06-23-2019, 11:37 PM | #45 | |
Rep 400
I knew in theory but easier said than done. Much higher speed than auto x kinda got scared. Now I noticed that the traction control didn't even kicked in. (left it in sports+. Normally on Auto X, always TC fully off) Next time.... Last edited by TajoMan; 06-24-2019 at 12:07 AM.. |
06-24-2019, 06:53 AM | #46 |
Rep 3,503
That's a healthy reaction. Matching driving skills to speed is the challenge and what will keep you on the driving surface.
TajoMan174.00 |
06-24-2019, 06:55 PM | #47 | |
Rep 26
Interesting, the instructors last weekend told me that I need to trail brake as I enter turns and slowly release, inducing understeer with too much speed is actually slow. I mean it sounds cool and is really fun but very hard on the equipment and if I can gain a few tenths by being smoother why not. Like the vids Tajo! |
TajoMan174.00 |
06-24-2019, 09:16 PM | #48 |
Rep 400
2 of the tires have abnormal wear.
This happened during the Auto x school in April when I did 26 runs almost back to back. Front 2 tires were like this. (one is worse) I saw similar wear from other cars with RE71r as well. It seems like it's due to overheating the outer edge with lack of proper camber. I guess I have to keep my eyes on it. |
06-25-2019, 08:50 AM | #49 | |
Rep 2,874
bryan_G011164.50 |
06-25-2019, 04:32 PM | #50 |
Rep 1,931
When you hit the brakes, hit them like you mean it! Stand on them... You should be able to go from 130 to 60 in less than 2 seconds and dip into the apex. As you push your braking reference point further to turning point, thats when your going to want to trail brake into the turn.... It assist with the understeer. You can even learn ho to left foot brake to help.
As shown here in turn 1 of LRP: https://www.facebook.com/bryanduncan...6219213296457/ same turn, track from in car: https://www.facebook.com/bryanduncan...2585834664262/ Using brakes for weight balance and distro is an entire conversation by itself, but as you progress as a driver, and learn your cars characteristics, knowing how and when to break to setup for a turn is good for a couple of seconds. LRP is my favorite spot as its semi local, and if you mess up 1 turn, your whole lap is wrecked.
www.nybmwcca.org
06-25-2019, 08:35 PM | #51 | |
Rep 3,503
At the risk of way too much information, examples follow below. Each is a high-speed, former F1 track. The first is Mont Tremblant, a track requiring modest trail-braking, including two turns requiring only a short, sharp press of the brakes. The steering wheel is off by 10 degrees to the right in this video. https://www.youtube.com/watch?v=2e3aaeSGgCI In comparison to Namerow, note the steepness of the application and especially the release of the brakes in the turn under the Bridge. This despite the fact that both are uphill, straight-line braking zones. The 15 MPH increase in speed accounts for the trail-braking going up the hill to Namerow. In contrast, Watkins Glen is a very heavy trail-braking track, as shown in the video and the data traces that go with it. Look how far this professional driver trail-brakes across the track going into many of the turns; he's holding the car at the very edge of the tires' adhesion. https://youtu.be/NMdnioBa0E The brake trace of the turns where the driver is trail-braking ½ or more across the width of the track shows just how much and how long he's trail-braking. The reason for the jaggedness of the brake pressure while trail-braking is because in addition to slowing the car as necessary, he's also steering the car with the brakes. That is, the rising and falling brake pressure is keeping the car on a smooth and perfect arc from the turn-in point to final brake release. At the turn-in point, the car has been slowed only enough to allow it to turn in while maintaining the desired line. From 1:03 to 1:07 in the video, the data overlay shows the driver using a rising and falling throttle to effect the same type of result, thereby allowing the car to smoothly turn down to the curb in the Carousel. In this car, pressing and releasing the throttle one or two credit card thicknesses was enough to produce the desired result. Here the driver is shown using the brakes for ~460' going into the Bus Stop, finally releasing them just before he climbs up onto a significant curb at 90 MPH. The purpose of this breakdown of the Bus Stop's braking zone is to show (generally) how a professional race car driver uses the brakes, especially the throttle-to-brake transition. (Not shown is the transition from no-throttle/no-brake back onto the throttle, which also has a "knee" in the throttle trace (i.e., the driver eases onto the throttle for ~1/10 of a second before fully opening it; on this lap, he reached full-throttle with the steering wheel turned 72° to the left.))
