2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack 442M on my M235i
      06-01-2016, 04:07 AM   #23
leeadam
leeadam's Avatar
United Kingdom
468
Originally Posted by sublimegolf View Post
Just swap the senors out. My local tire shop charged me $150 to take my M235i sensors and put them in the 442M wheels. Works perfectly.
Let me know if you have any other questions.
oh ok well ill look into it..so the alloys have no rubbing at all then
      06-01-2016, 09:28 AM   #24
sublimegolf
Drives: 2016 M235i
Yup...not a single rub
      11-16-2016, 05:26 AM   #25
chihao
442m
how much did you pay for the swap???
thnks!
      11-17-2016, 12:23 AM   #26
sublimegolf
Drives: 2016 M235i
thnks!
$150
      11-17-2016, 08:37 AM   #27
chihao
wheels
it just worked out perfectly; looks stunning without having to put spacers on to kick the wheels out... I'm just wondering if BMW sell 442 style anymore...
      07-14-2017, 03:30 AM   #28
Kolyan2k
Drives: 2006 S2000
How's the ride and the handling compared to stock 18 with 245 rear?
      07-15-2017, 01:57 PM   #29
Acheron83
Acheron83's Avatar
South Africa
53
Drives: F22 M240i
2018 BMW X3 M40i  [0.00]
2016 BMW M240i  [0.00]
Got them on my F21:
BM235iW97.00
      01-23-2018, 12:55 AM   #30
still-miss-s2000
Drives: 2014 M235
How're the wheels working out? Still no rubbing or other similar issues (wear pattern, ride quality, etc)? I'm strongly considering these but am hesitant due to the fronts being 9 mm further out (rear are only 5 mm further out) compared to BMW-recommended offsets. The 442M are by far the nicest wheels I've seen on the M235.
      01-23-2018, 02:04 AM   #31
sublimegolf
Drives: 2016 M235i
I still have them and still no issues. (knock on wood )
      01-23-2018, 02:40 AM   #32
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
What size tires are you running? Any spacers fitted?
It's a straight swap from a 2014 335i M Sport. TPMS is the only thing that wasn't compatible.
Rear Tyres 255/35/19 (92 Y)
Front Tyres 225/40/19 (89 Y)
No spacers.
you should have dropped 5 on the tyre profile.
35 front and 30 rear to match original rolling diamter.
that's why arch gap is less as you kept the stock.tyre profile but moved up in rim diameter.
2014 M5
1990 E30 318i Touring
1999 E38 728i -sold
M235i - sold
Activehybrid 5 - sold
      01-25-2018, 01:10 PM   #33
Mr Carrots
Drives: Bmw
I didn't know that would even fit, lol
what happens when you go oversized on the tires on 19's??
      01-25-2018, 01:16 PM   #34
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
Just means the speedo is out.
Check out this website.
Will they fit.com
You,put in stock size and the new size and it gives you poke and speedo error etc.
2014 M5
1999 E38 728i -sold
M235i - sold
      01-25-2018, 01:23 PM   #35
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
Your mm is off as you didn't take into account the wider rim as well as the offset.
Front Wheels: 8Jx19 ET36 (p/n BMW 36117852493)
Rear Wheels: 8.5Jx19 ET47 (p/n BMW 36117852494)
These are the specs for the 442 M wheels
Front Wheels: 7.5Jx18 ET45 (p/n BMW 36117845870)
Rear Wheels: 8Jx18 ET52 (p/n BMW 36117845871)
And these the 2series 18"
Fronts poke 15mm more so like using a 15mm spacer on OEM fronts which is acceptable
Rears poke 11mm
That's using a 235/35 and 255/30 tyre size.o
2014 M5
1999 E38 728i -sold
M235i - sold
      01-25-2018, 02:44 PM   #36
sublimegolf
Drives: 2016 M235i
10k miles without problems so far.
Is there anything I should be looking out for?
Will the offset stress the wheel bearing?
      08-18-2018, 06:08 PM   #37
Scoupe
Australia
23
Drives: Mineral white M240
442m wheels on M235i
Hi
Wheels look great btw.
Do you notice any handling / performance issues (and mpg)with the larger setup.
Some suggest the bigger diameter slows acceleration and increases understeer.
And how much does it change your speedo reading (not sure how much error the 240i has on standard setup to begin with)
Cheers
      06-18-2019, 02:13 PM   #38
sniktun
United Kingdom
Drives: Z4 M40i
Nice. they all fit perfectly on mine as well
      09-17-2019, 07:48 AM   #39
mastrchee
mastrchee's Avatar
United Kingdom
84
Drives: i4 M50
No rubbing at all, even under load?
      10-16-2019, 06:24 AM   #40
sniktun
United Kingdom
Drives: Z4 M40i
No none at all. Had these on for about 7 months now so all good
