01-22-2021, 04:51 AM | #3719 | |
Rep 348
To note though, when I came to pickup my car they informed me that they didn't install the rear bump stops, only the fronts as "the rear struts didn't need to come out." They said it shouldn't effect anything and everything felt super solid so I haven't worried about it. I woulda rather had them in but whatever. Edit** Their initial quote of $250 was for springs install without rear shock removal. I didn't mention the bumpstops when making the appointment as I didn't think it would require extra steps, so that's my bad, but I went back and they installed the Dinan rear bumpstops on the house and helped with a headlight leveling issue I was having. Would recommend
01-22-2021, 09:30 AM | #3720 | |
3690
Rep 3,615
01-22-2021, 10:26 AM | #3721 |
Rep 208
Ordered oil thermostat housing, gasket, screws and o-rings from N55 for my N20 "oil heat exchanger" to "oil cooler" conversion.
Quaife LSD | BC Racing Coilovers | H&R ARB | F8x LCA+TS | Wiechers Strutbar | Mishimoto CAI | Mishimoto Oil Cooler | Mishimoto Oil Catch Can | Mishimoto FMIC | VRSF DP | Masata TIC | Masata CP | DV+ | Custom Kline Exhaust | GTS Style Roll Cage | Sparco Evo QRT | Brey-Krause seat mounts | Schroth Profi 2 ASM 6p | 10" Android HU| xHP Stage3 | BM3 | RaceCapture Data Logger
01-22-2021, 12:26 PM | #3722 | |
Rep 148
Southwest Bimmers wanted $900 with alignment Eurotek wanted $1100+ with alignment BMW Only also wanted somewhere around $1100+ with alignment Southern California probably has the most tuners. European Auto Source in Anaheim, CA quoted me around $450 without an alignment. I'm seriously considering kianf22's recommendation since it is half of what EAS quoted me. Last edited by Finn Germai-Yaz; 01-22-2021 at 06:26 PM.. |
kianf2264.00 |
01-26-2021, 06:19 PM | #3724 |
Rep 536
Finally had a warm enough day for a top down drive in the country today. First one of the new year and I even managed to get out on both BMW bikes as well.
01-26-2021, 06:33 PM | #3725 |
Rep 170
First major mod ;)
Had a drop of coffee have a near slam dunk into the USB port. Problem solved!
(P.S. Don't worry about loosing them. Had to order 50!) |
01-26-2021, 10:28 PM | #3726 |
Rep 776
Aren't these ports waterproof?
M240i | Mineral White | Coral Red
01-27-2021, 05:14 AM | #3727 |
Rep 170
Eh. Who knows. But coffee, soda, etc could still mess with the contacts inside. No easy way to clean. I won't use it often, but if I do, I'd like it to work.
01-30-2021, 06:30 PM | #3728 |
Rep 3
2016 bmw 228i m
hey guys, going to a shop in a week to install a few mods any ideas on expected #'s for the 1/4 mile and or power gains?
installing: BM3 Stage 2 flash VRSF Catless Downpipe VRSF HD Intercooler Upgrade VRSF Chargepipe Upgrade Intake upgrade my best run was 14.2 fully stock |
01-30-2021, 11:14 PM | #3729 |
Rep 65
I got quoted $750 from Performance Technic in Fremont, CA. They look like a very professional and high end BMW shop. The quote was for DINAN springs + bumps stops + alignment. Will be setting up an appointment sometime next week.
01-31-2021, 03:56 PM | #3731 |
Rep 101
I added a microfiber steering wheel cover. Hand sanitizer will ruin leather very quickly. My kid's X1 wheel is destroyed by it. My 228ixCV has a cover and although it doesn't feel great it will be on for the duration.
neverlost99
01-31-2021, 05:44 PM | #3732 | |
Rep 218
(some might, but I wouldn’t in this case) |
01-31-2021, 06:39 PM | #3733 |
Rep 120
That is a very good price. You might want to give Simon and Orhan a call at European Werkstatt in Walnut Creek, those guys do amazing work for fair prices. They took care of all my BMW needs when I used to live in the Bay area.
imperialgrunt47.00 |
02-01-2021, 02:28 PM | #3734 |
Southern Fried
139
Rep 140
Had a run-in with a brief but damaging hailstorm last week while driving on the interstate. The entire event was over in about 7 minutes, but the damage was done. I found about 6 spots on my hood, 6 or 7 on the roof, and a couple on the rear deck. I found a local paintless dent repair shop and dropped by last week for an estimate. He used an LED light and I was shocked at how many dents actually showed up. Over a dozen on the hood, the same on the roof, back deck, fenders. He even showed me a couple of spots repaired before I bought my CPO.. spots that were rushed, to say the least. We negotiated a cash deal and I dropped it off this morning. I just got it back and WOW! I am very pleased with the results. He went over the whole car and also sorted out the previous stuff. It looks like new again, I can't find a bad spot anywhere on the car.
02-01-2021, 03:38 PM | #3735 |
Rep 140
Turbo blanket is now installed. Did it to lower the temps under the hood; might consider an intake down the line.
Received the LCI LED tail lights, LED reverse light bulbs, and white LED blinker bulbs. Might install them later today. |
02-01-2021, 04:17 PM | #3736 | ||
Rep 507
E46 -> E90 -> F30 -> F23
Jcoop901138.50 |
02-04-2021, 07:56 PM | #3737 |
Rep 348
Alignment at West End
BM235iW97.00 |
02-08-2021, 11:14 AM | #3739 |
Rep 322
Changed the diff oil before the day's track activities. The diff whine got quieter, but still louder than the engine.
