BMW 3-Series (E90 E92) Forum
Door lock issue - Fuse or Actuator??
10-09-2014, 01:19 PM | #1 |
Rep 463
So... My drivers side rear passenger door will not lock/unlock with FOB or with the central lock/unlock button. The door can be manually locked by pushing the door pin and opened, by using the door open lever inside the car..
I have read from similar issues it could be the fuse for the doors - not enough amperage - and the consensus was to replace either fuse 53, 56 or 57 - can't remember exactly, from a 15A to a 20A. The other possibility might be the actuator gone rogue and to replace it on the offending door?... Thoughts?? Would prefer just the fuse route.. |
10-09-2014, 01:22 PM | #2 |
Rep 604
Drives: 2009 328i xDrive
I have an 06 and the same problem with me... When I got a new car battery, the door miraculously worked again by the Fob and central locks.
10-09-2014, 01:25 PM | #3 |
Rep 463
Replaced battery when I got it.. If I recall all doors worked? Never really checked at the time, just assumed if I lock the doors, the doors are locked and the one I cared most about, driver, was locked?
