2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum lock doors while engine on
      12-11-2015, 10:24 AM   #1
Cjnj
Drives: 2016 228i xdrive
Is it possible to start engine, take fob, lock with fob (warm up in winter with door locked)
      12-11-2015, 11:16 AM   #2
nike001
Drives: 2018 718 Cayman
Idling is bad & your car will warm up faster if you drive it.
Get in the car, let it warm up ~30 seconds (enough time to select heated seats, put on seatbelt, & pick your music choice) and go.
      12-11-2015, 11:33 AM   #3
AlpsRider
AlpsRider's Avatar
2888
Drives: M2 Competition, LBB, 6MT
True. Just make sure the oil is pumped through the engine for at least 20 or 30 seconds depending on the outside temperature and you drive it very easy for the first minutes until the oil warms up. I've read that the majority of the wear on engine parts happens when it is first started up and cold.
      12-11-2015, 12:27 PM   #4
Cjnj
Exactly. I'm also not talking about long amounts of time
      12-11-2015, 12:58 PM   #5
skeeedunt
Drives: 2016 M235i
I know this works with comfort access, I can touch to lock and leave it running for a sec while I run to close the door or whatever (bringing the fob with me). Haven't tried actually locking with the fob though.
      12-11-2015, 01:28 PM   #6
Cjnj
Mines on order (no comfort access) so I would be good to know if it did
      12-12-2015, 08:49 AM   #7
Pinghacker
Drives: 228i
I do this and it works fine. I do not know why idling would be bad. Leave it running for 5 minutes with the rear defroster, front defrosters and seat / steering wheel heater on while you pack your lunch. I don't have comfort access either.
      12-12-2015, 09:17 AM   #8
midwest 340xi 6sp
midwest 340xi 6sp's Avatar
Drives: 2018 340xi
I think technically one could make the case not to do it.
IMHO if you generally take care of your vehicle, letting it warm-up a few minutes before you get in, is not going to appreciably reduce the lifetime of your car
Previous Rides: 535xi, M235xi, X3, E92 M3, E70 X5 35d, X6 50i, X6 35i, E60 550i, E46 M3 Cabriolet, E39 540i, E36 328i
      12-12-2015, 09:26 AM   #9
Tpeterson
Tpeterson's Avatar
Drives: 228i MSport/THP/MT/
Unnecessary use of gas and extra tailpipe emissions.
      12-13-2015, 10:43 PM   #10
2Banger
M POSTER
Australia
151
Drives: 2er
I always let my car warm up like that at night, i thought it was a good thing?
Also i have comfort access, i use the remote and it doesn't lock?
Should i be using the doors comfort access to lock it? I never tried i've always wanted to let it idle and lock and come back out but it would never do it by the remote.
      12-14-2015, 07:05 AM   #11
nike001
Idling basically isn't good for anything. From spark plugs to exhaust outlets to oil circulation then then to tailpipe emissions.
Guys. It's easy. I mean I'm not sure how it works in AUS but it works for every car I've tried it with, comfort access or not.
Get out of the running car with the key. Close the door and hit the lock button on the key fob. The car should stay running and you should be able to quickly run into the gas station or wherever you're going. I just did it on Saturday to run in to a restaurant to get lunch.
      12-14-2015, 07:41 AM   #12
Cjnj
Possible that this is disabled in certain countries? For example I'm in Canada and my current car (gti) won't. Lock
      12-14-2015, 09:22 AM   #13
2Banger
M POSTER
Australia
151
Drives: 2er
Possibly correct, I tried it and it didn't work...
Really wish it did
      12-14-2015, 11:21 AM   #14
Pinghacker
Drives: 228i
If I cared about unnecessary extra gas and emissions I would have bought a Honda Civic. This car has a completely unnecessary sport mode that wastes gas and adds to emissions. I tend to accelerate more than required to safely enter traffic and take the long way around to enjoy the drive at the peril of gas usage and our planet.
      12-26-2015, 09:56 AM   #15
R88
Anticipator
R88's Avatar
United Kingdom
14
Drives: F23 M235i
If you have ConnectedDrive you can also just start the heater/air con with your phone right?
      12-26-2015, 10:35 AM   #16
Pinghacker
Drives: 228i
All that does is circulate the air. The engine needs to run long enough to warm the coolant to do any defrosting or defogging.
