2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning M235i 6MT Gear Ratios
      11-12-2019, 04:40 PM   #1
Dannyxz
Drives: BMW M235i
Hello all,
I’m new to the 6MT’s and am wanting to better understand the gear ratio in this car.
My main questions are:
At what speed should you be at when downshifting in each of the gears?
How much should the RPM fall in-between each gear before releasing the clutch? (To avoid the car surging forward or bucking)
Is the 1->2 shift purposefully a pain in the butt in this car?
Appreciate any insight!
      11-12-2019, 05:24 PM   #2
overcoil
Drives: M235i 6spd
The 1-2 shift, yeah, but first gear is excellent for crawling in very slow traffic and 2nd gear is perfect for slow corners minimizing shifting. So the 2nd to 1st gear downshift is many times unnecessary for slow turns.
I need to test to be sure, but 6th to 5th at 50mph, 5th to 4th at 40mph, 4th to 3rd at 30mph and 3rd to 2nd at 20mph.
Usually a 1000 rpm drop when upshifting into consecutive gears.
Since your new to driving a manual you should probably be upshifting between 2500 to 3000 rpm.
MLJR235116.50
      11-13-2019, 06:37 AM   #3
celsdogg
E4 Mafia
323
Drives: E30, E36/5, E46, F22, F30
1990 BMW 325i  [0.00]
1998 BMW 318ti  [0.00]
2003 BMW 325i  [0.00]
2015 BMW 335i  [0.00]
2015 BMW M235i  [0.00]
you are probably going to get a ton of differing opinions on this topic, haha!
I have always found 1 to 2 shifts required more effort to be smooth in every manual BMW I've ever driven. double clutching can help once you master the skill.
depending on how I am driving I like to keep engine speed in a certain range. for normal/everyday driving, I like to keep it between 2.5 to 3.5k in most cars.
in the m235i though, you can easily go lower since the motor produces so much torque down low.
Squad - '90 E30 325i MT (225k) | '98 E36/5 318ti MT (153k) | '03 E46 325i MT (152k)| '15 F22 M235i MT (60k) | '15 F30 335i MT (80k)
KIA - '91 E30 325i AT (146k) | '02 E46 325i MT (212k)
Bring back the purple M stripe
MLJR235116.50
