2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes Strut Tower Bolts - Torque Settings.
      02-21-2017, 03:22 AM   #1
Billy_BMW
United Kingdom
54
Drives: BMW M2 Competition
Hi all,
Wondering if anyone has the BMW torque settings for the strut tower bolts. See highlighted pics of said bolts:
Many thanks!
      02-21-2017, 09:53 AM   #2
Uridian
Uridian's Avatar
42
Drives: E36 M3, 228i M Sport
20.7 lb/ft each
From this guide: http://f30.bimmerpost.com/forums/sho...d.php?t=994489
And cross referenced the part numbers from the F30 to the F22. Same part number, same bolt, same torque spec.
      02-21-2017, 10:11 PM   #3
Billy_BMW
United Kingdom
54
Many thanks!
      02-27-2017, 08:34 PM   #4
Taunto
Car Enthusiast
Taunto's Avatar
Drives: 2016 BMW M235 X-drive
Not trying to sound rude But i have no idea where those specs came from.
Right from BMW repair instructions
Bolts must be replaced - torque to Yield
Joining Torque 30NM
Angle Torque: 90 degrees
2016 M235 - Melbourne Red
2005 BMW M3 - Sold
Licensed Automotive technician for BMW Regina
      02-28-2017, 12:28 PM   #5
Billy_BMW
United Kingdom
54
After further digging, the actual value is 56Nm. The first document from ISTA shows the torque value. The others cross reference the relevant part numbers.
The strut mount bolts are M10 bolts, not M8.
      03-01-2017, 09:19 AM   #6
Uridian
Uridian's Avatar
42
Wow, ok... I guess I'll be retorquing mine this weekend!
However, I don't see how your ISTA image relates to this bolt's part number.
      03-01-2017, 10:56 AM   #7
Billy_BMW
United Kingdom
54
The part numbers that correspond with those on realoem confirm they are M10 bolts (see on right of partnumber in realoem picture). The ISTA states that M10 bolts should be 56Nm.
      03-01-2017, 01:54 PM   #8
Uridian
Uridian's Avatar
42
I get that, but I'm curious how you're making the connection from the ISTA page with no part numbers to realOEM with part numbers. I'm not trying to make a stink, I just want to be very sure both sources are referring to the same bolt.
The ISTA refers to a "nut and locknut/self locking nut" without specifying where it is in use (such as "guide support" on realOEM). The actual part is a bolt with a washer.
      03-01-2017, 03:15 PM   #9
Billy_BMW
United Kingdom
54
Purely on the basis that it's an M10 bolt. You're right ISTA doesn't correspond to actual part numbers. If someone with access can step in and advise, it would be appreciated. For now, I've gone with 56Nm as that was what I was advised by local dealer parts advisor.
      11-14-2019, 08:15 AM   #10
ChristosD
ChristosD's Avatar
South Africa
97
Drives: m135i
did anyone ever find out the correct torque setting for these bolts
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT //
//CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 //
      11-14-2019, 10:03 AM   #11
BEM-S4
BEM-S4's Avatar
It's 30NM, I was told by Matt Bean (former performance specialist at Thompson BMW) when we were installing my strut brace. Note they are single use only and easy to snap, so definitely use a fresh set and a properly calibrated wrench.
      05-25-2020, 01:44 PM   #12
nikijack
Drives: 2016 M235i, Grey, manual
On my car (2016 M235i) There are 5 bolts, M8.
      09-24-2020, 07:51 PM   #13
BMW mind
Drives: BMW M235I
Yes its 30nm, do not torque to 56nm, you will break your bolts, if they don't break they will be at their very limit, when I torqued them to 56nm they broke.
