The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > BMW Diesel particulate filter regeneration smell:
View Poll Results: BMW Diesel: Do you have a burnt smell around the engine during the regeneration?
Yes 15 39.47%
Maybe, I'm not sure. 4 10.53%
I dont know! 9 23.68%
No 10 26.32%
Voters: 38. You may not vote on this poll
Reply
      02-21-2008, 07:51 AM   #1
m.rk77
m.rk77's Avatar
24
Drives: BMW 335d
bmw particulate filter regeneration takes place every 300 to max 2000 km. It takes place when you drive at an average speed of 50 km/h for 20 minutes. Computer will take over and your vehicle will drive as in Sport mode. The particulate filter will heat up in order to burn everything that's stuck inside of it.
BMW diesel owners: Do you have a strong burnt smell when this particulate filter regenerates?
http://www.realoem.com/bmw/partgrp.d...43&hg=18&fg=10
http://www.bmw.com/com/en/insights/t...le_filter.html
      02-21-2008, 08:08 AM   #2
beemerbird
beemerbird's Avatar
England
172
Drives: Merc diesel
No smells noticed whatsoever in 6k now and I'd say I have quite a sensitive nose. I used to get alot of sulphur smells from my E90 330i coming into the cabin. I was puzzled as to why the filters didn't block the smell. Could yours be a combination of exhaust leakage/inefficient filters/DPF?
All I've noticed is as stated in part of the text posted by red-max in the other thread:
"The somewhat delayed response under acceleration, mainly at low engine speeds, results from the reduction of intake air by the throttle valve during regeneration, which does not need to open fully again until there is a significant increase in load. The maximum engine power output available remains available even during regeneration."
Hope you get this sorted.
      02-21-2008, 08:09 AM   #3
dxb335d
The Tarmac Terrorist
dxb335d's Avatar
England
949
Drives: 997.2 GT3
Mrk buddy your poll is flawed, how will people who say ''no'' even know its happened. So that one is not valid.
To be fair how will anyone really know when their car has been thru a regeneration without a BMW technician beign there to tell you ''its now happening''
997.2 GT3
      02-21-2008, 08:29 AM   #4
Dave_3
Dave_3's Avatar
Scotland
652
Drives: G22 M440D
It is actually in the Manual, Carl. Sigh.
So you obviously don't know the answer to your question. And if you were sensitive to the driving characteristics of your car you can feel it too.
I can sense it when it is operational. And you can notice a slightly sweet burnt caramely aroma if you are driving in traffic, come to a stop, wind blowing in the right direction with your window open.
It is exactly the same kind of effect as when your hot exhaust burns off mud or a plastic bag.
Never with the windows shut.
D.
Escort Mk1 RS2000 (2.1 2x44IDFS, BVH, Kent FR32, 5spd, 180 BHP) : M440D ¦ Previously : F32 435D : F32 430D M Sport sDrive, 335D E92 2006
      02-21-2008, 08:30 AM   #5
dxb335d
dxb335d's Avatar
England
949
Drives: 997.2 GT3
Love you to Dave. Also Dave does it say in the manual where in the exhaust system the DPF is situated?
997.2 GT3
      02-21-2008, 08:36 AM   #6
m.rk77
m.rk77's Avatar
24
Drives: BMW 335d
the DPF should be right around the turbos
      02-21-2008, 08:39 AM   #7
m.rk77
m.rk77's Avatar
24
Drives: BMW 335d
go here: http://www.realoem.com/bmw/partgrp.d...43&hg=01&fg=05
Select: Exhaust System
Exhaust System front
      02-21-2008, 10:24 AM   #8
red-max
red-max's Avatar
England
42
Drives: 520d M Sport
I voted "I don't know", since I have never noticed it. Anyone know if there's any indication in the cabin (on the multi-function display) to let you know the regeneration is happening?
I do quite a lot of fairly long runs, so perhaps I've never stopped and got out during one of these...?
