03-04-2017, 04:38 PM | #309 | |
Little Deuce Coupe
391
Rep 635
Drives: SO M2C
Here's some more pics of mine. Mind you, this is after a charity laps event at Virginia International Raceway, so there are 200 miles of highway grime and 12-15 track laps of brake dust on them.
ex: 2004 Thermonuclear Yellow RX-8|6MT
ex: 2015 Estoril Blue M235i |6MT|slicktop|MP exhaust - PCD 2020 Sunset Orange M2C|6MT|Black 788s |
03-05-2017, 09:45 PM | #310 |
Rep 5,386
Thanks for posting the extra pictures. Yeah, running BMW center caps will require some silcone for safety. I'm also going to run metal rings in the caps to keep them tight.
03-06-2017, 02:11 PM | #311 |
Little Deuce Coupe
391
Rep 635
Drives: SO M2C
I've thought about a ring/spring inside to help the arms to stay tight. Could you post what you come up with?
03-06-2017, 03:59 PM | #312 |
Rep 5,386
03-07-2017, 12:25 PM | #313 |
Rep 27
12-08-2017, 05:12 PM | #317 |
Rep 219
Does anyone have a picture of BMW 2-series (preferrably M235i) with Style 230 rims from the E92 3-series? I looked all over but couldn't even find one. I know they fit and look good on the 1-series, but what about 2?
Bmw240xi1833.00 |
12-10-2017, 09:15 PM | #318 |
Rep 3
I hope someone can help me, i had to register since i couldn’t find much info so i can ask wether this would really work as these are my only options,... work meaning no rubbing and poke
I’m on H&R With these options for Rins to upgrade: Option 1 19x8 Et35 19x9 et44 What are my tires option for a sure no rubbing and poke? Option 2 19x8.5 et 35 19x9.5 et 38 What are my tires option for a sure no rubbing and poke? TIA |
01-18-2018, 04:27 PM | #319 |
Rep 30
Wheel fitment question
Hey gang, I used an offset calculator and these should fit, but asking for verification...
I want to get a set of 19x8.5 et30 and 19x9.5 et35. The fronts should have the same clearance as stock and the rear will be about 36mm more towards the outside than stock fitment. Any suggestions? |
01-18-2018, 11:19 PM | #320 | |
im a car
737
Rep 1,117
Drives: 220i M Sport | 520i M Sport
'14 220i M Sport | AW/CR | PUR Wheels RS07 19" | KW V1 | MTC Design F2X Kit [CF] | Stage 1 ECU Tune | Eventuri CF Intake | Manhart Race Exhaust/Resonator Delete | ER HFC Downpipe | F8X LCA + TS | M Style Grilles | Gloss Black Roof | Custom Steering Wheel | Autotecknic Competition Shift Paddles [YMB] Instagram: @icyj95 | FB |
03-27-2018, 10:35 AM | #321 |
Rep 143
10-26-2018, 06:40 PM | #323 |
Rep 1
Rim details
11-02-2018, 02:26 PM | #324 |
Rep 197
Are you running any suspension setup here?
16' M235i Active Autowerkes Stage 2 Tune/DP/FMIC/CP - Dinan CAI/Lowering Springs - 19x8.5/19x9.5 Forgestar CF5V Bronze Burst
02-10-2019, 04:17 AM | #325 |
Rep 4
02-17-2019, 04:49 AM | #326 |
Rep 3
Hi,
I wonder if I could put some tires dimensions on my M235i on GK wheels 270 without touching the fenders. http://www.gebr-knechtli.ch/shop/d/pdet/87/1328 235X35X19 on 8.5 X 19 ET34 (front) 245X30X19 on 9.5 X 19 ET34 (rear) How Can I check this before to buy the tires ? Thanks ! |
01-05-2022, 01:47 AM | #328 |
Rep 7
Hey, I’m sorry this is probably a stupid question but I just ordered a 2015 M235i and I’ll definitely be in the market for some aftermarket wheels/tires. I had an f30 prior to this. Would my wheels from that fit on the 2 series?
02-01-2022, 09:56 AM | #329 |
Rep 2
Which OZ LEGGERA HLT to choose?
Hey guys, after having 428i xdrive, and 435i convertible, finally bought an M240i Xdrive Coupe a week ago, and want to get rid of the factory 18x7.5 rims, which are pretty heavy. I'm in love with OZ LEGGERA HLT, but I'm not sure what size to choose. Don't you think 18" would look small? Maybe I'd better to get 19"? If anyone has photos of 2-series on 18" and 19" OZ leggera - please, show it! I'm really struggling. Thank you!
[IMG][/IMG] |
02-01-2022, 01:18 PM | #330 | |
Rep 913
Keep the factory wheels for winter - get the wheels you like for summer. I stayed with 18's on my car because I prefer a little extra rubber between the wheel and the road, plus keeping unsprung weight down.
Rogue Engineering SSK & transmission mounts, WaveTrac LSD. Ohlins R&T coilovers, Turner monoball thrust arms, F87 LCAs, GC camber plates, Superpro subframe bushings, Megan Racing adj. RCAs, delrin differential bushings. Stoptech BBK 6 piston (f) 4 piston (r). |
dradernh4470.00 |
