BMW 3-Series (E90 E92) Forum
Microfilter Service Light Will Not Reset
06-04-2015, 10:55 AM | #1 |
Rep 128
So since I've owned my vehicle it has had the orange service reminder light come on at start up for the microfilter service and now it's gotta to the time period where the service light coming up is red (overdue).
I have looked up and read through tons of posts on how to reset the service lights which have worked for everything BUT the damn microfilter. Whenever I attempt to reset it the clock icon spins as if it is in the process of resetting and then it just goes right back to the last service date. I was wondering if anyone else has had this happen to them and have been able to find a solution or if anyone has any other routes I can try. I've taken it in to my indy and they too have tried everything they could think of with no success. I know it isn't something to necessarily worry about but it's just super annoying to see that big red light come on every time! Any info is appreciated! |
06-04-2015, 05:36 PM | #2 | |
Rep 1,951
If you have an android device and can install Carly, just code it out. If not, you can jump through other hoops to do the coding.
06-04-2015, 05:59 PM | #3 |
No 55mph
1622
Rep 8,476
In my 09 MF service was not turned On from factory. When I switched to the M3 gauge cluster I turned it on just for s&g
Its basically useless and annoying, so I turned it back Off Recommended replacement is 1X per year, pretty bad if I can't remember that and need an electronic reminder...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
06-04-2015, 06:01 PM | #4 | |
Rep 128
Gotta find a coder in the Bay Area now then if so. |
06-04-2015, 07:07 PM | #7 |
1920
Rep 13,119
Mine reset through the BC stalk procedure
no problem. Contact elliot@detailaddict in Santa Clara he does coding. Detail Addict is the name of the business also. He also has and add on the coding sub forum, or is at least a presence there. http://www.e90post.com/forums/forumdisplay.php?f=16 |
