2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Weird Misfire on START engine
      10-17-2019, 10:49 AM   #1
Matanaba
Drives: BMW M3 E92
Hello
I have 235M 2016
The last two weeks as I drive the car I have strong SHAKES in the car
Sometimes he also switched off. Happens when the vehicle is off \ or COLD START
Sometimes, if I push the throttle a little bit it balances
I connected OBD to ISTA. And I found that every time there is a MISFIRE from a different cylinder
Still, I switched to 6 new plugs. But still the same problem
When I reset faults, and motivate. The vehicle is excellent!
I read in the forum about previous issues, the problem in INJECTORS.
My question, if the problem is with Injectors, why does MISFIRE move to another cylinder every time? After all, if INJECTOR malfunctioned, the malfunction would be in one cylinder. But they are changing
Is there a way to check Injectors?
Can example INJECTOR, of cylinder number 4, affect cylinder 6 \ 5 \ 3 \ 2 \ 1?
Thanks for responding
      10-17-2019, 12:07 PM   #2
este
N54 to N55
este's Avatar
66
Drives: e92 335i (sold) / M235i 6mt
Before checking injectors, I'd check/replace the coil packs. Even though they usually don't all go out at once, so if you see same one or two cylinders misfiring replace the coil in those.
      10-20-2019, 10:49 AM   #3
Matanaba
Drives: BMW M3 E92
FIXED
The problem was bad bad bad fuel .
TNX
      10-20-2019, 09:48 PM   #4
Zyzzthetic
6 speeeeeeeeeed
Zyzzthetic's Avatar
Drives: 2017 M240i 6-Speed Manual
Originally Posted by Matanaba View Post
FIXED
TNX
Where were you filling up?
17' 240i 6MT - black on red
      10-21-2019, 01:58 AM   #5
Matanaba
Drives: BMW M3 E92
in israel..
      10-21-2019, 02:49 AM   #6
Zyzzthetic
6 speeeeeeeeeed
Zyzzthetic's Avatar
in israel..
Interesting
