04-17-2015, 04:57 PM | #1 |
Rep 845
Diffsonline M235i Differential
Fellow Track Rats,
My new differential just showed up at the shop today -- getting it installed Monday. Pics to follow along with a very detailed review regarding street and track impressions. |
04-18-2015, 03:40 PM | #4 |
Rep 845
I don't know what installation cost is yet, but the differential itself was 3800. It was custom built though, so that factors into the price. I also raised my final drive ratio to 3.46 from the stock 3.08. If you wanted a quaife or a cheaper clutch type, you could get away with much cheaper.
04-18-2015, 06:24 PM | #5 |
Rep 201
Definitely interested in getting same. I messaged diffs online but no response. I look forward to your review from on track
2015 6M Black Sapphire Metallic | MPE w/Carbon Tips | Digital MP Steering Wheel | Carbon Interior | StopTech Slotted Rotors | Pagid RSL1 Race Pads | KW Clubsport Coilovers | DINAN Stage 2 and Carbon air intake | Clutch Masters Lightweight Performance Clutch and Flywheel | Hotchkis Anti-Roll Bars | Enkei RS05RR 18" Racing Wheels
04-18-2015, 07:31 PM | #6 |
Rep 845
04-20-2015, 11:43 AM | #7 |
Rep 845
It's here . . .
04-20-2015, 05:27 PM | #9 |
Rep 845
Picture of the differential.
Also, for those of you thinking of doing this, removing the rear end on an M235i is . . . interesting. Most BMW's (even the F30) have a bolted differential (for the axels and driveshaft). However, the M235i has splines (I think they're mechanically superior, but EXTREMELY HARD to fiddle with/swap out differentials). Will probably be a few more days in the shop |
04-21-2015, 08:07 AM | #10 | |
Rep 2,672
04-21-2015, 09:49 AM | #12 |
Rep 845
04-21-2015, 10:45 AM | #14 |
Rep 845
04-21-2015, 01:03 PM | #16 |
Rep 845
Called the shop. It'll be done today.
I'll probably have some fun with it tonight down the PCH (after traffic is gone) -- maybe some easy canyons. Don't want to make it too hairy -- that shit is hard (and dangerous) when its dark outside. Just so you all know, the differential spec is as follows: Diffsonline 3-Clutch Custom REM Polished Gears 35/60 Ramps 100 ft/lbs preload (will probably settle closer to 80 ft/lbs) 3.46 final drive ratio I'm very excited for (1) the extra corner stability and traction (that "dig in" feeling accelerating around corners) and (2) the drive ratio increase (12% torque increase through the power band from mechanical advantage). Should definitely liven the car up. I am also very interested to see how it behaves going into corners with that 60 ramp lockup. It seems like a 60 degree ramp would be a subtle lockup (probably is), but I wouldn't mind a little push going into/out of corners -- car tends to oversteer just a tad right now. |
04-22-2015, 06:59 AM | #17 |
Rep 197
I'm afraid the differences shall be unnoticeable on the street and so subtle on the track, except for slow speed corner exits if you had spinning before, that it would take a road racing professional to appreciate and analyse the differences.
04-22-2015, 07:50 AM | #18 | |
Rep 201
04-22-2015, 08:36 AM | #19 |
Rep 197
If your lap times are consistently within the same second, and very close to what a pro would do with the same car, I agree.
04-22-2015, 11:00 AM | #20 | |
Rep 845
04-22-2015, 11:33 AM | #21 |
Rep 201
Did you get one of those charts from diffs online that shows the maximum speed in each gear? How different is it from stock now? Definitely want to know if you feel like it accelerates faster. If you can get some timing data on a strip or track please post.
04-22-2015, 11:39 AM | #22 |
Rep 845
I did, and it's a significant boost -- about 12% increased torque from mechanical advantage at all RPMs.
