05-21-2019, 09:41 AM | #67 |
Rep 25
Installed K-MAC front camber bushings in M235i
Installed the K-Mac bushings this weekend. I'd give the whole thing a B. The website is kind of awkward, I had to follow the discussion here to get the right part number. They were easy to deal with though, shipped fast; from Australia.
As to the install. They left out the pusher part of the stock bushing removal tool. So the drive nut bore only on the inner metal part of the bushing. It drove out the bushing as advertised though. If I return to stock, I'll plan on new bushings. The system uses serrated washers and tooth features to prevent the bushing rotating away from the desired eccentricity. It was a pain to keep these aligned and concentric until all tightened down. Lastly, the larger washers contacted the lower area inside the bushing mounting flanges/ears? I had to clearance these with a Dremel tool. Not a big deal, just not expected. The pic shows the driver side from the rear. The washer and hub extending past the flange was a little disconcerting, but I got over it. I ended up with -1.6 and -1.7, which is the range I was after. I didn't want to go to -2.0 or more for concern about related components, other geometry changes. No miles on it yet, but it seems solid. Met my expectations after a little tweaking. Maybe too much detail, but I like this kind of info when I'm looking at a modification. DLJ |
05-23-2019, 11:02 PM | #68 |
Rep 260
Excellent info. Would love to hear about how they feel after you've put some miles on them. Did you notice if they changed your caster and pushed the wheels forward like the M3/M4 LCAs do?
05-24-2019, 11:09 AM | #69 |
Rep 25
I didn't compare was-v-is on the caster specs, but they were within the factory green on the alignment system.
I'm doing a track day in a couple of weeks. Hoping this helps the front tire shoulder life a bit. |
05-24-2019, 07:41 PM | #70 |
Rep 5,262
Any reason you went this route instead of M3 LCA's ?
05-26-2019, 10:41 AM | #71 |
Rep 25
I liked the idea of the adjustability and buying less parts. Honestly, I didn't research it thoroughly; I was concerned about shims, connection to suspension sensor and final camber. I just didn't have the feeling someone had a fully baked package of all parts, installation and results. Might be out there, just didn't find it quickly. And this seemed easy to do.
If I decide I need more camber, it might be the way to go. It sounds (pun warning) like there are too many NVH issues with camber plates. I don't want full boy-racer, just better for a few track days per year. |
05-27-2019, 12:09 AM | #72 |
Rep 3,535
Drives: 328d Wagon, M2 Comp, i4 eD35
They do increase caster. When I maxed them out on my F3x it pushed my caster to 8.5 and 8deg. I installed the KMac caster bushings to set both sides at 8deg (8.5deg rubbed at full lock).
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
Sypher82.50 |
05-27-2019, 10:44 PM | #73 |
Rep 66
I've had the KMAC front and rear camber bushings on my car since February and am very happy with the results. That said, I'd echo DLJ's feedback on the install; my shop had a tough time getting the camber set. They are a race shop and only do string alignments so I don't have a printout of my settings but they were able to get -2/-2.6 F/R. The bushings do seem to increase front castor. I'm running more camber out back to help tuck my summer wheel/tire combo and keep the rear stable during high speed transitions. I got the KMAC rear bushings so I could keep toe at 0 and run more camber. These are super worth it, and I'd recommend them to anyone who wants similar alignment specs.
With my alignment specs the front end feels much more engaged than with oem alignment. It isn't darty on the freeway but the car turns in smoother and holds a line much better. I haven't had the chance to track it this season, but on the freeway interchanges in my commute and the few mountain runs I've taken they make a noticeable difference. They are worth it if you want to improve the front end feel of your DD/weekend warrior and don't plan to run more than a 235/40 up front. I had AFE F80 lowering springs and F30 sway bars installed at the same time as the the KMAC bushings were installed so I focused my feedback here purely on how the front end feels as a result of the KMACs. The picture doesn't do the front justice but you can see how tucked the rears are with 225/40 sq winter tires on oem wheels. |
06-04-2019, 06:25 PM | #74 |
Rep 26
I just ordered M3/M4 LCA's for the front which will hopefully give me 1 more degree of negative camber.
