2Addicts | BMW 2-Series forum Technical Topics N20 (228i) / B46 (230i) Engine, Transmission, Exhaust, Tuning Exhaust Flapper Tech Bulletin
      07-15-2015, 02:36 PM   #1
OpenAir
OpenAir's Avatar
Drives: Enzo F23 228i
2015 BMW 228i  [0.00]
So, my exhaust flapper started to rattle the other day, and I crawled under to take a look and when I pulled on the spring clip, "pop" it came right out!
Called the dealership and explained the situation and sure enough, tech bulletin came out for "rattle noise" in exhaust. They did the repair and all is well again...something about the heat shield and bolts.
      07-15-2015, 03:25 PM   #2
2msport
Drives: '14 228 MT
Very interesting! I'm pretty sure I've heard a rattle... Although I have the MPE installed so I guess it doesn't apply to me. I thought I'd try and spray some grease back there.
      07-15-2015, 04:42 PM   #3
OpenAir
OpenAir's Avatar
My service manager didn't mention if it was just oem mufflers or if it went across all mufflers, it was about the servo, and your mpe has a servo. I'd check!
      07-15-2015, 05:11 PM   #4
horsepower_and_hounds
horsepower_and_hounds's Avatar
Drives: '15 M4 BSM
I unplugged mine on the 235.....no rattle
      07-15-2015, 07:22 PM   #5
OpenAir
OpenAir's Avatar
That's great! Mine wasn't plugged in and I had the rattle...it's a servo thing so it's not effected by power.
I also noticed that putting your car in sport + and unplugging the harness doesn't change the valve position...hence why most are saying it makes little to no difference.
      07-15-2015, 08:15 PM   #6
Drives: '15 M4 BSM
I unplugged it when it was cold and I guess it has been unplugged almost from the beginning it is tight enough not to rattle. Now sometimes I think I hear something but not enough to worry about and i also have the mPE
      07-15-2015, 08:31 PM   #7
pikcachu
pikcachu's Avatar
987
Drives: M235i (F22 Red angel)
can you take a picture where the spring clip is ?
      07-15-2015, 09:01 PM   #8
OpenAir
OpenAir's Avatar
Well...I'd have to jack the car up again cause I'm too fat to crawl underneath!
I can say that the clip is a u-shaped rod about the thickness of a coat hanger and it is compressed when the solenoid is attached to the exhaust bracket. Both the solenoid and the actual flapper valve have a straight groove that the spring sits in, and the compression is what holds it in place. It fills the 1/2" gap between the flapper and the solenoid.
Helpful?
      07-15-2015, 09:06 PM   #9
pikcachu
pikcachu's Avatar
987
Helpful?
Ok... i'll see if I can locate it thanks...
      07-15-2015, 09:10 PM   #10
OpenAir
OpenAir's Avatar
I did take a pic when it was out of the car:
      08-14-2015, 08:56 AM   #11
M-tavo
M-tavo's Avatar
Do you know what they changed? I have the same rattle, but I changed exhaust so I can't bring it in for that.
      08-17-2015, 02:38 PM   #12
OpenAir
OpenAir's Avatar
The heat shield...which is the metal cover that protects the servo.
Search this Thread:
Copyright ©2000 - 2020, vBulletin Solutions Inc.