2018 G30 520d M Sport with M Sport Plus - Mediterranean Blue
Previously: 2015 F32 430d M Sport, 2012 F10 520d M Sport, 2009 E92 320d M Sport, 2006 E92 335d, 2004 E60 530d, 2000 E39 525d, 1997 E39 523i
      02-21-2008, 10:28 AM   #9
creepy coupe
creepy coupe's Avatar
1867
Drives: BMW M340I G20
2015 BMW 435d  [0.00]
2009 335i  [0.00]
Whats sports mode, mines always in sports mode
      02-21-2008, 10:44 AM   #10
Dave_3
Dave_3's Avatar
Scotland
652
Drives: G22 M440D
That's probably right.
It feels the same way as when the air-con kicks on a moderatey powerful car. Subtle draw on the power. When you are cruising you might not notice.
Most of my trips are short and in the town - I would imagine that mine forces itself on sometimes
D.
      02-21-2008, 10:47 AM   #11
m.rk77
m.rk77's Avatar
24
Drives: BMW 335d
good info: http://en.wikipedia.org/wiki/Diesel_particulate_filter
do read the regeneration section
      02-21-2008, 10:57 AM   #12
creepy coupe
1867
2009 335i  [0.00]
Sounds a strange system to me, what it’s supposed to do is burn soot, which I thought was burnt anyway, it sounds as if the filter stores the soot until a convenient time, when it can burn it and not affect emission values and claim cleaner engine outputs.
      02-21-2008, 11:04 AM   #13
e-maps
Drives: Seat
A BMW tech I know told me that the only way you can tell the car is in regeneration mode is the gearbox goes into 5th gear and you cant push it manually into 6th. This is to keep the rpm up so the exhaust temps are high enough to burn off the soot.
I'm not 100% sure on this, might be something to watch out for if you think your car is in regeneration mode.
      02-21-2008, 11:11 AM   #14
roofer
roofer's Avatar
United Kingdom
21
Drives: 335D M Saloon
As Dave says, describes the smell acurately as well imo.
      02-21-2008, 11:15 AM   #15
m.rk77
m.rk77's Avatar
24
Drives: BMW 335d
there's no indicator light , there's no message to let you know the process if taking place. One way you know is that the car will handle as if it is in DS mode (Sport mode) to ensure higher temperatures.
If you suspect you are in regeneration mode you can pull over and place your hand CAREFULLY on top of the air filter box. It will be HOT! This box almost never becomes hot except if the car is going through regeneration. I am talking HOT not warm so be careful!
Everything in the engine compartment will be hotter then usual.
      02-21-2008, 12:59 PM   #16
quattrogmbh
Drives: BMW
I can smell Diesel exhaust fumes (Pre-filtered fumes since they don't have the ammonia smell) around the particulate filter and turbo manifold. This often enters the cabin if at a standstill or in traffic. I havent experienced a Sweet Caramel smell, which suggests its likely to be the lacquer burning off the particulate filter.
      02-21-2008, 01:18 PM   #17
m.rk77
m.rk77's Avatar
24
Drives: BMW 335d
you should smell it much stronger when the regeneration is active. Can you feel a lot of heat coming from down there?
The regeneration process creates a lot of heat, much hotter then the regular engine heat
      02-21-2008, 01:26 PM   #18
Dave_3
Dave_3's Avatar
Scotland
652
Drives: G22 M440D
Must be SOME laquer to do that even after a year of everyday use ....
D.
      02-21-2008, 01:44 PM   #19
m.rk77
m.rk77's Avatar
24
Drives: BMW 335d
the laquer burns off after the first regeneration...
The regeneration process can reach 600 degrees Celsius
the last time I had the regeneration my engine compartment was so hot that I could not touch anything in there. I almost burned myself just by opening the bonnet.
D.
      02-21-2008, 01:45 PM   #20
roofer
roofer's Avatar
United Kingdom
21
The exhaust is a sealed system, the only smell will come from the rear, as stated, when the wind is blowing in the right direction.
      02-21-2008, 01:49 PM   #21
quattrogmbh
Drives: BMW
agreed - "Should" be a sealed system ;-)
      02-21-2008, 01:53 PM   #22
m.rk77
m.rk77's Avatar
24
Drives: BMW 335d
yea, should be sealed and there should be absolutely no exhaust smell or any kind of burned smell around the engine...
But that is not he case with my vehicle...
This my be my first and my last diesel purchase...
Reply