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF Last edited by dradernh; 07-15-2019 at 05:25 PM.. |
ggggbmw435.50 |
07-15-2019, 03:48 PM | #52 |
Rep 400
Another Auto X last weekend.
Weather was super hot (95F) but spraying water on tires worked pretty well. (didn't feel greasy) More and more I Auto X this car, I feel like the car is just way under tired. For the weight and power, it should be at least 255 or 265 (just like M2 or new Supra) I got the tires flipped today. Inner half looked almost new. lol (damn camber...) |
07-15-2019, 04:50 PM | #53 | |
Rep 12
Last edited by Bareiss; 07-15-2019 at 04:51 PM.. Reason: To add additional information |
07-15-2019, 05:15 PM | #54 | |
Rep 400
I knew it's legal but someone mentioned it's not. Basically about 80% of serious Auto Xer runs with RE71r. (14% Rival, and 1% etc.) Now I am wondering about Yoko Advan A052. |
07-15-2019, 06:58 PM | #55 |
Rep 12
Andy Hollis published a pretty comprehensive test of 200 TW tires in the August issue of Grassroots Motorsports. When Andy says something about tires, you can certainly believe him.
07-24-2019, 12:39 PM | #57 |
Rep 87
I have issues with MP4S where I destroy the outside of it due to lack of camber plus the fact that they love to lose chunks of rubber all at once. Might try these as summer tires (I don't do a lot of mileage) that I leave on at the track a few times a summer...
07-24-2019, 05:58 PM | #58 |
Rep 3,503
That's normal. Between the lack of negative camber and the fact these tires don't like the heat generated by running the car on race tracks, reports such as yours have been coming in for years now. The photos are often pretty dramatic considering that owners plan on driving their cars home from the track.
07-25-2019, 12:04 AM | #59 | |
Rep 400
Also, you can't help the lack of camber. It wears only outer half for track or auto x use. It's a must to flip after a while. As long as you don't put too many miles, it will be very good track tire. (it's as sticky as the R comp 10~15 yrs ago) |
08-01-2019, 02:44 PM | #61 | |
Rep 3,503
When it comes to wheels and tires, the issue with these cars is fitment. My requirement for the track was 255s front and rear, and you can see in my signature what I came up with for a solution.
bryan_G011164.50 |
08-12-2019, 11:01 AM | #62 |
Rep 400
Another Auto X with CCSCC.
After 130+ Auto X runs, tires still have about 30~40% left. After this tire, I want to try Yokohama A052. According to Tirerack's test, it is even faster than RE71r. |
08-22-2019, 07:02 AM | #63 |
Rep 2,874
RE71r is really a track cheater tire, pretty bad in the wet I'm told so it may be a bad idea as a general summer tire. I have been running the s007 and quite happy with it - almost identical treat pattern to the MPSS/Conti and does very well in heavy rain, have not had the same wear problems on track (still more outside edge wear), and it is also a 200 - but a legit 200, not a '120-labelled-200'. I also found that the Conti summer tires did OK on track last season - wore fast, but not as bad as the MPSS and not chunking.
08-26-2019, 08:37 PM | #64 |
Rep 400
Another Track Sprint event by TSSCC.
Finally turned the traction control off in last 2 runs. (~0.7 sec improvement) Tires are nearing end of it's life. (~140 runs of Auto x and track sprint ) |
09-07-2019, 10:38 PM | #65 |
Rep 33
I'm pondering the Yokos too. Thinking about buying a set. I mostly use the car for road touring with the occasional autocross expected in the future. I just finished a season of AX with the local Chapter of BMWCCA with the PSS in stock staggered sizes.
Not interested in going down to 17 so either running f225/40 r255/35, f235/40 r245/40, 235 square or f225/40 r235/40. The reason for the indecision is clearances with the shocks as the 235 Yoko has the same tread width as 245 RE71 even though it has the same section width as a 235 RE71. The 225 Yoko tread is the same width as the 235 RE71 and the 255s are very wide compared to the 255 PSS like same section width 10.2 but 9.5 vs 8.7 for the PSS for tread width :P. Just worried about the tread not recessing away enough from the shock towers XD. Last edited by rhop101; 09-08-2019 at 05:42 AM.. |
09-08-2019, 01:49 PM | #66 |
Rep 400
yokohama seems very wide compared to RE71r.
I noticed that Yoko's been used quite a bit in this year's solo national. (STS class was dominated by yoko) I have to think a little bit since I cannot flip yoko. |
