BMW 3-Series (E90 E92) Forum
Potential Fuel Pump going..
06-26-2014, 10:53 AM | #1 |
Rep 131
Hi Guys - had a quick question regarding the fuel pump recall.
I threw a fuel pump code yesterday which said something of being a potential pump thats starting to fail?I cleared the code and havent had it since. But i was curious about whether or not I would have to remove all my bolt-ons to bring the car in to BMW for the recall eventually. I realize every dealer is different and for the turbo/wastegate recall you absolutely need to remove DPs, filters, etc. Either way, the tune would go back to stock, but i wasnt sure if dealers would deem the failure to come from upgraded components Its probably better to air on the side of cautiousness and remove everything anyways, but any feedback would be helpful! thanks
2005 Audi S4
2009 e92 335xi 2006 Audi A6 2001 Saab 9-5 Aero |
06-26-2014, 11:07 AM | #2 |
Rep 6,478
I *believe* the HPFP is a recall - not a warranty item. I'd be surprised if they refused to do the work since you aren't really making a warranty claim, merely taking advantage of an existing TSB.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
06-26-2014, 11:28 AM | #3 |
Rep 131
thanks for you input, and thats what i beleived as well. I know dealers give you a hard time on the turbo recall regarding aftermarket performance parts though..
2005 Audi S4
06-26-2014, 11:30 AM | #4 |
Rep 80
Which pump code did you throw? HPFP/LPFP?
From what I understand, the plausibility code (2AAF) is pretty common and does not always require an immediate replacement. Regarding the mods, you should be alright as long as they can't prove those were the cause of failure. |
06-26-2014, 11:31 AM | #5 | |
Rep 6,478
HPFP was fundamentally defective in design and execution.
06-26-2014, 11:42 AM | #6 |
Rep 131
thanks guys, and yes it was the 2AAF plausibility code - hasnt come back on since im going to give it a couple days and see what happens. Would that alter timing correction in my data logs? or more likely just bad fuel.
I understand what you are saying concerning the turbo recall as well.
2005 Audi S4
06-26-2014, 11:55 AM | #7 |
Rep 6,478
If it's struggling to hold fuel PSI you'd be getting numerous other rail pressure codes and the low pressure pump would likely peg full duty cycle in an attempt to compensate.
Far more likely any timing drops are the result of poor fuel/ lack of octane for the targeted advance.
