2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions DIY: MirrorTap & BlendMount
      08-03-2014, 06:14 PM   #23
asm777
Drives: BMW
Originally Posted by abirmaher View Post
We don't have the HBA option in the US so this isn't an issue here.
Sorry, I meant we have "5AC Automatic high beams" which adds the camera to the rear view mirror so anyone who orders that option will have the mounting location issue due to the extra hardware...
On the other hand, you get the benefit of being able to re-enable HBA... which I'll take any day for having to offset the camera! =)
      08-04-2014, 12:21 AM   #24
abirmaher
abirmaher's Avatar
  [0.00]
2018 BMW M2  [10.00]
True true, didn't think of that. Im not a fan of the auto high beams so I didn't spec that but if i would have thought about enabling that when ordering I would def have done it so i totally get where your coming from.
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010
The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35
      08-06-2014, 04:08 PM   #25
asm777
Drives: BMW
Thanks for posting this! Made it really easy to quickly wire the detector.
However, need to rethink the mounting location due to the HBA camera which makes mounting directly underneath the mirror impossible. Slightly offset to the right next to the HBA camera with the radar tucked under the mirror should work but need to decide whether to use a permanent mount or the new StickyCup...
Well, decided to go with the StickCup which places the detector further into the cabin than the permanent mount (which puts it right up against the glass) so that the display sits right under the mirror.
Quite pleased with how it turned out and thanks again to the OP for posting the detailed info on the wiring which made this install a breeze!
Here's the view from the driver's seat:
Offset to the right due to the HBA camera assembly blocking the mounting area that was chosen by the OP:
View from outside:
      10-22-2014, 12:40 PM   #26
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Drives: 2018 Audi S3
Great write up thanks for sharing and putting up all the links.
FBO-PS1 and stuff
      12-11-2014, 12:10 PM   #27
PrazVT
PrazVT's Avatar
Drives: '21 M240i 6mt (soon)
Hey great write up and pics Op and others!
I got the parts to install this yesterday. I just wanted to get some additional insights into removing the plastic cover.
Are there just some clasps of some sort connecting the 2 halves? ie, when I stick a credit card in the middle (from the bottom of the assembly), I'll figure it out? Any tips here would be appreciated!
Thanks,
Praz
2018 Audi A4 6mt + Sport Plus (retired)
2015 228i M Sport 6mt + Track Handling Package (retired)
2012 328i Sport 6mt (retired)
      12-11-2014, 03:13 PM   #28
abirmaher
abirmaher's Avatar
  [0.00]
2018 BMW M2  [10.00]
Thanks,
Praz
You just have to kind of force it between the two sides and wiggle up and down and once one of the clips gives then the other will be easy. Putting to back on is much easier just push both sides back together.
Follow my builds:
      12-11-2014, 04:04 PM   #29
PrazVT
PrazVT's Avatar
Okay thanks! Just wanted to make sure before I started messing with it
      12-11-2014, 07:49 PM   #30
hoppy6698
hoppy6698's Avatar
Drives: M235i, Estoril Blue on Black
Yes, the clips are not very thick or snap together, they just sort of slide into position. It pops apart very easily.
      12-11-2014, 09:46 PM   #31
PrazVT
PrazVT's Avatar
...And done! Thanks again abirmaher for the DIY instructions. Managed to install the Blend Mount without too much trouble
      12-11-2014, 09:46 PM   #32
abirmaher
abirmaher's Avatar
  [0.00]
2018 BMW M2  [10.00]
Perfect.
Follow my builds:
      12-11-2014, 10:17 PM   #33
PrazVT
PrazVT's Avatar
You're right - the left one popped out first and then the right one came out with a little jiggling.
      01-03-2015, 05:02 PM   #34
nzw212
Drives: M235XI, Maserati, Ducati
Very nice and great DIY.
      01-26-2015, 10:13 PM   #35
Kidu
Drives: 2015 M235i EBII, RWD, 6spd
Quick stupid question - On the blendmount website, there are a lot of them under M235, one is actually on a waiting list! Which is the correct one for a US Spec 2015 M235? also On amazon, I see a Blendmount too, is that the right one?
      02-04-2015, 09:39 PM   #36
Kidu
Thank you!!!
Just installed everything.... Passport 9500ix hanging from my mirror like the car came with it!!!!
Absolutely amazing, I used to get really annoyed by the up and down motion of the detector on suction cups in earlier cars but this is phenomenally stable!
Thank you so much for the DIY! Really dont know how I would have figured out (without burning something up first) where to plug in the Mirrortap.
      02-04-2015, 10:45 PM   #37
abirmaher
abirmaher's Avatar
  [0.00]
2018 BMW M2  [10.00]
Happy to help!
Follow my builds:
      03-29-2015, 07:01 PM   #38
bacampbe
Drives: 2024 Z4 M40i PB
I just installed the MirrorTap in my M235i Convertible. It was as easy as described with one exception. I pulled the socket up where I could more easily unplug the harness, and it took quiet a bit of fiddling to line the socket up to nest back where it came from. If I did it again*, I might not even unplug the connector.
I haven't done a blend mount, because I'm afraid my fairly chunky V1 will block my view of cross traffic at intersections. (I already find the rear view mirror in most imported cars to sit too low for my liking.)
[*] ... which I plan to, for my wife's 2012 328i. Should I expect it to be wired the same as the 2er?
      03-29-2015, 07:02 PM   #39
abirmaher
abirmaher's Avatar
  [0.00]
2018 BMW M2  [10.00]
Should be similar
Follow my builds:
      05-20-2015, 10:14 PM   #40
Bixby
Drives: M240
Just confirming that the mirror tap will only work on cars specced with auto dimming mirrors (or do the necessary wires still run through there)?
      05-20-2015, 10:16 PM   #41
abirmaher
abirmaher's Avatar
  [0.00]
2018 BMW M2  [10.00]
That is my understanding yes.
Follow my builds:
      06-30-2015, 07:02 PM   #42
kevinaaa2gundam
kevinaaa2gundam's Avatar
Drives: 228i
Just hardwired my detector. Took only 10 mins. Thanks for the DIY.
      08-01-2015, 09:03 PM   #43
chemh0ser
Drives: M235ix Mineral Grey
I'm having an issue wi my install. First, I didn't get that breaded looking wire. I just got the rj11 wire with an inline fuse. Hooked everything up to my V1 and it was working. Then hooked up my concealed display via a splitter and it worked for a bit then lost power. Probably blew the fuse but
Won't know til I can check for sure (it got dark out). Has anybody come across this issue? Think I can use a higher amp fuse to get all the accessories working? Any thoughts?
      08-02-2015, 06:36 PM   #44
chemh0ser
UPDATE. the pins weren't making good contact in the molded plug. Going to go a different route other than mess around with the plug.
