Forum for the entire range of BMW electric vehicles
BMW i8 Forums BMW i8 General Discussion
      07-20-2014, 08:53 PM   #1
KKSigs
M4 CSL FBG
KKSigs's Avatar
Drives: M4 CSL FBG
Height of i8 with doors fully up
Does anyone know where I can get the height of the i8 with the doors fully up. I want to make sure that the framing of my garage door does not interfere with the doors up. If so I will have to rearrange the garage spots.
Thanks
16' M4 GTS Frozen Dark Grey Metallic
14' i8 Sophisto Grey Pure Impulse World
08' E92 M3 Jerez Black
      07-20-2014, 09:12 PM   #2
drlonline
drlonline's Avatar
Drives: 2019 i8 Coupe
The height from the ground to the top of the open doors is 1958 mm (77.1"). You can see that and other dimensions at the end of the attached file.
      07-20-2014, 09:21 PM   #3
KKSigs
M4 CSL FBG
KKSigs's Avatar
Drives: M4 CSL FBG
Awesome thanks for the info!!
      07-21-2014, 09:23 PM   #4
granitesentinel
Drives: Audi 4.2
Does anyone know if there are explosive bolts fitted to the doors or other safety
Features fitted to the doors in case of roll over?
      07-21-2014, 09:30 PM   #5
Carac
Drives: E30M3, E39M5, SLSAMG, RRS SVR
The doors would still open enough for egress since the hinge is on the side not the roof, unlike the SLS.
      07-23-2014, 10:32 AM   #6
granitesentinel
Drives: Audi 4.2
Thanks! Since we're talking about doors...has anyone tried ingress/egress in tight parking spots and found that materially more clearance is required with 'butterfly' doors? (not that I would ever risk parking that close to someone, but worst case scenario, what extra clearance is required and has anyone tried crawling out the 'escape hatch' rear window
      07-23-2014, 10:37 AM   #7
ddk632
Chief Senior Executive Managing VP of Orange Sales
ddk632's Avatar
Drives: 17 BMW F87 M2 6MT MG HBDGR !
One review recently stated that parking in tight spaces is a no-no as the doors do need some clearance and I imagine need to fully open to allow the driver to get out.
And yeah, don't park in tight spaces. I never park in places where I might get door dinged or have a shopping cart rammed into my vehicle.
As for the escape hatch, you'd have to first break the "emergency escape gorilla glass rear compartment divider window" which sits between the cabin and the mid-mounted engine/rear compartment.
A costly endeavor, only recommended in the most extreme of circumstances. And even then, one would most likely need to be a meth-addicted midget to actually fit through the opening there...
      07-23-2014, 02:29 PM   #8
drlonline
drlonline's Avatar
The clearance required for entry/exit was a question I had as well, as our garage is not particularly wide. At a dealer preview of the car, I actually experimented with getting in and out while the door was only partially open (had someone hold it in the halfway open position). As you would expect, it was tougher than normal, but not impossible. Not something you'd want to do frequently, but can be done in a pinch.
      07-24-2014, 09:24 PM   #9
granitesentinel
Drives: Audi 4.2
Thanks to all for the rigorous testing!
bmw
