2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes m4 tension struts to go with lcas
      05-29-2016, 04:57 PM   #67
rwalker
Drives: the wheels off
Originally Posted by Bee Pee View Post
Do the front wheels have more chance to rub (ie poke out further) with LCAs and TSs compared to just LCAs
to me, no discernible difference
      05-29-2016, 05:42 PM   #68
Bee Pee
United Kingdom
1738
Drives: AW M2 DCT
Ok good to know and last questions
1-has front ride height changed ?
2-how does the car feel with TS's ?
Fettled M135i EB AT - gone but not forgotten:
AW M2 DCT
      05-29-2016, 07:20 PM   #69
rwalker
2-how does the car feel with ?
As I've posted before: I think ride height has increased, but it's another case where I don't have real "before" information.
Camber looks to have gone slightly more positive (maybe 0.25deg), but my measurement tool is crude (phone taped to a straight edge with a level).
Car feels great. There are perhaps more interior rattles surfaced, but the front is really sharp. I was at the Bimmerfest autocross yesterday and was able to get plenty of runs in.
Pics of car as she sits (well, almost: I have cleaned up the cone marks on the rocker panel since taking these )
      05-30-2016, 02:13 AM   #70
Bee Pee
United Kingdom
1738
Drives: AW M2 DCT
RW,
Looks good with 441m's
Did the alignment need adjusting when you had it checked post install ?
BP
AW M2 DCT
      05-30-2016, 02:18 AM   #71
rwalker
RW,
BP
thanks for the props
but srsly? you quoted my post (#63) on alignment (toe)... much?
no adjustment needed for alignment, as far as I can tell
      05-30-2016, 02:19 AM   #72
M235iguy
M235iguy's Avatar
Drives: 2016 M235ix
nice
2016 ///M235ix | MP Grilles | MP Pedals | Gloss Black M235i Badge | Dinan CAI | Dinan tune | Dinmann CF Diffuser | MP CF Spoiler | CF mirrors | M2 CF interior | M2 Steering wheel
      05-30-2016, 02:30 AM   #73
Bee Pee
United Kingdom
1738
Drives: AW M2 DCT
Yes - England beat Wales yesterday at the rugby here in London - long day followed by a long night - just as well its a public holiday. You must be up late in San D !!!
AW M2 DCT
      05-30-2016, 04:40 AM   #74
Kasteel
Drives: BMW Z4M MY07
Are these 441m 8,5J square? /which spacer+tyres do you use?
      05-30-2016, 04:56 AM   #75
Bee Pee
United Kingdom
1738
Drives: AW M2 DCT
Looking at the last photo the front tyres are 255/35/18 MPSS so must be a 8.5" 441m up front.
Given that these are et47mm, RW has 5mm spacer fitted to clear strut - see post below
http://www.2addicts.com/forums/showp...60&postcount=1.
Also RW running camber plates hence he's able to get the top of the tyre further inward and run much higher camber angles than just with LCA + TS.
Any photos of your car with LCA and TS installed ??
AW M2 DCT
      06-02-2016, 01:33 PM   #76
quenotte
France
60
Drives: F87N M2 Competition
Originally Posted by Pparana View Post
Glad you got them in,
I ended up putting in larger spacers, I used 1/2 on the inside and a 1/4" on the outside with a 1" od, 1/2 ID. Summit had them, they also have them in 1.5 OD, but were out of stock, I will prob. order those next time from them.
I also noticed on mine, it pushed the wheel further out, so The track width is more in line with a m3/m4.
I am now running 15mil spacers in the rear and 7 mil in the front.
Before I ran 12 mil in the front. That gives me a track width difference of .9 inches. 62.4 in the rear, 61.5 in the front. That is on oem wheels.
This is it quite confusing for me...
To sum-up, and complete BP post, for the F8X TS upgrade:
Let's talk in milimeters since car is designed in metric.
Material - Stainless Steel, Aluminium?
OD - 1.5": 38.1mm ?
ID - to suit M12: 1/2": 12.7mm ?