Has anyone installed these bushings into M3/M4 LCA's? or is that just too much for the rest of the components to handle? |
06-27-2019, 03:11 AM | #75 | |
Rep 137
06-30-2019, 11:19 PM | #76 | ||
Rep 66
2015 BSM M235i 6MT Dinan Turbo|KWV3|GC Camber Plates|OEMConcept 437M|Kumho PS91 225/255|Wagner HFC|MHD Custom Tune (Weekend Warrior)
2017 Alpine White X3 35i M-Sport (Daily Driver) 2020 Alpine White X7 40i M-Sport (Wife's Car) |
07-03-2019, 09:12 AM | #77 |
Rep 87
Those that got this working, you ordered 193616-8H ?
Just asking because the KMAC website is really confusing me. Then it seems the ECS site says 193616-8H works on F23... but not F22 (I have a coupe RWD M235i). But from this thread it seems that is the right part number, I am just unclear as to wether anyone installed them on a RWD M235i or only X-Drive. Even if the install is a bit painful this could finally be my solution for more camber without too many downsides on the road... Thanks! Last edited by Gepeto; 07-03-2019 at 09:25 AM.. |
07-06-2019, 01:11 AM | #79 |
Rep 3,535
Check RealOEM RWD and xDrive bushing PNs. If they're the same then you use the same KMAC bushing too. On the F3x platform that bushing is the same RWD and AWD. I suspect it's the same for your platform too.
07-17-2019, 09:14 AM | #81 |
Rep 87
Ordered, now waiting for them to show up in Canada. They'll have quite a bit of mileage even brand new! Will report once installed... currently way too excited over a change of maybe 0.8 to 1 degree in negative camber, but that's the F22 life!
07-17-2019, 03:59 PM | #82 |
Rep 25
I can report that after 2 track days without and 2 with the Front KMAC bushings, I'm happy with the improved tire wear. The fronts seem to be wearing reasonably evenly.
Not a great pic but lol at all the crap that gets picked up |
jondagger90.00 |
07-24-2019, 12:05 PM | #83 |
Rep 87
Can't wait to get mine, unfortunately ordering from their site has been a trainwreck, their site kept charging me in the wrong currency and I am still waiting on Paypal processing the reimbursement. Highly recommend that people in the US buy from a place like ECS Tuning instead of direct.
08-17-2019, 10:43 AM | #84 |
Rep 5
Hi, I would like to know if these kmac camber bushes (193616-8H)
1) continue to work properly 2) need to be installed alongside the 193616-5J caster one to keep the wheel centred in the fender 3) are made of rubber or polyurethane 4) are internally made as spherical joints or cylindrical* *PS I ask if they are spherical because I've read that superpro bushes are not produced any more because they do not permit the small arm movement given by the fact that our cars (F20, F21, F22) have a virtual steering axis which when steered behaves like an articulated parallelogram when viewed from above and so the polyurethane bushes suffers and get loose. |
08-18-2019, 03:54 AM | #85 | |
Rep 5
(for reference https://www.vividracing.com/kmac-fro...152459126.html vs https://www.ecstuning.com/b-kmac-par...193616-8h~kma/) Last edited by Xwang; 08-18-2019 at 09:47 AM.. |
08-19-2019, 05:01 AM | #86 | |
Rep 5
08-19-2019, 12:06 PM | #87 | |
Rep 3,535
2) Don't need to install the caster bushing in conjunction with it. Your caster will increase as you increase negative camber. 3) The caps/sleeve are polyurethane. 4) The main bushing is cylindrical. These shouldn't have the same failure mode as the SuperPro bushings. I actually inspected a failed SuperPro bushing this weekend. The flange that's supposed to prevent forward/rearward deflection/travel on the SuperPro bushing weakened and allowed the arm to rock laterally, vs only pivoting around the main cylinder. KMAC's design shouldn't fail this way for two reasons. The first is the metal inner bushing/cylinder is much larger. Since it's rigid, it allows less deflection (the metal inner cylinder in SuperPro's bushing is tiny). Secondly, KMAC uses metal end washer/caps that encapsulate the PU sleeves, so the PU is supported by metal and not supporting the lateral load all on its own.
