2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum M235 jerky upshifts. Bad tune or transmission issue?
      05-23-2024, 02:19 AM   #1
370_n55
Drives: m235i
Had a nightmare repairs with my m235i. Went for stage 1 tune, then they noticed that there's a leaky transfer case. As the shop didn't work on transfer cases, they recommended other shop. I brought car to them, they fixed the issue, however when fitting transfer case back they cracked, AT case, then they fixed that. Now it all seemed fine, however I get jerkiness in shifts especially when I hold rpms right before and upshift in sport mode, I feel slight jerkiness. When it warms up, the shifts are buttery smooth. At first I thought it has something to do with transmission, but as far as I think, if there was something wrong with transmission the issue would persist no matter the temperature of the transmission.
Now I think the jerkiness comes from tuning, like there's some kind of ecu limitation.
Has anyone experienced these symptoms, should I just detune/retune my car or maybe the issue maybe actually more serious than that and my headache will continue?
      05-23-2024, 08:22 AM   #2
MarcoZandrini
Drives: 2018 M240i
The first step in diagnosing a problem is to scan the various modules for codes.
      05-23-2024, 01:59 PM   #3
inverse121
Drives: 2016 M235ix
Can you simply revert the tune and see if the problem subsides?
      05-23-2024, 02:04 PM   #4
Shirazkhan
South Africa
56
Drives: F22,GO1,i20,POLO,BANTAM,BREZZA
Listen to Marco.Or else you wasting your time and money.
      05-24-2024, 05:17 AM   #5
370_n55
Drives: m235i
Car doesn't throw any codes.
Honestly thinking about doing full maintenance this summer, including transmission, detuning and enjoying the car in it's stock form. As there was zero issues before I decided to tune it.
However, yesterday and today car drove like a dream.
      05-24-2024, 08:43 AM   #6
MarcoZandrini
Drives: 2018 M240i
What did you use to scan the car?
      05-24-2024, 09:48 AM   #7
370_n55
Drives: m235i
BimmerLink
      05-24-2024, 11:50 AM   #8
zoro2001
zoro2001's Avatar
Drives: 2014 M235i
2014 BMW 235i  [0.00]
Check your tranny fluid level.
      05-24-2024, 03:23 PM   #9
370_n55
Drives: m235i
The fluid level is fine, actually it was overfilled.
      05-25-2024, 09:06 AM   #10
MarcoZandrini
Drives: 2018 M240i
The transmission was made by ZF . These transmissions don't like to be overfilled. The fluid level is critical. Fix the fluid level and report back.
