2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning JB4 install guide
      10-30-2014, 12:08 PM   #1
Béhème
JB4 install guide
I haven’t been around here long, but I did do some research before posting this.
Although Burger Motorsports do have an JB4 install guide on their website, it could be more specific to the 235 (pneumatic versus electronic solenoid, A or B harness for TMAP, etc. ).
Does anyone know if a 235 specific and complete JB4 Stage 2 install guide, which includes the EWG and FF harnesses (also possibly the USB cable routed into the glove box), exists?
BTW, one would also think that OEM type in-line connectors could be cleanly spliced into the car’s wires instead of the obviously superficially retrofitted quick connectors (ex: CAN wires) for rapid and neat unplugging/plugging, for JB4 removal before/after routine maintenance.
      10-30-2014, 04:44 PM   #2
G-Mann
G-Mann's Avatar
552
Drives: X6 M60
I never found anything specific to the M235i and took my time reviewing and asking Burger questions before I attempted the install.
Personally I think Burger would sell a few more of these if model specific installation videos were made and it would cut down on the questions they field.
In the end the instructions will make sense, hook up two harnesses, Your ground and power cables, and your two wires you tap into your can wires with. You will be saying piece of cake afterwards but yes I do feel where your coming from right now.
and yep, an improved can wire tap would be nice. Really seems to be a main reason why some choose a competitive product.
2026 X6 M60i
2025 M240ix, 2022 M4 Comp X, 2021 M440ix, 2015 M235 - Sold
      10-30-2014, 06:07 PM   #3
TB///M3
Drives: 16 ///M3
I just installed mine, here are some parts that got me stumped.
The Tmaps are easy, just lay out the cables, one sits by the charge pipe, the other is toward the top of the engine. The CAN, when you pull out the wires, there are two red wires. The correct one is the one twisted with the blue/yellow. NOT the stand alone red one. You will not need the blue wired connect, just tape it up and put away. +/- wires you should know where that goes. For the unit, I used Velcro and placed it on top of the fuse box, the cover will fit. Btw..this is for the stage 2 jb4, and order the usb connector, apparently there's no easy way to tell what map you are on without hooking it up to JB4.
      10-30-2014, 06:09 PM   #4
Mike@N54Tuning.com
Drives: 2007 335i, 2015 M3
That's because none of the competitive products have CANbus access. If you just want a simple tune like everyone else sells grab the BMS Stage1.
To OP, directions are the same as the F30. There is no USB routing for the F series just run it in the door jamb when needed. The FF and EWG are add on parts that have their own specific guides.
Mike
      10-30-2014, 06:20 PM   #5
TB///M3
Drives: 16 ///M3
Mike
Mike do you have the ewg install guide? Not where it's plugged, but where the wires go, pictures if possible.
      10-30-2014, 07:19 PM   #6
Cybertronic
Drives: G30 M550i, E30 M3
You can check out this vid I made. Its more to show how I cleaned up the harness, but also shows where I connected and routed things.
      10-30-2014, 08:41 PM   #7
zipphreak
No_Country
471
Drives: m235xi
Agreed if there was a detailed F22 guide, and/or video. I would probably have already bought one Although this video is a good start, that look's legit. It's way easier than I thought.
Where are you grabbing power and ground?
If i magically got a JB4 from one of our forum sponsor's on here, I would spend some time making a video to document the install for people..
      10-30-2014, 08:44 PM   #8
TB///M3
Drives: 16 ///M3
Very nice job, mine was not so clean.
Where do those the pins go for the ewg wires?
      10-31-2014, 02:04 AM   #9
Bee Pee
Bee Pee's Avatar
United Kingdom
2151
Drives: AW M2 DCT
Cybertronic,
Great idea, any tips or a step by step DIY ?
Thanks,
Pave
      10-31-2014, 06:48 AM   #10
snodgrass23
snodgrass23's Avatar
Drives: 2015 EB m235i
The whole thing is actually pretty easy once you get the harness in and laid out, especially if you don't do the FF and EWG wires. If you basically lay the harness over the top of the engine, each plug pretty much falls right where you plug it in.
If you add the FF and EWG wires, it adds a little complication. You need to add the wires to the harness first. I recommend sitting down and taking your time with this step, ideally with some additional tubing, etc so clean up everything once you get it hooked in. The hardest part then is really just getting to the EWG plug.
aFe Momentum Intake, Dinan springs
      11-22-2014, 01:03 PM   #11
kd0t
Sorry for being such a noob, but can I follow this video for stage 1 install?
      11-23-2014, 12:24 AM   #12
r33_RGSport
General
r33_RGSport's Avatar
14622
Drives: X7 M60, G05 X5 40, 991.2 GT3RS
Yes, use that video.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for EVERYDAY DEAL!!
AST • iSweep • RaceChip • Sterckenn • PowerFLEX • Akrapovic • Vossen • Eventuri • HRE
Active Autowerke • KW • H&R • Ohlins • Remus • CSF • SPL • SST and more...
Accepting - Visa, MasterCard, American Express, Discover, Paypal, Venmo, Cash App, Amazon Pay, Affirm.
      12-14-2014, 10:08 AM   #13
CONTROL ONE
CONTROL ONE's Avatar
74
Drives: 2014 BMW M235i
Ok, just installed the BMS Stage 1 and everything looks good but I just want to be sure you aren't supposed to connect the red/black power/ground wires by the battery?
Instructions say that only the rainbow and brown connectors are used and all other connectors and wires should be tucked away however it doesn't seem like the unit would get power this way (unless it can feed off of the power from the TMAP).
Please confirm, thanks!
      12-14-2014, 12:46 PM   #14
Bee Pee
Bee Pee's Avatar
United Kingdom
2151
Drives: AW M2 DCT
See link here for PDF guide from Babybmw.net.
http://bit.ly/1yONVAT
      12-16-2014, 09:05 AM   #15
r33_RGSport
General
14622
You do not connect those wires on the JB Stage 1. Just the brown wire connector pairs and the rainbow wire connector pairs.
      12-30-2014, 07:24 PM   #16
F80_M
Drives: 1/1 PSM F80, F36, G11
I believe this isn't suppose to display...?
      12-30-2014, 07:46 PM   #17
CONTROL ONE
74
Thank you.
      12-31-2014, 06:27 AM   #18
qballis
Drives: G80 Comp xdrive
Hit ok and restart the car. All should be fine. You'll get this and chasis stabilization warnings.
      12-31-2014, 12:31 PM   #19
Mike@N54Tuning.com
Read the codes then use those as a basis to fix whatever is wrong with your vehicle.
Mike
      12-31-2014, 12:36 PM   #20
F80_M
I turned it off and then back on and engine kicked on but here are the issues... Whole tach didn't move everything stayed at 0 as if engine was off, extremely loud fan noise, brake malfunction, and drivetrain malfunction... Attempted to hook up the usb to laptop but didn't pick it up so I'm going to unplug and redo it all and make sure all connections are snug again.
      01-01-2015, 12:47 PM   #21
F80_M
So I got everything up and still says drivetrain malfunction (6mt). I noticed that in the bundle of wires for the can theres 2 red wires. Wondering if I should give that other one a try?
      01-01-2015, 06:28 PM   #22
Mike@N54Tuning.com
If you bought it new just send in photos to BMS for support. If used then you could still post photos in the n54tech support section for help.
Mike
