2Addicts | BMW 2-Series forum Technical Topics N20 (228i) / B46 (230i) Engine, Transmission, Exhaust, Tuning Added Bootmod3 to 230i
      10-20-2019, 09:14 PM   #1
Uwrwilke
Drives: BMW 230i
Just added a stage 1 OTS bootmod3 flash to my 2017 230i. Notice big increase in boost throughout the rpm range. Not sure how accurate the Sport Displays are for HP and TQ but they both peak off the chart (320 respectively) - so if that's right, it's added ~70 hp and probably more TQ.
Only "mod" I have is a better drop in filter and the intake box snorkel taken off (which I'll probably put back on).
Pretty happy so far. Only weird thing is that it doesn't seem the flash is allowing me to change the exhaust flap to open on demand.
No codes... yet. If I do get some I'll post them here. Also hoping overheating/boosting isn't an Issue. May reduce the boost as this is my daily driver.
      10-21-2019, 08:59 AM   #2
sandrik93
Drives: '23 M240i RWD
I flashed Stage 1 93 around 3 months ago. No problems so far. Yeah, the flap settings are only open, close or auto.
      10-21-2019, 11:27 AM   #3
Congrats OP
Phone number 702-494-9435
      10-16-2020, 03:32 PM   #4
VitaminF22
VitaminF22's Avatar
Drives: BMW 2017 230i
Hey guys ive been flashing my 2017 bmw 230i with bootmod3 and i keep getting these codes:
21A02D, No Description available
101F01 Throttle-valve angle - intake manifold pressure limit value exceeded
118001 mixture control: mixture too lean
Can anyone help? Mods: Aluminum Charge pipe, Aluminum Turbo Inlet pipe, Catless downpipe, secondary cat delete, K&N drop in filter
      10-16-2020, 10:03 PM   #5
mb67
In search of the perfect cup of coffee
mb67's Avatar
Drives: 2015 228i Conv
21A02D is a Combustion control: valve lift correction when at idle. CAUSE. A software error in the Digital Motor Electronics (DME).
The first thing I found was this -
https://static.nhtsa.gov/odi/tsbs/20...38380-9999.pdf
There is also this site for fault codes -
http://bmwfault.codes/
      10-18-2020, 06:21 AM   #6
VitaminF22
VitaminF22's Avatar
Im not sure how to fix the engine from running lean though, I know a proper tune will do it but i dont know how to get a custom tune on bootmod3
      10-18-2020, 10:26 AM   #7
We offer custom maps, once you make the purchase with us, you will select the tuner from the list on bm3 interface and they will reach out to you with a base map to start with
mb67152.00
      10-24-2020, 11:23 PM   #8
Avaley
Avaley's Avatar
731
Drives: f32 430ix & 982 GT4 PDK
So mine does this too in WOT stage 1 and i'm in process of stage 2ing my 430i.
I think the B48/46 has potential for 300+ whp and 370+ wtq in stage 2 based on what ive seen.
      10-24-2020, 11:55 PM   #9
mb67
mb67's Avatar
300whp should definitely be possible.
https://bmwtuning.co/b48-tuning-guide-300whp-for-1500/
      11-07-2020, 01:38 AM   #10
Jacob657
Jacob657's Avatar
Drives: 2018 BMW 230i Sport Line
2018 BMW 230i  [8.50]
Can I use BM3 if I have the Dinan Elite V2 or whatever on my car? I'd rather not pay to have it taken off and would like to add some features BM3 has.
      11-07-2020, 09:58 AM   #11
You can use both
