02-01-2016, 01:23 AM | #1 |
Rep 23
Upgrade Options
Dear all,
Good day to you all. I would like to upgrade for my M235i. 676 HIFI LOUDSPEAKER SYSTEM This is what I found doing VIN decoder. I found alpine hifi upgrade and Focal IFBMW-S. Which one is better to go for? Thank you. Best wishes |
02-01-2016, 04:57 AM | #2 |
Rep 70
Focal IFBMW-S is better for two reasons :
1)you have Hifi 676 and your car has'nt base sound Notice Alpine hi-fi system retrofit kit : Retrofit kit number 65 41 2 293 994 These installation instructions do not apply to cars with the SA 674/SA 688 (Harman Kardon surround sound system) or the SA 676 (Hi-fi speaker system). You already have an amp in the trunk so you only have to change speakers. 2) don't know why, this kit does'nt appear in realoem for 235i With focal or any other kit, you need to change Emblem Alpine F2X 65132230426 (1 kit for left and right) Corner moulding, interior right 51332349058 Corner moulding, interior left 51332349059 (Before applying Emblem Alpine) and these fits very well and are cheaper than harman kardon because HK already went with tweeters inside. the diy is easy : my french tuto : http://bmw-one.com/phpbb3/viewtopic.php?f=21&t=34196 i don't use Focal but ETON B100W (german speakers) http://www.extremeaudio.de/gb/eton-b...n-b-100-w.html see pics in my tuto, nothing to adapt, nothing to cut. |
02-01-2016, 06:27 AM | #3 |
Rep 23
Thanks for sharing this to me.
Then what about Focal vs HK? Which one do you think going to work well then? And, I found Bimmer Tech has Amp too. Recommend that upgrade? |
02-01-2016, 07:42 AM | #4 |
Rep 886
I have the BimmerTech amp, and like it. Still getting the sound tuned, but even out of the box it's an improvement over the harmon kardon system that came with my car.
DIY here: http://www.2addicts.com/forums/showthread.php?t=1218371
02-01-2016, 08:25 AM | #6 |
Rep 70
Not the same magnets and weight. Try to search pics and i think Focal is better
Don't know for you but in France Focal is cheaper and better sound so updating a car with new HK speakers is'nt a goo idea. Their amp is a Match PP82DSP with some mods and is adapted for HK option. You need to ask Bimmer Tech for compatibility with a car with Hifi For me it's a good but expensive idea but you can't trust Bimmer Tech for adjustments : you don't use same speakers and Bimmertech use F30 adjustment. F30 is a bigger car and had more speakers than F22. If you get one, you need to ajust yourself the amp with your car with a PC and a Microphon. Not so difficult, software and manuals are free at http://www.audiotec-fischer.de/lng/e...sp.html?type=N As i have old subs and amp from my older bimmer, i choose his little brother : PP52dsp (now it's 62) but my F22 had european base sound system. tuning with USB connection |
02-01-2016, 08:34 AM | #7 |
Rep 23
Thanks grave.
I did find out their website and has an option for 676 which should be for hi-fi system. And, you are right, Bimmer tech isn't cheap! Or it's pretty damn expensive I'm thinking to get maybe a Focal ifbmws, which is easier to get in Taiwan, and a HK amp upgrade or Bimmer tech maybe? Tune with USB, is that mean after I installed, i can use the sub port in car? Or I need to pull the amp out again and do the tune. Thanks in advance. |
02-01-2016, 09:20 AM | #8 |
Rep 886
You do the tune via a USB cable that you leave connected to the amp with the other end accessible in either the cabin or battery compartment.
02-01-2016, 09:22 AM | #9 | ||
Rep 886
02-01-2016, 12:01 PM | #10 | |
Rep 70
dist is 0 for right door and sub and 51 cm for left door I think they put the car on it's roof |
02-01-2016, 12:12 PM | #11 |
Rep 886
I have grab my laptop and look on mine. You're using a different version of the software, and you've got more channels showing than there were when I opened the file. The file as sent to me had 6 channels total, not 8, and I do remember that Channel F is the sub channel on the software version I'm using (2.93?), not G.
02-01-2016, 01:33 PM | #12 |
Rep 70
you grab DSP PC-Tool Version 2 and 2.93 is the last one but very old
try DSP PC-Tool Version 3 and 3.28d : Release date: 15.12.2015 http://www.audiotec-fischer.de/cms/l...c-tool-v3.html you also need Audiotec Fischers Sound Tuning Magazine - DSP Special Vol.1 Audiotec Fischers Sound Tuning Magazine - DSP Special Vol.2 Very instructive and i think easy to read for you. a bit more difficult for french men with their poor english |
02-01-2016, 03:09 PM | #13 | |
Rep 886
Already have them and have read them, but thanks!
02-01-2016, 09:22 PM | #14 |
Rep 832
He has an F22 with HIFI. We Already have a tune for it. The one that we don't have is for vehicles with HK which i was finally was able to locate one locally to create a tune. I have an tuning scheduled for the 14th of this month.
02-02-2016, 04:42 AM | #15 | |
Rep 886
And don't get me wrong. Even with the F30 tune, the amp was a great improvement over the stock hk setup. Once there's a specific tune for it, I expect it to improve even more.
02-02-2016, 05:03 AM | #16 | ||
Rep 886
Current: 2014 F22 M235i Mineral Grey
Previous: 2011 E82 DCT 135i Space Grey Build thread: http://www.2addicts.com/forums/showthread.php?t=1149793 |
02-02-2016, 06:19 AM | #17 | |
Rep 886
That's because you're below the equator, right?
02-02-2016, 09:11 AM | #18 | |
Rep 832
Trust me it will. As soon as it done i will email it to you and post it here. |
02-02-2016, 10:09 AM | #19 | |
Rep 300
