PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
BMW 3-Series (E90 E92) Forum
Wheel sizing or Shock issue?
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer |
10-01-2015, 09:02 AM | #1 |
Rep 99
Hey guys,
Having some serious rubbing issues. Im on Alufelgen CS7 19x8.5f (225/40/19), 19x9.5r (255/35/19). I think the offset is et35. Ive had my fenders rolled (could have not been done properly), and the car is on stock sport suspension. I am running 20mm spacers in the rear and 10mm in the front which could very well be my issue but wouldn't adding camber in the front/rear alleviate this? Or is the size of the spacer simply to large for this to work? Could it be that the shocks are worn so the car is sitting lower than normal? I rub even on relatively shallow dips with just myself in the car. I love the way it looks but the excessive rubbing is killing me. Any advice? -SP
// '07 / e90 / 335i / 6MT / BMS DCI / Cyba Scoops / JB4 G4 / CDV Delete / M3 upper + lower control arm upgrade / Alufelgen CS7 19x8.5F 19x9.5R /10mm F 20MM R spacers / 20% tint (windows + tails) / bavauto shift nob / matte kidney's // |
10-01-2015, 09:59 AM | #2 |
Rep 5,120
Your tires are too tall. 225/35/19 and 255/30/19 are the stock sizes. Have you tried taking off the spacer to see if that helps? Are you rubbing in the front or rear?
10-01-2015, 03:17 PM | #4 |
Rep 99
Ill double check the sidewall height when i get home. It did not rub without any spacers at all but Im hoping there is a way to make it work with the spacers. I want the wheels flush rather than tucked. I was wrong however about the rear tire specs. They are actually 265/30/19 Hankook v12 evo2. I thought hankooks werent on the wider end of the over state/under state spectrum.
10-01-2015, 03:18 PM | #5 |
Rep 99
The previous specs where on the 18 in 162's. Sorry lol.
