2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes Ohlins, KW, M3LCA or combo?
      10-31-2019, 12:04 AM   #1
helloelectro
Drives: 2018 BMW m240i
I was considering the m4 LCA upgrade for my f22 m240i, but now wondering if Ohlins or KW coil overs may be a better option. Or is it worth doing the LCA and coil overs? Price excluded here, what would you do?
I may do a track day or two, or a drag race for fun, but enjoy spirited driving in the country. If that matters. This is also a daily, but I'm ok with some harshness. Suspension is currently adaptive too. Which makes everything more pricey but again, excluding price.
      10-31-2019, 11:00 AM   #2
dradernh
dradernh's Avatar
4352
Drives: 2017 M240i
Originally Posted by helloelectro View Post
what would you do?
See my signature.
The coilover kit includes camber plates. The car has 2.n° of negative camber front and rear. The setup is extremely effective for spirited and track driving. The limited slip differential and aluminum rear subframe bushings help quite a bit with that.
I recently added the H&R front swaybar to the list.
      11-05-2019, 10:01 PM   #3
Nugget
Nugget's Avatar
650
2011 BMW 135i  [10.00]
I went with Ohlins and Vorshlag camber plates and kept stock LCAs.
The M3 LCA limits how wide you can go with front wheels.
Mine was also adaptive which I got coded out.
      11-05-2019, 10:13 PM   #4
helloelectro
How do you like them? What was your install cost?
Thanks!!
      11-06-2019, 07:09 PM   #5
Nugget
Nugget's Avatar
650
Thanks!!
I love them. I went with different swift springs than what comes with the kit though, harder on the front, softer on the rear.
Install cost was the same as any coilovers, plus alignment.
I bought them from HP Autosport and he sent them with the front struts already assembled with the swift springs and camber plates.
I'm in Australia so labour costs probably aren't comparable.
      11-06-2019, 10:25 PM   #6
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Coilover with camber plates means you don't have to go the M LCA route for more negative camber or add the thrust arm with spacers to avoid the tire running on the front wheel liner. If you want a more precise handling Whiteline and SPL both make a good adjustable bushing/bearing for the thrust arm.
TCKR and Ohlins are both good choices for coilovers.
      11-08-2019, 10:26 AM   #7
helloelectro
Are Ohlins available for an 18 m240i? I've been looking around online and can't seem to find anything. I have adaptive suspension but would probably opt to code it out.
      11-10-2019, 06:47 PM   #8
Nugget
Nugget's Avatar
650
The F30 kit will work but I would recommend a softer rear spring.
      11-13-2019, 08:54 AM   #9
helloelectro
Why did you go with a softer spring? Which did you choose? Thanks!!
      11-13-2019, 07:00 PM   #10
Nugget
Nugget's Avatar
650
Ohlins provide a 16kg rear spring which made the car not very nice to drive on the road in my opinion.
I went with a 12kgs swift spring on the rear and 7kg on the front.
This is some spring info I put together.
      11-14-2019, 09:13 PM   #11
helloelectro
Thanks! I'll keep this in mind if I move forward with it.
      03-21-2020, 08:13 PM   #12
Shadowfax028
Drives: 2016 BMW M235i
I put the Ohlins M2 kit on my M235i. totally worth it...Some machine work will need to be done to make everything work.
But the payoff. WOW!!!
WolfGTI716.00
      03-22-2020, 01:28 PM   #13
WolfGTI
WolfGTI's Avatar
2002 MINI Cooper S  [0.00]
2015 BMW X1  [0.00]
See below for my thoughts so far. - No regrets! - Ohlins, Turner monoballs, full poly bushing in the rear, M3 LCA's
Caveat - I am still on my winter wheels/tires - will update when I get the summer wheels/tires on.
Ride - I have the coilovers set to the recommended settings from Ohlins for the street. It firm and well damped non of that 'pitching' back and forth that occurs with the factory suspension.
Steering feel - Ground control camber plates with the monoballs and F80 LCA's make a major difference in front, the car feels very precise and you can actually feel the road. I have to say if you do nothing else, this is a must do mod.
Rear subframe poly and Delrin diff bushings - There is none of the 'squishyness or squirelly' feeling I felt when changing lanes under hard acceleration or over ruts in the road when it would feel like the back end was wandering a little. There is a little more NVH from the diff primarily - but if you're not really sensitive you will not notice it. The car feels more responsive when you gas it- like drive line lag is gone - I guess it feels more urgent or direct is a good way to describe it.
Handling -haven't had the opportunity to push it yet - but the car certainly felt more planted on the couple off ramps / on ramps I drove on heading home.
Lastly - I was not looking for the slammed look - don't get Ohlins if you want to slam the car - height is set at 10 mm less than stock.
      03-22-2020, 01:41 PM   #14
ifobd
ifobd's Avatar
32
Drives: 2017 M240i xdrive
[COLOR="Blue"]Caveat - I am still on my winter wheels/tires - will update when I get the summer wheels/tires on.[/COLOR]
What subframe/diff bushings did you get?
      03-22-2020, 08:04 PM   #15
WolfGTI
WolfGTI's Avatar
2015 BMW X1  [0.00]
SuperPro.
      03-23-2020, 09:11 AM   #16
Maynard
Drives: 228iX & M2C
How expensive was the rear install? I've heard it is a major process.
      03-23-2020, 12:11 PM   #17
WolfGTI
WolfGTI's Avatar
2015 BMW X1  [0.00]
PM Sent - yes the rear is pretty involved - removed the subframe, and took out every arm / link and the diff bushings -and replaced with poly - very labor intensive. You have to realign the car after as well.
Maynard3833.00
msendit418.00
      03-26-2020, 11:21 AM   #18
I ended up with KW's w/ the KW camber plates. Already had the M4 LCA/TS's so they remained. I am running 9" wheels w/ 255 RE71r's no problem, but wouldn't work without the TS's installed as well, imo
If you're gonna go through the trouble of the rear subframe bushings I'd recommend doing the 4 links as well. You'd at the very least want adjustable rear toe arms to get the alignment adjusted back to factory after the lowered ride height and added camber otherwise the toe angle may not be "ideal" for wear etc. Also if you want to dial in the perfect alignment you'd want that adjust-ability. Megan racing has really decent quality link (for the price) I ended up doing all 8 of them, they have a metal ball joint style bushing with some forgiveness/rubber, and the added adjust-ability w/ thread protectors built in.
D