Length:
- Front/Outside:
- Pparana 4mm
- rwalker 1/4": 6.35mm
- Rear/Inside:
- Pparana 15mm
- rwalker 1/2": 12.7mm
Total Length (Front/Outside + Rear/Inside)
- Pparana 4mm + 15mm = 19mm
- rwalker 1/4": 6.35mm + 1/2": 12.7mm = 3/4" = 19.05mm
rwalker reduced 1/2" spacer by half a millimeter: 12.7-0.5 = 12.2mm
6.35+12.2 => 18.55mm length
But then Pparana, you talk about 15mm (rear/inside) + 7mm (front/outside), that lead to a length of 22mm, 3mm more than previous setup!
So what are the right values in mm to match F8x geometry, more correct wheel placement and less bushing wear, ?
Many thanks in advance!
Last edited by quenotte; 06-02-2016 at 06:46 PM.. Reason: Bogus calculus... Thanks BP!
      06-02-2016, 01:38 PM   #77
rwalker
Pparana is referring to wheel spacers in that sentence, not TS spacers. You can ignore Pparana's first TS spacer setup as he's now running 0.25in/0.50in (outside/inside), just like me.
I think if you insist on metric spacers, they'd be 19mm total. Your choice will be whether to do 6mm/13mm or 7mm/12mm (outside/inside).
      06-02-2016, 04:08 PM   #78
Bee Pee
United Kingdom
1738
Drives: AW M2 DCT
rwalker reduced 1/2" spacer by half a millimeter: 12.7-0.05 = 12.65mm
6.35+12.65 => 19mm length like Pparana
1/2mm is 0.5mm not 0.05mm
12.7 -> 12.2
19mm -> 18.5mm
Based RW's experience, I have 12.2mm and 6.3mm spacers 30mm OD and m12 ID
      06-02-2016, 05:52 PM   #79
quenotte
France
60
Very nice thanks! (Sorry for my bogus calculus... )
BP, did you use aluminium spacers or stainless steel?
Where did you order them in UK?
I plan to use stainless steel spacers to be sure that there is no problem, since we don't have long term feedback about aluminium ones...
      06-03-2016, 12:57 AM   #80
Bee Pee
United Kingdom
1738
Drives: AW M2 DCT
Yes I bought stainless steel too.
I bought them off eBay UK - seller 19edward45 - guys name is Vic - email address is victorescott@hotmail.co.uk
Vic made the spacers to my specs. Good service, prompt and value for money.
AW M2 DCT
      06-03-2016, 03:28 AM   #81
quenotte
France
60
Thanks!
I contacted him to order stainless steel spacers
Next step is to order TS parts at my local BMW dealer.
      06-03-2016, 09:39 AM   #82
quenotte
France
60
Grrr...
I contacted Victor and he answered "Sorry I can not help you with these"...
Edit: It's OK with Vic
      06-14-2016, 12:00 PM   #83
quenotte
France
60
Hi BP,
Did you had time to install your TS?
I'm still waiting for Victor to manufacture SS spacers.
I've received F8x TS + bolts
      06-14-2016, 04:22 PM   #84
Bee Pee
United Kingdom
1738
Drives: AW M2 DCT
Hi BP,
Hi,
Not yet work and cr@p weather getting in the way just now.......
BP
AW M2 DCT
      06-19-2016, 04:39 PM   #85
Kasteel
Finally some:
http://f20.1addicts.com/forums/showthread.php?t=1275186
      06-20-2016, 04:02 AM   #86
Bee Pee
United Kingdom
1738
Drives: AW M2 DCT
Kasteel,
Any side view photos showing how the front wheel sits in the wheel arch ?
BP
AW M2 DCT
      06-20-2016, 11:18 AM   #87
Kasteel
Kasteel,
BP
View post on imgur.com
- not perfect point of shot (slightly to the left)
- steering = straight
- this is before the spacers
      06-20-2016, 03:47 PM   #88
quenotte
France
60
Since this was not clear, what Bee Pee and I ordered for the F8X TS upgrade:
Material - Stainless Steel? Aluminium?
OD - 30mm
ID - 12mm bore (to suit M12)
Length:
- Front/Outside: 6.3mm
- Rear/Inside: 12.2mm
Total Length (Front/Outside + Rear/Inside): 6.3mm + 12.2mm = 18.5mm
Thus, I ordered to Vic (See Bee Pee post #80 above ) :
- Front/Outside: 2x Stainless Steel 12mm bore x 30mm dia x 6.3mm long
- Rear/Inside: 2x Stainless Steel 12mm bore x 30mm dia x 12.2mm long
Search this Thread:
