04-10-2015, 02:53 PM | #1 |
Swedish Viking
Rep 15
Charging
I'm not sure if it's me or something not working as it should when it comes to charging.
When I leave it to charge overnight I never seem to be fully charged in the morning. This morning it was even empty, so no eDriving to work. Maybe there's a setting or something, but am I wrong in my assumption that the car should be kept fully charged as long as the charger is connected (and powered of course)?
Am I not making sense? English isn't my native language, sorry. Then again I could just be drunk.
04-10-2015, 03:55 PM | #2 | |
Rep 578
Also the driver display shows charging status and what time charging will be finished. |
04-10-2015, 09:10 PM | #3 |
Rep 1,542
Another thing to consider.....did u plug it into the wall or use an extension cord. I have seen charging not working with extension cords or bad sockets. I use my regular 110 socket and it works fine. Of course check your charger, if it doesn't work in any outlet, voila!
Best of luck..... |
04-10-2015, 10:09 PM | #4 |
Rep 25
You can also check the bmw i app on your phone that will tell you if its charging and its status; i tried an extension cord and it will charge for about a minute and then state it is unable to charge.
04-15-2015, 02:46 AM | #5 |
Swedish Viking
Rep 15
Solved!
Update:
This was problem was caused by using an extension cable. For some reason the cable caused to charger to "power off" randomly. Once removed everything seem to function as it should. Thank you for the ideas!
04-15-2015, 10:13 AM | #6 |
Rep 678
Drives: E30M3, E39M5, SLSAMG, RRS SVR
Garage List 2015 Range Rover Sp ... [0.00]
'03 BMW M5 [0.00] '88 BMW M3 [0.00] '84 Toyota Corolla ... [0.00] '14 Ford Fiesta ST [0.00] '12 Mercedes SLS AMG [9.83] |
Probably detecting too much resistance from the extension cord and it cut power so it wouldn't catch on fire. Electricity is like water, if the pipe isn't big enough and you apply to much pressure, it's going to burst.
09-21-2016, 12:59 PM | #7 |
Rep 2,352
Drives: 16' BMW i8
Garage List 2001 BMW M3 E46 CON ... [9.50]
2016 BMW i8 [10.00] 2003 JEEP GRAND CHE ... [0.00] 2000 540i SPORT E39 [10.00] 2007 TOYOTA TACOMA ... [0.00] |
For those using an extension cord, you need to purchase a Heavy Duty 10-guage (preferably a 25-ft length) outdoor extension cord. Anything less will not work properly.
