05-07-2015, 07:01 AM | #1 |
Rep 129
Coding the Spoiler Guide
Confirmed this morning that the active spoiler can be coded.
Module: HKFM Inside HKFM there are a bunch of options that start with ASP. I'm not sure what all of them do yet but all of them have to do with the Active Spoiler. The example today is to change the speed at which the spoiler is activated. You need to change two values to change the speed. In this example I'll pick 55mph. We have to convert everything to km/hour so lets say 88. If you don't change both at the same time you'll get an error when coding the car. V_ASP_OUT has a default of 00, 6E. The '6E' value is the speed you'll need to change. We need to convert 88 to Hex. So the value you'll want in here is 58 The second one is a tricky one. INV_V_ASP_OUT has a default value of FF, 91. Just like the first example we'll need to modify the hex value of 91. This one is a bit different because you need to do some math. When converting these hex to decimal we get 255-145=110. 110km is the default activation speed. Not sure why BMW did this but we need to do the same to make this equation equal 88. So 255-88=167. Convert that to hex we get A7. When both of the values match you won't get a coding error and the spoiler will activate at 55mph. My final values are: V_ASP_OUT = 00, 58 INV_V_ASP_OUT = FF, A7 I'm assuming it's the same for V_ASP_IN, however, there isn't two parameters like there was for OUT. I'll test the IN later and report back. -Dan |
09-10-2015, 07:02 AM | #2 |
Rep 129
Confirmed V_ASP_IN works to retract the spoiler at a certain speed.
Confirmed that F34 Active Spoiler retraction speed can be coded. HU_NBT -> 3100 -> V_ASP_IN Again this value needs to be converted to hex to work. The default is 46 hex which converts to 70 kmph. If you want it to be 88 kmph that would convert to a hex value of 58. |
09-10-2015, 01:00 PM | #4 |
8280
Rep 16,145
09-12-2015, 03:01 PM | #5 | |
Rep 86
09-12-2015, 03:30 PM | #6 |
Rep 129
I'm not sure, i haven't really tested how low it can go. Another user @ bimmerfest wanted his to go up at 10kmph and retract back at 5kmph. He was going to test it out and see what happens.
09-12-2015, 07:43 PM | #7 |
Rep 86
10-06-2015, 08:20 AM | #8 |
Rep 1,345
Drives: 04 Z4, 18 X3 M40i
The spoiler seems to have a lock that is activated when the car is locked. After unlocking the lock disengages at about 53km/h. The spoiler still deploys at @110km/h. Have you seen the vales for this?
10-08-2015, 03:52 PM | #9 | |
Rep 129
Comment = Vehicle speed limit in km/h in order to transition FeTraFla mode < => automatic mode. OPTIONS initwert = 00 32 - Comment = 50-> 50km / h |
