04-16-2022, 03:18 PM | #45 | |
Rep 7,469
04-16-2022, 03:27 PM | #46 |
General
63944
Rep 24,828
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
04-16-2022, 03:29 PM | #47 |
General
60842
Rep 19,783
///M Power-Belgium63943.50 NYG10840.50 |
04-16-2022, 03:37 PM | #48 | |
#buildnotbought
10965
Rep 4,910
Also here in europe where most gasoline is (or was in that era) completely ethanol free. €2400 in parts alone.
04-16-2022, 03:52 PM | #49 | |
Rep 7,469
Ive never heard of this brand but it should be better than nothing.
If you're running higher concentrations of e85 a tank of regular pump gas is needed between tanks of ethanol, unless top cylinder lube is used with every tank of ethanol.
04-16-2022, 03:58 PM | #50 |
General
60842
Rep 19,783
04-16-2022, 04:05 PM | #51 | |
General
60842
Rep 19,783
NYG10840.50 |
04-16-2022, 04:12 PM | #52 |
General
60842
Rep 19,783
It's worth for some cars using E10 fuel to tank with E5 from time to time. Ethanol is not good.
04-16-2022, 04:23 PM | #53 |
General
63944
Rep 24,828
I'm pretty sure Ferrari nailed it completely => https://nl.motorsport.com/f1/news/fe...voren/9919926/
04-16-2022, 07:07 PM | #54 | |
Rep 5,440
Drives: Beige G31 40ix m sport
My old (2006) e92 N54, which I've owned for getting on for 11 years now, which has been running 380 bhp for over 8 years is still on its original injectors & has now covered 125,000 miles & has never had injector issues Maybes because I only use Shell VPower
G31 40ix M Sport
E92 335i. E36 328is coupe E39 540i V8 6SP manual E34 3.6 M5. E34 525i sport. VW Jetta Mk2 GTI 16v. 1679cc 1967 resto-cal beetle |
F87source7305.00 |
04-16-2022, 07:10 PM | #55 | ||
Rep 7,469
I can say that brand names and marketing is not everything, for instance there are botique oils that have a huge marketing presence and are super expensive. However those engine oils pale in comparison to cheap walmart oils like castrol edge and pennzoil - in terms of used oil analysis and actual addative packages, sheer strength etc. So brand names aren't everything. Quote:
1) Superior octane rating, E100 has 100 octane (rated in AKI) which is far higher than any pump gas - it is essentially race fuel allowing for much more agressive timing and boost based tunes. 2) It burns incredibly clean, so there are essentially no carbon deposits on pistons and valves vs. gasoline. 3) The evaporative cooling effect is very nice and helps engines run alot cooler on track. Other than that the few draw backs are minimal, such as it is more agressive on rubber but fuel lines should be teflon lined anyways. It does require more fuel to be burned to make the same amount of energy - but the anti knock properties more than make up for it. And it lacks lubricity, but top cylinder lube solves this issue and you also get the much cleaner burning fuel.
irunalot1518.00 |
04-16-2022, 07:33 PM | #56 |
Rep 4,668
Drives: BMW
Why do I get the feeling that Ferrari is going to dominate their home race(s)?
Killed by Death12755.00 |
04-16-2022, 08:04 PM | #57 | |
#buildnotbought
10965
Rep 4,910
But if Ferrari comes with updates that greatly increase power.... For LEC it's nice that the Ferrari probably will be extremely fast in Monaco compared to the competition, with it's slow corners etc. So he's bound to win for his home audience after last year's disaster.
04-17-2022, 02:56 AM | #58 | |
General
60842
Rep 19,783
04-17-2022, 03:33 AM | #59 | |
Rep 7,469
Plus I'm North America all fuels (except some premium blends) have e10 in it, and there are zero issues with year round use in all climates. In regards to the catalytic converter there should be zero issues, if anything it would be even easier on the cats because ethanol blended fuel produces less NOX, SOX, POX and aldehyde emissions vs. gasoline because it contains much less gas and all of its associated additives. Other than that emissions would still be CO2 and water just like gasoline. If anything ethanol fuels would be better for the cats because it burns so much cleaner than gasoline so there will be less carbon soot going through the cats. Literally ethanol is a much better fuel imo. Sure there's less energy per volume, but you get many more benefits to compensate. I wish we went to e85 + turbos + hybrids (turbo hybrids are awesome! Just like the McLaren p1 and similar) before we went to electric cars.
irunalot1518.00 |
04-17-2022, 03:59 AM | #60 | |
General
60842
Rep 19,783
04-17-2022, 04:13 AM | #61 | |
Rep 7,469
So AKI is the average of the 2 octane measurements. We generally have: 87, 89, 91, 93, and 94. Although 93 and 94 are only found in select areas.
04-17-2022, 07:55 AM | #62 | |
General
63944
Rep 24,828
Binotto said : It's a bad idea to come with upgrades in Imola regarding the sprint-race and the lack of time to test new upgrades. That's why the Ferrari upgrades are planned between Miami and Spain.
04-17-2022, 01:48 PM | #63 | |
General
60842
Rep 19,783
04-17-2022, 01:57 PM | #64 | |
General
63944
Rep 24,828
It couldn't be a better moment for the 2022 Ferrari PU with the engine freeze ..
04-17-2022, 01:59 PM | #65 |
General
63944
Rep 24,828
04-17-2022, 02:09 PM | #66 |
General
60842
Rep 19,783
