Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Reliability of LCI E9X?
Reply
      07-15-2014, 03:25 PM   #1
devtec
Drives: 2011 E92 6MT M Sport
Hello all,
I know there are a ton of threads on reliability, but I haven't seen one specific to the N55 LCI E9Xs. We know BMW ironed out a lot of the pre-LCI problems, which are well-documented on this forum, but I was just curious if the supposed improved reliability has continued to be true a few years out.
What problems have 2011+/LCI/N55 E9Xs been experiencing out there? What should we all look out for specific to these cars as they age?
__________________________________________________ ___________________
ISSUES MENTIONED SO FAR:
30-40k
Replaced warped rotors
35k
Replaced water pump, HPFP, lower control arms due to failed bushings
      07-15-2014, 03:29 PM   #2
335m
Drives: 08 e92 M3
Subbed, haven't seen many n55 threads that cover more than one issue.
      07-15-2014, 03:42 PM   #3
bad karma
Drives: 2015 328i F31 M-Sport
Subbed as well. Quite curious. Ostensibly, BMW took all of their engineering knowledge of the development and subsequent issues of the N54 and rolled that into the N55, making it a better, more reliable engine. We're three years out from its release now so it may still be too early to tell.
      07-16-2014, 01:27 PM   #4
chatch10
chatch10's Avatar
65
Drives: 2011 E90 335i M-Sport
From what I've read the issues still seem to be the same ones as the n54 like HPFP failure, wastegate rattle, and everything else, but it is at a much lower rate.
I have a n55 with about 30k on it and the only issues I've had are warped rotors and a vibration issue that I suspect is a bad wheel bearings from a pothole. No problems engine-wise though.
Otherwise this car has been perfect to me for the last 3 years. Look around the n55 section just to get some idea of what is going on.
      07-16-2014, 01:29 PM   #5
335m
Drives: 08 e92 M3
Warped rotors @ 30k, is that normal?
      07-16-2014, 03:16 PM   #6
chatch10
chatch10's Avatar
65
I think I've seen a couple others mention it at low mileage, but the Service Advisor who is a friend of mine said that's the earliest he's seen it at his dealership.
      07-16-2014, 03:44 PM   #7
raisingAnarchy
raisingAnarchy's Avatar
Drives: E90 ZMT
Most of the used 3 series that I've driven have had warped rotors, usually with 30k - 40k miles. It just depends on the driver and how much they ride their brakes down a hill.
      07-16-2014, 03:52 PM   #8
335m
Drives: 08 e92 M3
I'm not sure if this thread has ever been done before, but if it hasn't you should edit the first post asking for people to post a template such as:
Model and Year:
Mileage:
Mods: (Include when they were installed)
Issues: (Include when it occurred)
      07-16-2014, 04:43 PM   #9
bad karma
People need to learn how to downshift.
      07-16-2014, 05:57 PM   #10
miker2013
Drives: 335xi 6mt Msport coupe
this x2
downshifting seems to be a lost art these days
when i don't downshift, to me it just feels weird like i don't have control of the car and i it just feels unnatural and feels like i am wasting brakes... but so many drivers coming from automatics never learn the how to use engine braking to control the vehicle... too bad, they are missing out
      07-16-2014, 07:48 PM   #11
jakuum
Drives: SGM e92 335i M-sport
2011 BMW 335i  [0.00]
Had the coolant expansion tank replaced at about 34k miles as it had developed a leak. Took two trips to the dealership for them to find the cause of the low coolant warning.
      07-16-2014, 07:54 PM   #12
Delta0311
Drives: 2011 BMW 335xi E92 2016 228xi
At 35k had following done already
Car is a 2011 e92. Except for rims car is bone stock and don't plan on modding it.
Replaced water pump
Replaced hpfp
Replaced rotors
Replaced lower control arms due to bushings going bad
And there is a vanos bolt recall but still waiting on final letter.
      07-18-2014, 11:02 PM   #13
devtec
Replaced water pump
Replaced hpfp
Replaced rotors
Delta, why did you get all that replaced?
Could you describe the symptoms for each that brought you in to the dealer? Also approximately how many miles when you encountered each?
Thanks.
      07-18-2014, 11:03 PM   #14
devtec
To all, will keep this thread organized and updated with all responses.
Hope to keep hearing from more people.
Thanks.
      07-19-2014, 06:46 AM   #15
Bob Shiftright
Save The Manuals!
Bob Shiftright's Avatar
64
Drives: E91 Schleppwagen
Scanning the Consumer Reports reliability charts (they claim to include questionnaires covering 1.1 million vehicles), the post-LCI 335i looks a little better than the pre-LCI 335i, but is not up to the pre-LCI 328i.
After 2012 (F30) the cycle looks like it's beginning to repeat.
The 335i is no longer in the CR "used cars to avoid" list after MY 2009.
(BMW knows exactly how much of what breaks for every model year, but they ain't sayin'.)
2008 E91 36K, 6-speed, RWD, Alpine, Terra, Xenons, ZSP, ZCW, ZPP, PDC, CA, alarm, M shifter and M brake handle, Euro rear fog light switch, Euro aspheric mirrors, rear power outlets, Euro split armrest, Lidatek, remote V-1, Cocomats, beach sand, $10 clutch stop mod. 1998 Volvo V70T5 226K, 5-speed, original clutch (third clutch pedal!), aspheric driver's mirror, E-code headlights, IPD sway bar, strut tower brace & skidplate.
      07-19-2014, 09:57 AM   #16
Delta0311
Thanks.
Rotors caused wheel to shake when braking. Control arm caused a vibration at around 65mph. Hpfp, got long cranks during cold start and scanned for codes. Water pump, radiator fan kicked on right as the car would start and would run at very high speeds, again scanned for codes.
Dealer replaced everything under warranty.
Rotors replaced at 26k. Hpfp at 30k. Water pump at around 33k. Control arms just now at 35k.
      08-12-2014, 10:17 AM   #17
335m
Drives: 08 e92 M3
Had to hunt down this thread.
At 25k miles my Chargepipe just cracked. I have had Cobb Stage 1 Aggressive with no other significant mods for about 3000 miles.
I highly recommend upgrading the plastic OEM chargepipe if you plan on running any boost above stock levels, even then I would recommend the upgrade because they have been prone to crack on stock levels.
I have not received the product yet but I would recommend the VRSF CP ($169) and install it yourself <30min.
      08-12-2014, 10:20 AM   #18
335m
Drives: 08 e92 M3
Any known cause for the Control Arms? Is that normal? I just installed BC Coilovers so if my Control Arms go bad the dealer probably wouldn't cover it.
      08-12-2014, 10:21 AM   #19
Delta0311
It's normal.
Reply
