05-28-2018, 01:09 AM | #1 |
Rep 81
Easy entry with bimmercode?
I have a 228i and I use Bimmercode to code my car on my android. I've done some searching but I haven't found an answer.. can you code easy entry on the Bimmercode app?
2014 228i M Sport w/ M235i Exhaust, VRSF DP, Stage 2 AA ODB2 Tune
05-29-2018, 06:29 PM | #2 |
Rep 121
I have tried this with my 2018 230i without success. The values in the seat module are supposed to be:
3000 SM_GLOBAL ->*EINAUSSTIEGSHILFE*= Modus_FA_SLV 3012 EAH -> EAH_VERFAHRWEG_SLV_PHYS = Werte=00, 28 3012 EAH -> EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS = Werte=00, 3C For the last two parameters, however Bimmercode for Android only allows "initwerte." Perhaps it's different in the iPhone version. |
05-30-2018, 01:03 PM | #3 |
Rep 39
I have coded my 2018 M240i for easy entry with bimmercode. I left the last two values at initwerte initially. Easy entry only worked for my GF and not me because I already had the seat too far back for the initial rear legroom limit. I had to go back with esys and change that last value to 00, 0F in order for easy entry to work. Hope this helps!
///M Houbi1655.00 |
05-30-2018, 01:26 PM | #4 |
Rep 121
Do you remember if you had to code any other parameters? I also coded (in FEM):
30C0 EINSTIEGSH_LN_AKTIV set to: aktiv 30C0 EINSTIEGSH_NG_AKTIV set to: aktiv 30C0 PRIO_ACHSEN set to: 1 although these have to do with electric steering wheel adjustment, which I (we?) don't have. Couldn't get it to work. :-( |
05-30-2018, 11:45 PM | #5 | |
Rep 39
05-31-2018, 12:40 AM | #6 |
Luxury at the redline :)
9105
Rep 7,563
You guys might screw up your ECU if you keep coding stuff randomly, that you're not sure about...
Here is the coding for 'Comfort Exit/Entry' The werte "64" = 100mm of retraction, lower the number from 64 or convert the hex value entry to decrease the retraction, if you please. I've done it on a couple of BMWs, it's guarantee to work. I'm not sure if it works for 2018 though, since some folks been having issues with the new MY and coding. Good luck. 19bis Driver Seat: 3000 SM_GLOBAL -> EINAUSSTIEGSHILFE = Modus_FA_SLV 3012 EAH -> EAH_VERFAHRWEG_SLV_PHYS = Werte=00, 64 3012 EAH -> EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS = Werte=00, 00 Passenger Seat: 3000 SM_GLOBAL -> EINAUSSTIEGSHILFE = UKNOWN, WERTE=03 3012 EAH -> EAH_VERFAHRWEG_SLV_PHYS = Werte=00, 64 3012 EAH -> EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS = Werte=00, 00 |
///M Houbi1655.00 |
06-01-2018, 12:16 AM | #7 | |
Rep 39
11-01-2019, 06:51 AM | #9 |
Rep 348
Any update on if this is working? I have a 2020 if that helps.
11-14-2019, 03:02 PM | #10 |
Rep 45
Hi,
I have the first "global" value listed below in BimmerCode but I do not have the 2nd of 3rd . Can anyone advise as to how to get this to work? 3000 SM_GLOBAL -> EINAUSSTIEGSHILFE = Modus_FA_SLV 3012 EAH -> EAH_VERFAHRWEG_SLV_PHYS = Werte=00, 64 3012 EAH -> EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS = Werte=00, 00 |
12-12-2019, 05:46 PM | #11 | |
Rep 12
Any help would be appreciated! |
12-12-2019, 07:07 PM | #12 | ||
9105
Rep 7,563
When I attempted to recode the Easy Exit/Entry, initially, it also was not working. Funny, I then got tired of messing with it and left. The next morning it worked fine. I suspected that when the battery is close to being drained, it's doesn't commence. Double check the parameters, code it in again, then power down the vehicle and let it go to 'sleep mode,' then retry it. This might solve your issue. I also notice then when try to retract and detract the seats with the physical control, after a certain distance, it stops and you have repress the button to get it going again. I guess this must be a safety feature they implemented via the new software integration. Do you happen to know the iStep version was uploaded to your vehicle? |
12-13-2019, 10:36 PM | #13 | |
Rep 12
I'll see if it has taken effect tomorrow. I spent about half an hour trying to get it to work. I don't think it has anything to do with the battery though because by the time i was coding, I had already driven for around 2 hours. And not sure of the iStep version. How can I check? |
12-14-2019, 06:56 PM | #15 | ||
9105
Rep 7,563
I'm not sure why it's not working, I coded a 2018 3 series and it activated fine. All I could say is triple check the coding and try again. I ran out of suggestions.. Sorry. |
12-15-2019, 02:24 PM | #16 | |
Rep 12
The chair goes back the full 100mm even though I had changed the value from 64 to 32 but I'll play around with the setting again. Thanks again for the help |
aerodavew9.50 |
12-15-2019, 05:18 PM | #17 | ||
9105
Rep 7,563
Yea, mines I had coded severals time, right after a firmware update and it still didn't work after hours of trying.. I gave up because the car indicated that the battery was getting drained, so I just accepted that new software ate the old hack feature. The next morning, as jumped in and the seat started moving forward, 'I was WTF' but whatever. : Maybe someone one day will solve this mystery. |
12-24-2019, 12:05 PM | #18 |
Everyday I'm shuffling
449
Rep 1,098
01-07-2020, 02:35 PM | #19 | |
Rep 147
For anyone in doubts, I’ve coded easy entry exactly as per Poochie:
I also had 3015 EAH instead of 3012. My car is a 2017. My I-Level is F020-18-11-531 After coding the car I locked it, unlocked, turned it on and moved it on my driveway. After I shut it off and locked it, the seat had retracted by itself. Now it works 😎 |
Poochie9104.50 |
01-07-2020, 03:21 PM | #20 | |
449
Rep 1,098
3012 EAH does not have EAH_VERFAHRWEG_SLV_PHYS nor EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS parameters under it. Would be interested in knowing what others have done. |
03-18-2020, 09:45 PM | #21 | |
Rep 7
Worked great
03-20-2020, 01:53 PM | #22 |
449
Rep 1,098
