2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics Installing TechnicPnP Active Sound removal harness
      12-05-2015, 03:27 PM   #1
Zooks527
Did the installation of the TechnicPnP (TechnicPnP.com) ASD removal harness this morning. Went well.
My car is a 2015 M235xi with the harmon kardon audio package. One thing I've hated from the first test drive is the fake engine sounds piped into the cabin from the ASD system. I thought about coding it out, but didn't feel like investing the cost and learning curve into the software and a cable. TechnicPnP offers an almost-plug-and-play solution to the problem. For $65 delivered off the website, I figured it was worth a chance. Ordered it the week before last, and it showed up on the Monday after Thanksgiving. With a beautiful December day this morning, I took the opportunity to install it.
EDIT: There's another thread in the forum (http://www.2addicts.com/forums/showthread.php?t=1181343) that seems to be indicating that the ASD unit adds a noticeable hiss to the sound system. I did notice the hiss in my car before installing the harness, and I no longer notice it. I won't swear the harness was the reason the hiss is gone, just that I noticed it often before I put the harness and amp into my car, and no longer can find a sign of it. It appears that if ASD is the source of the hiss, coding it out will not solve the problem, as that leaves the module active.
The cable comes almost ready to install, but it is necessary to swap the locking connector on the cable with the one in the car. It's a trivial piece of work, and I assume it's because the BMW OEM style lock is not available.
The cable comes with the connecting pads slid into the lock connector but not clipped in.
The electrical connectors are easily slid out. This frees up the lock to be used on the car's harness, with the car's lock being slipped onto the two connectors to tie it down to the ASD module in the trunk.
The amplifier and ASD are in the left side of the trunk, behind the liner.
There are connectors in the trunk holding the inner liner to the body, one on a hook, one a straight pin connector, and one under the floor tiedown.
Biggest nuisance is removing the floor loop. The plastic cover is easily popped off, revealing a large Torx bolt underneath. Naturally, this is in an odd size that doesn't match any of my Torx keys. Fortunately, it is easily grabbed with a small ViceGrip, and once it's loosened a 1/4 turn, can be easily removed by hand.
The pin and hook connectors are easily removed by pulling the center section out and then removing the entire connector from the liner. Take care to not break the tabs and the connector can be reused at assembly.
One more pin connector remains, hidden behind the folding seat. Drop the driver's side rear seat to expose the connector, and remove it in the same manner as the others.
The back edge of the trunk at the latch now needs to be removed. Remove the four pin connectors from the cover plate, pull the trunk edge seal free, and remove the back plate.
Once the trunk edge plate has been removed and the trunk lip seal has been removed just past the edge of the trunk liner, the trunk liner can be moved away from the body of the car. Move it about 6" away from the body, reach behind, and unplug the back connector on the trunk power socket. Then move the liner out of the way.
The amplifier and ASD module are under the plastic liner support. Lift the liner support out of the way, allowing access to the module.
The ASD module stands vertically at the rear of the car. Press in the small grey tab and slide the black locking lever towards the top of the ASD unit, freeing up the ASD signal cable.
Using a small pick or awl, release the locking pins on each side of the ASD signal harness and slide the electrical connectors out of the locking connector.
Take the black connector that was removed from the purchased cable back in picture 2. Slide the electrical connectors on the harness in the car into the black locking connectors. Push them all the way into the lock until they click into place.
Now take the grey locking connector you removed from the harness in the car and slide the electrical connectors on the Technic cable into the lock connector as done in the previous step. Press the connectors into place until they click. The black lock will now be on the harness in the car, and the grey lock will be on the cable that you purchased.
Plug the black lock connector on the car harness into the black socket on the Technic cable. Swing the black locking lever upwards until it clicks over the locking tab.
Plug the grey lock connector on the Technic harness into the socket on the ASD module in the car. Swing the black locking lever downwards until it clicks over the locking tab.
Use a small zip tie to secure the harness to the frame of the car so that it doesn't shake back and forth to create a rattle behind the lining of your trunk.
That's it. Test the radio to make sure it works. If there's no sound, one of the connectors is not fully seated into its socket. Go back and reseat both.
Reassemble the trunk liner in the reverse order that you took it apart.
  • Place the support tray over the electronics.
  • Plug the power connector onto the back of the trunk power socket.
  • Slide the trunk liner back onto place.
  • Replace the 3 pin connectors and one screw connector that hold the liner in place.
  • Replace the trunk back panel cover at the back edge of the trunk over the trunk liner.
  • Replace the 4 pin connectors holding the trunk back panel.
  • Reseat the trunk lip edge seal onto the metal rim of the body and over the edges of the trunk liner and trunk back panel. This is an enormous pain in the neck to get into place properly. Work slowly and from the outer edges towards the center. Be prepared to swear mildly from time to time.
Total time was around an hour. Would have been much less if I didn't keep stopping to take pictures.
The results are really nice. The background drone is gone on the highway, and flipping to sport mode doesn't increase the level of noise in the cabin. Well worth the $65 and the time to put it in.
Couple of things to note on the exhaust sound. There's absolutely NO change in exhaust volume flipping between SPORT and COMFORT when you do this on a car with the stock exhaust. You can argue that the deceleration burble is more pronounced, but I don't think it is. Rather, because the engine is decelerating faster due to the more exponential throttle response, the frequency is higher, which makes it a bit more noticeable.
FWIW,
George
Appreciate 14
      12-05-2015, 03:43 PM   #2
Luminous
Luminous's Avatar
699
Drives: 2019 M5 Competition
My car is a 2015 M235xi with the harmon kardon audio package. One thing I've hated from the first test drive is the fake engine sounds piped into the cabin from the ASD system. I thought about having them coded out, but didn't feel like investing the time and learning curve into the software and a cable. TechnicPnP offers an almost-plug-and-play solution to the problem. For $65 delivered off the website, I figured it was worth a chance. Ordered it the week before last, and it showed up on the Monday after Thanksgiving. With a beautiful December day this moring, I took the opportunity to install it.
The cable is almost ready to install, but it is necessary to swap the locking connector on the cable with the one in the car. It's a trivial piece of work, and I assume it's becasue the BMW OEM style lock is not available.
Plug the grey lock connector on the Technic harness into the socket on the ASD module in the car. Swing the black locking lever upwards until it clicks over the locking tab.
That's it. Test the radio to make sure it works. If there's no sound, one of the connectors is not fully seated into it's socket. Go back and reseat both.
FWIW,
George
Great post, thanks for the detailed DIY!
2019 SG M5C
2015 SO M3 6MT
2015 BSM M235xi
      12-06-2015, 09:14 AM   #3
Viffermike
Viffermike's Avatar
Massive, zooks. Massive! Much appreciated. This is a great diy guide for amp swaps, too.
--Helmets are for closers.--
      12-06-2015, 11:11 AM   #4
simoneves
Drives: '16 228i DSB/THP/6MT
^^^ This
      12-06-2015, 04:13 PM   #5
kern44
Drives: '14 235i EB coupe, auto
Nice job Zooks
Thanks for this excellent post and helping out my next project
'14 M235i EB Coupe
'11 135i Convert DCT (traded)
'03 and '97 540iA Sport (retired)
'97 Vette Coupe 6 sp (sold) '74 Jensen Healey (MIA)
" No law about how long it takes to go the speed limit "
      12-06-2015, 08:19 PM   #6
Zooks527
I'm glad people like it. Yeah, it would seem to be useful for people who want to work on the amp.
      12-06-2015, 10:13 PM   #7
NEUE02
NEUE02's Avatar
257
What a great write up! Thanks for doing this. It will absolutely be my next mod!
The TechnicPnP website is down right now. As soon as I can get some contact info and a part number I will order the harness.
The Stable
      12-07-2015, 05:15 AM   #8
Zooks527
It's been down for a few months. Waiting for it to come back up is why I didn't do mine until recently. Eventually, I got tired of waiting, used the inquiry box, and did the order by email.
Use the contact form on the home page or on the contact page (http://technicpnp.com/contact.html) and he'll get back to you fairly quickly.
      12-07-2015, 10:57 AM   #9
NEUE02
NEUE02's Avatar
257
Thanks! Will do!
The Stable
      12-19-2015, 10:00 AM   #10
wjones14
wjones14's Avatar
515
Drives: 2021 M2C
Awesome, awesome thread! Best DIY guide anywhere for the ASD.
Just curious - there are other threads in other BMW forums about ASD, not 2 series specific, but in at least one of those, I thought there was a guy who simply disconnected the connector going into the ASD? Do you get a CEL if you do that in the 2 Series?
