2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning xDelete
      10-20-2019, 03:26 PM   #1
CEDS 2
Drives: 2016 M235i xDrive
xDelete
Anybody try xDelete for the F22's? Is it even compatible? I know they released for F chassis but all the posts/videos I've found are for the F30/32.
      11-22-2019, 10:51 AM   #2
H3G0N3_F22
H3G0N3_F22's Avatar
30
Drives: 2015 BMW M235xi
I just installed it last week, when I went out to test it on a wet surface after it had rain doing a launch control the rear tires never gained traction until I came off the throttle and easy away. Turning radius seem to be better and it may just be me, but my Lucy seems fast AF now w/ FOB, Pure stage 1, MHD 93 OTS map, XHP Trans flash and Burger tuning pedal booster in stock mode. So far so good, install was super simple once you purchase xDelete license and have the correct supporting Ethernet cable and adapter for IOS. Tried on my Android with micro USB adapter and it did not work. They list the Android devices that they have confirmed work with xDelete. For $149 I can't complain. Would love to hear what other F series owners with xDelete think.
      12-10-2019, 04:14 PM   #3
McDonald_F22
McDonald_F22's Avatar
Drives: 2016 BMW M235i
I tried it out but honestly without a LSD I can't see it being much fun. You get some oversteer but than one wheel burns up and ruins your tires. Xdelete with an Mperformance lsd would make the 235i Xdrive the best daily car to have.
      12-10-2019, 11:42 PM   #4
CEDS 2
So not worth it if you don't have an LSD?
      12-15-2019, 01:06 PM   #5
H3G0N3_F22
H3G0N3_F22's Avatar
30
I Agree, there is still a lot of un-control wheel spin in most of the gears or the DSC cuts in at less than optimal times to mitigate traction loss. It's not fun by any means, but with a LSD, a little work and some fine tuning it could perform better IMO. That said I was able to do a 0-60 in 4.65 secs with a .081 reaction time and that was just messing around on two attempts and lots of wheel slippage.
      07-01-2022, 12:36 AM   #6
RyanSira
I've used my Xdrive multiple times with no issues but now when I try to switch to xdrive off it wont let me. Every time the download fails at disabling xdrive. I tried to see if the recalibrating clutch download would work to try and figure out the problem and that completed with no problems. Any ideas why this literally just started happening?
