01-07-2024, 09:02 PM | #1 |
Rep 54
ISTA+ ABS Bleed - Do I Need Battery Charger?
Hi guys,
I'm wondering if I need a voltage regulator hooked to the battery when I perform ABS bleed procedure through ISTA+. Or can I just just charge the battery to 100% before starting the procedure? I've heard that ISTA+ can brick the car if there is sudden drop in voltage or something..... Thank you! |
01-11-2024, 09:06 PM | #2 |
Rep 5,776
I’ve seen it done with and without a battery charger. It’s not a very long process but, if you have the charger, just play it safe and do the procedure with the charger.
