2Addicts | BMW 2-Series forum Classifieds Members Classifieds Electronics: Audio / Video / Phone / Alarm / Navigation / Radar Hi-FI AMP Harness
      08-30-2015, 11:46 AM   #1
CAF10
Drives: F10
Hi-FI AMP Harness
None
BMW HI-FI amp connector harness for upgrading to aftermarket amplifier. Please note this amp connector harness will only work with OEM 42-pin Hi-Fi AMP connector and will not work on vehicles equipped with Harmon Kardon (HK) sound system. It is designed for plug-n-play application without cutting or splicing factory wiring harness for installation of aftermarket amplifier(s). All wires are thin-walled automotive wire specification meeting or exceeding OEM wire size, 18 AWG for all signal and output wires and 12 AWG for subwoofer output wires. Signal wires are equipped with high quality gold plated metal male RCA connectors, not the cheap plastic one. All wires are crimped and soldered to ensure secure connection. Two different configurations are available for specific installation needs. The basic version comes with four channels signal output (FL, FR, RL, RR) and a remote wire. It is designed for those who just want the singal wires from the IDrive unit and run their own speaker wires for high power application. The deluxe configuration utilizes all existing OEM wirings for plug-n-play installation for full seven channels if desired, (Front left, Front Right, Center, Rear Left, Rear Right, Left Sub, and Right Sub). Both version can be configured with optional relay for multiple amps/dsp remote turn on application. All wires are labeled and come with connector pins assignment documentation. Please refer to ebay listing http://www.ebay.com/itm/161809291201 for ordering information.
      06-04-2016, 12:24 PM   #2
CAF10
Drives: F10
Underseat subwoofer connector harness is now available.
Ebay item no. 162092370709
      02-08-2018, 12:15 PM   #3
Spudnut1
Drives: 2008 135i
Subwoofer Connector
I noticed this post and was wondering if you still sell these connectors. My E82 has a bad subwoofer connector and for the life for me cant find a replacement. Any help would be appreciated!
Thanks,
Matt
