with limited fueling options and I guess most of you would like the convenience of achieving good Whp numbers with crappy fuel like 91 oct
2014 M235i AW 8AT,
03-22-2016, 11:07 AM | #4 | |
Rep 1,084
When HPFP capacity is exceeded, the result is stumbles and misfires at high RPM. Until I can figure out a better solution, I'm running an upgraded LPFP and a low-volume TBI setup from Fuel-It, with integrated control from a custom firmware JB4 and FSB (fail-safe box). My next step up will likely be JB4 integrated PI, but I'm also trying to find out if the S55 HPFP setup (dual pumps) can be retrofitted to the N55. You can find more details on my setup in the forum dedicated to the JB4, in the N55 section. |
03-23-2016, 07:27 AM | #5 | |
Rep 40
2014 M235i AW 8AT,
03-23-2016, 09:17 AM | #6 |
Rep 1,084
I've already discovered that a swap with new parts will cost more than the PI setups currently on offer... :-( I'm looking into salvage sourcing now.
03-23-2016, 03:03 PM | #7 | |
Rep 415
Hey man has the FSB and jb4 integration help solve all the issues you were getting with daily driving? I spoke to you briefly in your thread on another forum. Can you feel the transition from when TBI isn't activated to when it is activated or is it nice and smooth? Also I presume you can control when TBI is on and off via the jb4 app and meth user settings? Cheers |
03-23-2016, 03:47 PM | #8 | |
Rep 1,084
Yes: I can feel the transition, but it's very smooth. Yes: I can control when TBI is on or off with the single "meth trigger mode" user setting in the interface. The other forum has full details about my progress, probably best to continue that thread for posterity's sake. |
03-23-2016, 06:05 PM | #9 | |
Rep 415
I'll keep an eye on the other forum thread and add to it when I get round to getting TBI and the LPFP on oem turbo. |
03-23-2016, 06:20 PM | #10 |
Rep 1,084
Ah, yes: those have been addressed with the custom firmware that allows me to very strictly limit when TBI fires.
03-24-2016, 05:23 AM | #11 | |
Rep 40
but salvage sourcing the pump would be a great way to do it especially if there is a simple way to install the thing in an N55. can't wait for an update
2014 M235i AW 8AT,
03-24-2016, 05:55 AM | #12 |
Rep 40
here is something interesting I found about the S55 HPFP control scheme in boost addicts site:
boost addicts/showthread.php?68823-S55-N54-HPFP what I understood is that it is similar to an N55 engine up to 3000rpm then the second piston pump starts to cover the extra fueling needed for the M3/M4 engine to achieve its power. also the difference between N55 & S55 HPFP is one is single piston the other is double piston pump. I hope someone who is more experienced in bmw engines can help us out here on the possibility of installing it in our N55
2014 M235i AW 8AT,
03-24-2016, 05:32 PM | #13 |
Rep 1,084
That's a great thread. Thanks for the heads up. Unfortunately, I think I'll have to give up on the S55 HPFP option: we don't have ECU control for the 2nd HPFP...
03-25-2016, 10:58 AM | #14 |
Rep 1,931
http://www.dinancars.com/product/r42...?series=&mid=/
R420-0002 With increased power comes increased demand on the fueling system to satiate that demand. The modified Dinan® fuel pump allows the car to meet all the fueling demands under any conditions that may be faced when running at higher output under heavy engine load. Give Dinan a call... It is a race only part at this time...
www.nybmwcca.org
03-25-2016, 11:36 AM | #15 | |
Rep 1,084
04-03-2016, 05:53 AM | #16 | |
Rep 40
2014 M235i AW 8AT,
04-04-2016, 07:30 PM | #17 |
Rep 3,068
S55 uses two high pressure pumps located on the vacuum pump. Replacing n55 high pressure pump with single s55 will not result in higher flow, possibly reduce.
06-09-2016, 02:20 PM | #18 |
Rep 202
06-09-2016, 02:29 PM | #19 |
Rep 1,084
it's a modified LPFP, not HPFP
06-10-2016, 10:58 PM | #20 |
Rep 2,368
And as far as lpfp fuel it makes a cheaper option that I've heard good reviews on.
Follow my builds:
06-11-2016, 08:27 PM | #21 | |
Gettin It Figured Out
1821
Rep 2,669
out of curiosity...., where did you hear these good reviews? .
06-12-2016, 09:21 AM | #22 |
Rep 2,368
Nowhere specific but over my past few years with BMW's I've just always heard good about Fuel-It.
Follow my builds:
