2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Trunk won't open
      12-02-2015, 07:06 PM   #1
Saab Story
Saab Story's Avatar
572
Drives: m235i
Trunk won't open
Hoping someone will know a solution for this... I closed my trunk earlier when leaving work and now it won't open, either the shoulder strap on my bag got stuck in the latch or the mechanism broke.
The trunk is showing a warning light that it's open when driving on the dash and I made sure the valet lock wasn't on. I booked an appointment at he dealership for tomorrow but I have my work PC and house keys in the trunk so I need to get in it asap. Has Anyone dealt with this before?
      12-02-2015, 07:17 PM   #2
Lucky13
Lucky13
Drives: 2014 M235 manual, 2020 X3 30X
No but I did lock my car keys accidentally in the trunk and found out that you can't get into the car without another set of keys. Car was locked and threw my running fanny pack in the trunk after running, shut the trunk and the car door and trunk wouldn't open. If you had your rear seats down (I keep mine down) you could slide back there and pull on the yellow safety handle to open it from the inside.
1995 325i, 1996 328ci, 1997 528i, 1997 Z3 2.8, 2000 528i, 2001 X5 3.0, 2001 330i Convertible, 2002 M3 Convertible, 2003 M3 Coupe, 2004 M3 Coupe, 2004 Z4 3.0, 2004 X3 3.0, 2007 X3 3.0, 2007 335i Convertible, 2013 X1 28 sdrive, 2014 M235 manual, 2020 X3 30i Xdrive
      12-02-2015, 07:19 PM   #3
Saab Story
Saab Story's Avatar
572
Drives: m235i
Unfortunately my seats are up, I'm pretty sure the dealerships going to have to take apart the back seats
      12-02-2015, 07:40 PM   #4
Lucky13
Lucky13
I actually had it happen twice from a low battery and the valet lock in the glove box got flipped on somehow, both times in my 335 convertible. They may have a trick to get in without removing the seats by going thru the soft handle on the trunk from the outside.
      02-19-2017, 03:57 PM   #5
N54POWR
Drives: 2011 335is
2011 335is  [8.66]
What was the solution to your problem? I just experienced this on my girlfriends m235 convertible. I had some dog beds in the back and they must have got stuck. I can hear the latch triggering. It just doesn't open.
      02-20-2017, 09:16 AM   #6
Pparana
Drives: 2015 m235i
happened to me, I used a piece of 1/2 pvc with a 90 on the end to grab the emergency release in the trunk while someone pulled up.
      02-20-2017, 10:21 AM   #7
raleedy
Drives: 2016 228i 6-speed
Brute force should do it.
N54POWR52.00
ewohar21.50
      02-20-2017, 06:37 PM   #8
N54POWR
Drives: 2011 335is
2011 335is  [8.66]
Thank you! Yes! Brute force while repeatedly pressing the button freed the trunk. Much appreciated!
      02-20-2017, 10:19 PM   #9
Deutsche-Broke
Deutsche-Broke's Avatar
Drives: 2016 M235i
That's awesome..
Happened to me when installing a front / rear camera setup. The back seats were back up as I was almost done and I absentmindedly shut the trunk lid with the key fob in the trunk.
*shit*
Spent an hour fumbling around for another remote that didn't work, Probably because I reset the entire system during the wiring.. Still not sure about that...
And then another two hours fishing for the magic glowing pull handle.. Wasn't able to get it until a neighbor who is a Snap On tools dealer stepped in with a scope and we were able to unlatch it via infrared.
But it did take pressure from the pull and trunk lid at the same time.
Rapidly becoming a Snap On tools fan...
      02-21-2017, 08:00 AM   #10
Pparana
Drives: 2015 m235i
you need a bit of force on that emergency pull. Think of a sickle tool and that's what I made. I will probably add some cable, a pulley and put the pull under the seat. Besides, If I put someone in my trunk I want them in there. I illuminated the trunk with a small led flashlight.
