BMW 3-Series (E90 E92) Forum
Rubbing noise when turning right
12-18-2014, 11:09 PM | #1 |
Rep 265
Hi guys, just installed forgestar f14's on my e92, and it seems that when I make right turns i hear a rubbing noise possibly from the front fenders. The tires are 235/35/19 and 255/30/19, and the car has been lowered. Previously on my other set of wheels the fronts were 225/35/19 and this never happened, would this be due to the wider tires since its lowered?
Thanks |
12-19-2014, 12:58 AM | #2 |
Rep 6,604
Drives: e92 335i
what are the offsets?
12-19-2014, 01:28 AM | #3 |
Rep 2,731
They arent just wider, they have a taller sidewall too.
Even though the old and new tires are 35 series..... the 35 series isn't a measurement in mm, it is actually a percentage. 35% of 235mm versus the old tires 35% of 225mm. Just like 35% of 200 dollars is more than 35% of 100 dollars. So you are wider, and have taller sidewalls. |
12-19-2014, 07:32 PM | #6 |
Rep 3,548
Most likely passenger side tire rubbing against opening fins of the wheel well liner for the cooler.
Shave fins or heat gun and bend. |
12-19-2014, 07:55 PM | #7 |
Rep 6,604
Drives: e92 335i
i don't think you can roll front fenders because they are plastic not like the rear fenders on the e92 or the e90. The e92 have plastic front fenders be aware of rolling them. Just change out tires to smaller height & you should be good to go
12-20-2014, 02:15 AM | #10 |
Rep 265
12-20-2014, 07:07 AM | #12 |
4546
Rep 11,903
Perhaps ur wheels are too big
