09-13-2019, 08:55 PM | #1 |
Rep 555
Wheel fitment with Dinan springs + M4 LCA
Right now I am running Dinan springs, and VMR V804 wheels at 19x8.5 front et35, and 19x9.5et45 rear.
If I did the M4 LCA upgrade, would I have an issue with wheel fitment? Would this basically make it necessary to do the M4 TS as well?
10-08-2019, 01:35 PM | #4 |
Rep 197
OverRev found "front tires (235/40/R18 RE71R on 18x8 ET40) rubbing a lot." He is on H&Rs so 1" front drop.
rwalker found "Before LCAs I had -2.5deg camber to fit my 255/35r18 fronts on 18x9et36. F8x LCAs introduced another 0.9deg, about 1" of forward movement, leading to rubbing in the front upper part of the fenders, requiring fender rolling." Icy J found "had to replace 10mm spacer with 5mm and raise height twice to minimise rubbing." ..... notice this man is running a poke i have never really seen before up front and slammed on 225 tires. Bee Pee found "rough measurement of the M4 arms being approx 1/2" longer" Also refer to my post below, i put together yesterday, if you want to do this on a budget and right.... https://www.2addicts.com/forums/show...&postcount=237 also, note..... i am doing it with Dinan springs and VMRs 18x8.5et45 on 235 tires.... Yes e45 no spacers Will report back! Waiting on all parts and my connection for custom machined spacers.... |
10-08-2019, 04:36 PM | #5 |
Rep 3,496
Are these oversized units that you're having turned down on a lathe?
10-08-2019, 05:14 PM | #6 | |
Rep 197
10-09-2019, 07:04 PM | #7 | |
Rep 555
This is pretty useful info, and i had looked quite a bit, but none of it quite applies directly to my setup exactly. Since i have 19x8.5 front et35 with 225/35/19, but I'm also on dinan springs which are milder. I am very curious about your results! |
10-10-2019, 09:13 AM | #8 | |
Rep 197
The speedo error says mine is -0.73%, so your final tire diameter will be alittle more. Although their is a 10mm difference in wheel offset, the tire variation we have seems to almost even things out. Look how close the tire limit is on our outsides... if i have no rub, and this photo is relatively accurate, you shouldnt have much of an issue either. Will report back in a few weeks when installed. |
10-13-2019, 11:54 PM | #9 |
Rep 105
I'm gonna be right here with you in this fitment process. just ordered m4 lca's, ts and Dinan springs.. i really want to fit 245/35ZR19 front and 275/30ZR19 rear but that might be ballzy.. and not a fan of poke which I'm pretty sure would happen up front.
i have a shot(dented and bubbled) set of VMR v703's Front: 8.5 x19 et 40 with Michelin pilot 4S 235/35 R19 Rear: 9.5x19 et 45 with Michelin pilot 4S 265/30 R19 https://www.2addicts.com/forums/show....php?t=1603999 I will confirm fitment after the arms and springs.. this setup is fast AF but i would love one more size up if i can I'll keep ya posted |
jondagger90.00 |
04-26-2020, 04:41 AM | #10 | |
Rep 72
