08-11-2015, 01:26 PM | #1 |
Rep 980
Tire sensor is exactly .5 psi out of whack
Yes, I know this is very OCD on my part but I have now verified that either one of my front tire pressure sensors is inaccurate by .5 psi over or the other is by .5 psi under. I am just wondering, do any of you know if this can easily be recalibrated electronically, or will it involve replacing a part, in which case I will -- reluctantly -- live with the error? Many thanks.
2015 BMW 228i M Sport w/Track Handling Package DAP | Lighting | Premium | Tech DINANTRONICS Performance Tuner Stage 1 | DINAN Shockware | DINAN Free Flow Exhaust | DINAN Performance Spring Set + Ride Quality and Handling Kit |
08-11-2015, 01:30 PM | #2 |
Rep 5,262
I suppose there is an +/- error for the sensors .5 is probably around 1% which is probably as designed..
0.5 won't make your car jump the curb... but 1.5 might so keep an eye http://f80.bimmerpost.com/forums/sho....php?t=1075458 |
08-11-2015, 03:01 PM | #3 | |
Rep 288
Air pressure gauges have several accuracy classifications, which might explain the variance. What is the classification of the gauge you used? Here's a link to a site that gives a basic explanation... http://www.getagauge.com/faq.cfm |
08-11-2015, 03:43 PM | #4 |
Rep 3,338
Everything in the world has a tolerance. I expect that is within their tolerance margin of error.
And yes, this would fall under the extreme OCD category.
Current: '20 X5, '18 M3 ZCP
08-11-2015, 04:28 PM | #5 | |
Rep 5,875
08-11-2015, 04:38 PM | #6 |
Rep 980
Same here. Glad I could have been of assistance.
I tested the pressures with two high-end digital gauges immediately after two all-round tire refills. In each case, rear pressures were identical, and accurate to the last tenth but there has always been a .5 psi discrepancy on the fronts. |
08-11-2015, 04:43 PM | #7 |
Rep 470
Isn't there a lot of variance depending on temperature?
Just last week I filled my tires to 33 front and 38 rear. Sometimes they will dip as low as 30/35, and are almost never identical / even.
2015 M235i | AW | 6MT | Tech | Heated Seat | Parking Assist | Fabspeed DP & Muffler Delete | Apex PS7s
1999 MX5 NB | Emerald Mica | 5MT | Sport Edition | Kosei K5Rs | Heated Rear Glass ig: @bee2ven |
08-11-2015, 04:47 PM | #8 | |
Rep 5,262
pressure should be 32F 38F cold.... hot will always be higher like 35F 41F or so |
08-11-2015, 04:49 PM | #10 |
Rep 470
Looks like I'll need to spare another couple of quarters lol
08-11-2015, 05:11 PM | #11 | |
Rep 288
AFAIK, there isn't any way to keep all the tires uniformly pressured... |
08-11-2015, 05:36 PM | #12 |
Rep 470
Do you even need to code for that?
Both temps and psi's show for me if I just hit vehicle status.
08-11-2015, 07:13 PM | #13 |
Rep 2,010
I don't think .5 lbs. error is anything to get wrapped around the axle about. Our world is full of tolerances. I think this one is acceptable.
And then there's possible differences in your tire temperatures...
2014 BMW M235i
2024 Mercedes Benz GLC300 Expert ultracrepidarian |
08-11-2015, 07:40 PM | #14 | |
Rep 288
08-11-2015, 07:44 PM | #15 |
Rep 5,262
08-11-2015, 07:52 PM | #16 |
Rep 96
08-11-2015, 08:01 PM | #17 | |
Rep 5,262
First I thought it was a 2015 thing as some guys with 2015 started saying that they had temp with no coding, but then there are 2015 with no temp... Not sure if its US or non-US related... http://www.2addicts.com/forums/showp...10&postcount=9 http://www.2addicts.com/forums/showp...0&postcount=11 Last edited by pikcachu; 08-11-2015 at 08:08 PM.. |
08-11-2015, 08:52 PM | #18 | ||
Rep 288
I personally coded the temperature to display. When it was delivered, all it displayed was PSI. Maybe that info will be helpful... |
08-11-2015, 09:43 PM | #20 | |
Rep 980
08-11-2015, 09:59 PM | #21 | |
Rep 823
08-12-2015, 05:31 AM | #22 | |
Rep 851
Hoc Lapidem Non Vi Sed Saepe Cadendo!
