Are you following the 1200 mile break-in recommendations? |
06-29-2016, 02:03 PM | #23 |
Rep 395
The break in procedure is not just about making the car last long. It is also about making it run smoothly.
I'm sure most of you guys know, but when the pieces are new (engine, transmission etc) the pieces fit "too tight". It's like two surfaces of rock with small imperfections. If you drag the rocks smoothly, they'll wear smoothly and fit smoothly in the long run. But if you intensely drag one piece against the other, the small pieces will wear out in bigger pieces and the points of contacts won't be that smooth. It depends on how much you care about the gear shifts and other stuff be smooth (and up to what point). It will run fine if you don't do a perfect break in, but it will run better if you do. Perhaps this is not noticeable for most people Sellers have this bias of saying that the engines are "bullet proof" or "broken in from factory" because they have no incentive to say otherwise. They sell test driven cars. But think about it: how much would it cost to BMW to do the break in procedure for you? Break in only works when most of the pieces are together. We're talking about 800-1200 miles from factory,... gasoline, etc... |
07-03-2016, 06:38 AM | #25 | |
Rep 73
Next dyno day it put down the most power of any stock car and even the dyno operator came over and said "This thing has been driven hard from new hasn't it...?" Apparently he could feel the difference in how hard it pulled. When my new M235i arrives in August, it'll be the same deal |
07-27-2016, 02:45 PM | #27 |
Rep 5,120
So, based on the above, after I pick up my 230i from the Welt this fall and head to the autobahn, maybe I don't have to worry about burying it right away! That's welcome news for a Wednesday!
08-14-2016, 04:09 AM | #28 |
Rep 509
Drives: 2016 M235i RWD 6MT
Yes I am trying to follow the break-in period. For the very first full tank I was driving my car in Eco Pro 90% and maintaining revs mostly under 2000rpm. I have made occasional pulls where the revs go up to about 3500rpm. I am currently at about 800km on the odo and on my 2nd tank of gas I have driven the car in mostly comfort mode and about 25% in sport mode. With sport mode I have been revving the rpm up to about 4000rpm mark. I have not held back in comfort mode and ensured that I have been driving with shifts ranging from 1500rpm to 3500rpm steadily. I have been revving the engine up to 4000rpm mark and once made it go to 4200rpm (oops getting real close to the 4500rpm mark!). My 3rd tank of gas which I'm on right now I am revving up to about 3000rpm.
(Canadian manual suggests break-in period of up to 2000 km) 6MT RWD. Not sure what octane first tank was but 2nd and 3rd tank is octane 93.
2015 ES350 6AT - Traded In 2004 RX330 5AT - Sold 2004 Civic Coupe Si(EX) 5MT - Retired 1993 Civic Coupe Si(EX) 5MT - Retired |
08-14-2016, 08:49 PM | #29 |
Rep 76
Nice car, mine is the same spec and color plus Harman Kardon and heated seats [manual transmission of course]. Mine won't get here for another 10-12 days but I kind of plan and riving it pretty hard from the get go. How did you get the darker grey wheels????
F1HAMMY, FT Riley KS 2008 E90 Manual Trans [Retired] 2013 Ford Focus ST2/Chalupa Batman 1 [Retired]
2017 F22 230/Chalupa Batman 2. M-Sport/THP/Manual Trans/Harman Kardon/Heated Seats, On Order 991.2 GT3R: In an old gym sock under my bed..... |
08-21-2016, 07:37 AM | #30 |
Rep 864
Break-IN STYLE -- Don't over baby
Many new German engines uses MOS2 coated chamfered rings running in Alusil bores. A very difficult break in regime. This is why a break-in oil is used because with LL-01 oils you will never achieve true break in. They protect too well & you will have an oil burner for life (rings wont properly seat).
It is known not to over baby these engines during break-in as long as temperature does not rise above normal. Avoid constant throttle for long periods of time ~ is the main thing along with Revs below 5k. . . I purchased my car with 15k miles so it is unknown as to what break-in style was used -- I do sleep at night. |
08-23-2016, 10:06 PM | #31 |
Rep 201
Drives: 2017 GT350
I just changed my oil for the first time at 1,400 miles with Mobil1 0W-40
08-24-2016, 04:57 PM | #33 |
Rep 101
I followed the break in procedure the majority of the time, always in sport more and short shifting at 3-3.5K. After the break in period I drove some mountain roads at 4-6K and it really gives you the fizz .
Just hit 1200 miles a few weeks back and changed the oil. Sent it off for testing and plan to do it at every oil change. More so out of interest so I know if it's worth doing in future. Will post the results once I get them. |
09-03-2016, 04:32 PM | #34 |
Rep 3,395
Some manufacturers use "break in" oil on engines delivered new and it actually a bad idea to change oil before the first regular interval
Anyone know if BMW does anything like that with the 230 or M240? I know VW has done this in the past. particularly with diesels |
10-06-2016, 02:43 AM | #35 |
Rep 509
Ok, so I did the 1200 mile (2000km) break in oil change but I wasn't able to get an appointment until I had actually driven 2600km (approx 1615 miles) is it too late or am I just being paranoid for nothing?
10-06-2016, 05:10 AM | #36 |
Rep 76
Ha, I have almost the same car/options. My CA said don't worry about any break in, I'm at about 600 miles for my first 10 days, I haven't driven it really hard but have run it up to 68k rpm a couple of times
10-06-2016, 05:38 AM | #37 |
Rep 1,303
Drives: 2021 C8 Corvette 1LT
68k RPM? Shit I want your motor! Personally, I'm not being over hard on the motor, took it up to 5k once but otherwise staying below 4500rpm because should something happen and I need to claim the warranty for whatever reason, I don't want to be responsible for the $20k engine swap.
10-06-2016, 05:43 AM | #38 | |
Rep 1,303
But to answer your question, from the sounds of it BMW uses normal oil from the start so shouldn't be a problem changing it early. |
10-06-2016, 08:51 PM | #39 | |
Rep 3,395
