07-07-2019, 05:27 PM | #1 |
Rep 485
Oil Filter Housing Gasket replacement
Thoughts?
2015 M235i xDrive 8AT
07-07-2019, 07:58 PM | #2 |
Rep 1,117
Drives: 2015 BMW M235i
I was thinking about this too. It's weird how it doesnt seem common on the 2 series forums as much as the 3. Doesnt the m3 also use the ohfg setup?
07-07-2019, 10:06 PM | #3 |
Rep 774
Drives: 2015 435i grand coupe xdrive
I replaced mine at 82k it's such a normal bmw oil leak at this point I don't think anyone talks about it
2015 435i grand coupe xdrvie (current)
2006 F250 powerstoke CCSB (current) 2014 M235i Black on Red (SOLD) / 08 e90 335i MT Pure Stage 2 High flow (SOLD) 08 128i 6MT (SOLD) / 08 335i 6MT Pure stage 1 (SOLD) |
07-07-2019, 10:44 PM | #4 |
Rep 5,334
I've been on this forum for 4 years now. I can't recall someone reporting that they had one leak. I'm sure they do but perhaps the better oil cooling system on the M235 helps extend the gasket life.
I wouldn't bother replacing it until it leaks. I check under the hood at least once every 2 weeks and this is an area I inspect. It will weep first and then leak slowly. The biggest risk is letting it go for too long and the oil gets on the accessory belt, the belt slips off, and gets pulled into the oil pan. Such a weird freaking issue. |
07-10-2019, 09:13 PM | #6 |
Rep 485
Looks like some of the ongoing E46 issues have been ironed out and they are showing up much later for the F22's. That's good to know.
07-11-2019, 12:41 PM | #7 |
Rep 774
Like I said I had to replace mine at 80k its a common oil leak, don't be ignorant.
07-11-2019, 01:16 PM | #8 |
Rep 5,334
But was it leaking? We're not being "ignorant", but there's no sense in replacing it until it does start leaking.
07-12-2019, 10:57 AM | #9 |
Rep 1,184
Maybe I'm thinking of something else, but don't you replace it with every oil filter install?
The large black oring around the bottom of the oil filter housing? So far every oil filter that I've bought comes with a small green o ring and a large black one for the filter housing. I've replace both every oil change? |
07-12-2019, 11:05 AM | #10 | |
Rep 485
The one we are talking about is the internal gasket where the oil filter housing interfaces with the engine. https://www.ecstuning.com/b-genuine-...428637821~oeb/
07-12-2019, 01:56 PM | #11 |
Rep 1,115
Might started leaking slightly at 65,000km and the dealer replaced it at the end of warranty. They said it's inevitable that they all start leaking so might as well replace while it's free.
07-13-2019, 02:53 PM | #12 |
Rep 774
Yes mine was leaking. You need to be careful with these engines. If the oil leaks onto the belt there is a chance the belt will slip back behind the crank seal and lock up your engine. May as likely as the N54 but there is still the chance.
11-11-2019, 08:22 AM | #13 |
Rep 12
Drives: BMW M235i, Honda S2000
Any how to guides on this, mostly for the torque specs lol? Im planning on doing this preventatively. It's a common issue, the gaskets are cheap. I'm all about preventative maintenance. Im just under 70k but it is about 5 yrs old now. I think you can also end up with coolant in the oil if the oil cooler gasket leaks?
If anyone's done this, did you also change all the bolts and pressure sensor? Or just the gaskets? |
11-11-2019, 09:53 AM | #14 |
Rep 485
Unlike E46fanatics, where there was a hoard of people working their cars, the F22 does not attract a lot of people to work on their cars much.
Either that or the F22 DIYers do not go to forums much. Or we are in a wrong forum. I have not found an active DIYer for F22 that is similar to the E46fanatics.
11-11-2019, 10:35 AM | #15 |
Rep 1,115
11-11-2019, 10:57 AM | #16 | |
Rep 5,334
I don't understand why you'd replace before it's leaking though. It typically doesn't fail catastrophically. The big issue is people that never pop the hood routinely and inspect for leaks. A bad longterm leak at the OFHG can get on the accessory belts and result in the belt slipping off the pulleys and getting sucked through the seal behind the crank pulley. |
11-11-2019, 11:48 AM | #17 |
Rep 1,115
I wouldn't replace preemptively, people have had coolant oil contamination issues that resulted in spun rod bearings right after replacing this gasket.
11-11-2019, 06:52 PM | #18 | |
E4 Mafia
308
Rep 408
Drives: E30, E36/5, E46, F22, F30
Garage List 1990 BMW 325i [0.00]
1998 BMW 318ti [0.00] 2003 BMW 325i [0.00] 2015 BMW 335i [0.00] 2015 BMW M235i [0.00] |
Squad - '90 E30 325i MT (225k) | '98 E36/5 318ti MT (153k) | '03 E46 325i MT (152k)| '15 F22 M235i MT (60k) | '15 F30 335i MT (80k)
KIA - '91 E30 325i AT (146k) | '02 E46 325i MT (212k) Bring back the purple M stripe |
11-14-2019, 05:35 PM | #19 |
Rep 12
11-14-2019, 05:37 PM | #20 | |
Rep 12
Dylan861330.00 |
11-18-2019, 04:29 PM | #21 | |
Rep 863
This Logic is Crazy IMO - Replace at 75K as Maint Item
2. This process can occur and NO oil or coolant is leaked externally 3. Your car suffers from coolant / oil mixing 4. Eventually the gaskets are so bad that they leak externally and are replaced 5. Internal engine problems have already occurred but now you blame issues on the act of replacing the gaskets. IMO I believe that 75K Replacement is good preventive maintenance plan or when a leak is observed or by checking coolant tank of presence of oil contamination & then replacing. For a Stage II and up this maintenance could be increased every 50K due to heat related issues. Just my 2. |
11-18-2019, 09:30 PM | #22 | |
Rep 1,115
https://f30.bimmerpost.com/forums/sh....php?t=1488124 Mine has been replaced by the dealer before warranty was up. |