Here's one such tip for the M5:
http://www.autoevolution.com/news/ho...ity-81539.html
Previous: 2018 Camaro 2SS 1LE 6MT; 2015 BMW M235i 6MT; 2015 Mini Cooper F56 6MT; 2005 Mustang GT 5MT; 2003 Mini Cooper R50 5MT
      12-19-2015, 10:10 AM   #11
Zooks527
You can disconnect it, but in the 2-series, because we have the low-end audio systems (including hk), it takes the rest of the sound system out with it. It gives you a chance to see what it sounds like without ASD, but it's sadly not a long-term solution. If you want to accomplish that, you can do the same thing by just spending 30 seconds pulling the radio fuse.
You won't throw a CEL, but the dealer will get a system failure if they do an OBD read while the connection is undone. The harness above doesn't give any errors in any mode, as what it's doing is feeding a "give me no output" signal to the ASD module while leaving it in the sound system path. The ASD module remains online, and shows up as functional during an OBD scan.
      12-20-2015, 11:22 PM   #12
E36 Alumnus
Drives: white/black m235i
Brilliant Post!
Thanks for the details!
      12-21-2015, 01:11 AM   #13
Knightelf
Australia
79
2011 BMW 135i  [0.00]
Good write up, if only I had read this before my amp install. At least now I know that the "mini amp" is the ASD unit haha.
Difficulty wise, I would rank coding the same as installing the harness (I've installed an amp and also coded the ASD off). The cable was about $20 from eBay and it takes maybe an hour to watch the basic video guides and download the tools.
The torx screw size for the "loop" is T40 by the way. I had to go out and buy torx keys for it as I couldn't loosen it.
Current: 2014 F22 M235i Mineral Grey
Previous: 2011 E82 DCT 135i Space Grey
Build thread: http://www.2addicts.com/forums/showthread.php?t=1149793
      12-31-2015, 04:08 PM   #14
NEUE02
NEUE02's Avatar
257
I just did this today. The best mod ever! Thanks to the OP for your awesome DIY!
The Stable
      01-09-2016, 04:45 AM   #15
Legal Bill
Legal Bill's Avatar
54
Drives: 2006 330i
Hi George. I'm also in Mass. Thanks for this great write up. I just ordered my car, so if I don't like the ASD I'll be using this thread for sure.
      01-09-2016, 10:09 AM   #16
EEBreh
Drives: "M" 235i
Why not just code it out?
      01-09-2016, 11:22 AM   #17
m235hou
Drives: '19 X3 M40i
Just learned out to code, and that was the first thing I did.
Current: 2019 X3 M40i and 2018 330i
Previously: 2016 M235i Convertible and 2016 X4 28i and many non-BMWs
      01-09-2016, 03:36 PM   #18
Zooks527
Not everyone feels like making coding changes, nor does everyone feel like having to go back and redo the changes after the dealer updates the ECU.
      01-09-2016, 03:39 PM   #19
EEBreh
Drives: "M" 235i
Understandable, but it takes literally five minutes to code. Seems much more intensive to do it this way.
      01-09-2016, 08:32 PM   #20
Zooks527
Yeah, 5 minutes once you buy a cable, get the software, load it, learn the interface, get a token, and so on. If you have no interest in coding anything else, it's sure not just 5 minutes.
This is about 30 minutes all-in, including opening the package. There's also no footprint left in the ECU that you've done anything to the car, as the ASD module continues to answer diagnostic polls and all values remain at factory default.
Or, because plugging a harness in means you won't find yourself writing threads like these:
http://www.bimmerfest.com/forums/sho...t=after+coding
Appreciate 4
      01-11-2016, 04:50 PM   #21
Viffermike
Viffermike's Avatar
Yep. Altering the ECU of a car is quasi-legal. A recent Supreme Court ruling seems to allow it by consent of the owner, but the ruling is not very specific. Also, if you lease, do you own your car? Nope. If you finance, do you own your car? Not really ...
The harness is basically like using a USB cable with your phone: it's your property and it's completely removable, but it can still mess up your phone -- also your property. With coding, well, you mess up and you're on the hook for the mess -- which is the car. Personally, I'd rather have a dead phone (or a dead amp module) than a dead car ...
For some it's just not worth the risk. Don't trivialize coding just because you understand it. Some simply aren't willing to go that distance in that specific direction.
      02-27-2016, 09:00 PM   #22
Zooks527
And it now appears there may be another benefit to the harness over coding. See this thread concerning the hiss a number of people (myself included) have experienced. http://www.2addicts.com/forums/showthread.php?t=1181343
Search this Thread:
Copyright ©2000 - 2022, vBulletin Solutions Inc.
